Question about Pioneer GM-5200T Car Audio Amplifier
Red light on my amp?
Hi I have the GM-5200T 760W amp and I hooked it up recently today and when i started my car, the sub put out virtually no sound. I was able to feel it vibrating a bit but the light on the amp is red. Not blinking, just solid red. my friend told me that the safety is on and I cant seem to find a button for it. My friend also told me to try resetting it by getting another wire with two open ends and touching the ground bold on the amp to the power bolt on the amp to make a spark and maybe reset it, but it didnt work.(btw is that a dumb thing to do?) But do you have any advice to my problem?
  • 2 more comments
  • darek678 May 22, 2008
    No, the light stays red. I just now also tried taking out the speaker control wire out of its bolt and the light turned off altogether, and when i put it back in, or even touched it back to its bolt, the light only came back red. Could this be a bad wiring problem within my radio system?
  • darek678 May 23, 2008
    The lights only color on the amp is red?
    There is a yellow wire connecting the amp to the back of my radio system on the deck that says "speaker control" on the amp.
    No, i have not yet tried a different speaker....I might tommorow though. I dont really have a blue wire thats able to reach my amp at the moment. Should I buy one? The yellow wire i have now is one that I recieved from my friend to hook up the amp that reaches to my trunk, all the way up under my deck. The only blue wire i was able to find today is about 3 inches long and is bunched up with about 12 other wires to produce the power plug for my deck, but the yellow wire I used has been spliced together with the blue wire and at least the radio seems to be working fine. However my 760W amp still doesn't seem to be doing anything for my 600W pioneer sub.
    Should I have 2 separate wires connecting to the amp, or should i go find a blue wire at an audiostore and use it to go directly to the radio instead?
    But i shall try and plug the amp into a different speaker tommorow if i get it to turn on now. but i'm afraid i dont know anyone atm that has another amp for me to borrow to see if its the faulty wiring.....and as for earlier today while I was inspecting the wiring around my system the power cord for the amp campe in contact with the ground and made a spark.....it shut off the amp and the light hasn't turned on yet, and i no longer have working turn signals in my car :P
  • Yung Stunter
    Yung Stunter May 21, 2013
    Ok I need help wit my amp when I put the RCA in both light come on and when I unplug it the green light come on so can someone help me with that
  • 631 Answers
Does the amp power up normally if you disconnect the speaker wires from the speaker terminals of the amp?
It's never a good thing to blindly short across a power source.
Posted on May 22, 2008
  • 1 more comment
  • Perry Babin May 22, 2008
    It's normal for the light on top of the amp to be on. There's only one color, red.
    What do you mean by 'speaker control wire'? What's the marking on the terminal?
  • Perry Babin May 23, 2008
    From what I can tell from the service manual, there is only one LED and it doesn't appear to be able to produce more than one color.
    The terminal says system control. It should go to the blue wire on the deck. The yellow wire on the deck is constant power (memory) and will cause the amp to remain on always (until the battery runs down).
    Have you tried connecting a speaker that you know to be good to the amp?
    Have you tried plugging the signal source into a different amp to confirm that the head unit is producing output?
    The color of the wire isn't important. There are common/standard colors used by head unit manufacturers.  When you said you used the yellow wire, I thought you meant you connected the wire feeding the amp to the yellow wire on the head unit.
    When the wire touched ground, it probably blew a fuse.
    Do yourself a favor and read through the following site. Particularly 14, 19, 22 and 23 (in that order).
    http://www.bcae1.com/
    After reading through those pages, let me know if you have more questions.
Why does my spa 500 amp blow a fuse every time I hook up my 15" lanzar sub to it
Because it's drawing more power than the fuse can handle get a fuse with a higher rating. A 100 app fuse worked great for main power with my setup 760w amp a 15"sub 2 10"subs and a 12" sub. Also my amp had 2 30amp fuses on it one for each channel but I ran everything out of one channel.
Aug 02, 2016 | Lanzar Car Audio & Video
Red light on on amp
take speaker wires off amp if the lit is green then speaker are hooked up wrong or blown.
Mar 29, 2014 | Pioneer GM-5200T Car Audio Amplifier
I have 2 pioneer 6x9 400w, pioneer GM 6500f 760w amp and a kenwood KFC W1012 sub, how d i get the best sound from these?
pioneer gm 6500 is a 4 ch amp rated at 60w-4 way to small of an amp to run your sub. UNDER-POWERING your sub is more likely to damage spkr than over-powering. my advice,get mono-block to run sub
Jan 04, 2013 | Pioneer 6X9 5WAY 400W SPKR Car Speaker
When just wblue wire is connected red light comes on
This sounds normal. The light comes on when there is 12v supplied to the blue wire (remote input). Need more details. brian.small@bobstgroup.com
Sep 13, 2009 | Pioneer GM-5200T Car Audio Amplifier
No sound from amp
THIS IS AN EASY FIX. DISCONNECT THE POWER WIRE FROM BATTERY. REMOVE THE GROUND WIRE FROM THE CARS BODY. SAND ALL THE PAINT AWAY FROM THAT AREA. WIPE IT CLEAN WITH A DRY CLOTH AND HOOK THE GROUND BACK UP. THEN RECONNECT THE POWER WIRE AND THAT SHOULD FIX IT. IF NOT THEN TURN DOWN UR GAIN CAUSE THE AMP IS OVER HEATING
Feb 19, 2009 | Pioneer GM-5200T Car Audio Amplifier
Pioneer GM-5200T problem
i dont think transistors are bad . you should check the amp controlls they may need adjusting
Jan 20, 2009 | Pioneer GM-5200T Car Audio Amplifier
POWER
short in the system, or bad ground, or connections?
Oct 22, 2007 | Pioneer GM-5200T Car Audio Amplifier
No bass at higher volume
Your battery should be fine! Although the amp might not be strong enough for the sub. All you can do is check the RCA cables from your radio to your amp as these might vibrate loose when you get to 17 volume and also check the monster cable from your amp to your sub asit might have vibrated loose as well.
Oct 21, 2006 | Pioneer GM-5200T Car Audio Amplifier
Pioneer GM-5200T Car Audio Amplifier Logo
3,926 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
