Question about HP PSC 1350 All-In-One Thermal Printer
HP psc 1350 HP 57 print cartridge
I have been getting the error msg print cartridge error and the light is blinking so it is for the color cartridge. I followed the instructions for solution of this problem including installing a brand new HP 57 color ink cartridge and the error msg still comes up and the printer won't pint anything. What can I do it fix it. I need the printer bad. Thanks
  • 8 more comments
  • Anonymous Jun 13, 2008
    same problem!
  • canada guy Jun 15, 2008
    same as above but for the black hp56 cartridge
  • Anonymous Jun 16, 2008
    I have the same roblem
  • Anonymous Aug 26, 2008
    Same problem with me too. My exact error message is the print cartridge is the wrong type. But it is the correct type...57.
  • andybuk Oct 02, 2008
    Same problem, but I don't have the tools to open the case. Also I don't want to buy a new cartridge as it costs much.
  • Anonymous Oct 07, 2008
    I have the exact same problem. I cleaned the contacts, replaced the cartridge, opened the case to inspect for any obvious disconnects or damage, but still nothing I seem to try will fix it.
  • schaapie Oct 17, 2008
    I have the exact same problem. I've run all of the problem solving stuff, but it still doesn't work...... Please help
  • ncd2000 Dec 12, 2008
    I just put a brand new color 57 cartridge in my machine and it gave me the same error message; telling me to remove the cartridge, and put it back in. I finally tried the old cartridge and it ran fine!! so I'm assuming it is something wrong with the ink cartridge. I've had this printer many years and never had this problem before. What a huge hassel, because there's no way to take the cartridge back to the store. It's been well over 6 months. So what am supposed to do? Write HP. I need the ink tonight! I will never buy an HP printer again. This one is a replacement for the one that broke a year to the day after buying it.
  • Anonymous Apr 10, 2009
    IT JUST DOESN'T WORK THE LIGHTS KEEP COMING ON A WHEN I PUT PAPER IN IT AND PRESS PRINT IT PRINTS SOMETHING THAT I DO NEED OVER AND OVER AN DFOLLOW THE RULES THAT IT SAY DO BUT IT STILL DOES NOT WORK.
  • Anonymous May 11, 2009
    light is flashing check print cartridge and there is a backwards 3 where the number of copies go and it will not print
  • 3 Answers
I did everything that was written here and nothing worked until I bought OUTDATED genuine hp cartridges. Just put them in and it works perfectly!! No new printer for me!!
Posted on Mar 27, 2014
My print cartridge was a no-name refill.  I put the empty HP back in, and the lights went away and it is working.  I am going to buy an HP cartridge.  Don't use the generic print cartridges.
Posted on Jul 30, 2008
Same problem with me.
So:
I openede the whole box ( 4 screws ) in the corners. Then I presed the tiny belt on the left side to its socket, cleaned the contacts of the cartridges (56,57) with water and made them dry.
Then I reched the position of the small door which is ment to be opened once you wnat to replace the cartridge.
After this the printer works again.
Posted on Jun 25, 2008
I had the same problem I have replace 56 nothing hapened.
So:
I open the whole box ( 4 screws in the corners ) once you open the deck you can see on your left side the tiny belt which I checked on its contacts and pressed it more stronger in it socket.
Then I cleaned the contacts of both cartridges with water and than made them dry.
Then I rechecked the position of the door which is ment to be opened once you replaced the cartidge I removed them and put them back.
After some of those steps the amber light ( checked the cartridge stoped blinking )and the printer is back in order.
jveceer
Same as above but fot the black hp 56 cartridge.
After installing a new one still the same problem.
The amber light -check cartridge - is blinking
Posted on Jun 17, 2008
Me too, today only
Posted on Jun 16, 2008
I installed new cartridges and printer will not print and the check printing cartridge appears no matter what I try to correct problem. its a psc 1315 all in one. Many thanks and hny. I am referring to the...
Will it print with the old cartridges? Sometimes you get a bum new cartridge. If you don't get the error with the old carts, then take the new ones back for exchange and try again.
Jan 01, 2010 | HP PSC 1315 All-In-One InkJet Printer
My printer doesnt print anymore error msg and will not turn off. Ive installed new print cartridges and no luck keep getting the error msg and wont print at all. I have a psc 1210 all in one
What is the error message?
Also, please consider the following:
Are you using a factory new ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Nov 16, 2009 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 1500 xi Cartridge Error Problem
You do need both cartridges installed in order to use the printer. Even if one is near empty it will print (although your quality may suffer).
Jan 16, 2009 | HP PSC 1510 All-In-One InkJet Printer
How do I get a alingment test
HP PSC 1200 and 1300 series:
  1. Turn on the HP PSC 1200 or 1300 series product.
  2. Disconnect the USB cable from the all-in-one.
  3. Press the sequence of front panel buttons below to start the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
    1. Press and hold Cancel .
    2. While holding Cancel , press On .
    3. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
    4. Press Cancel again.
    5. Press Copies .
    6. Press Paper Type .
    7. Press Color Start Copy . The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
  4. When the alignment page has printed, place the page face down on the scanner glass and press Scan . The alignment is complete when the On light stops blinking.
  5. Reconnect the USB cable.
Jan 14, 2009 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 750xi - Incorrect color printer cartridge installed error
I had this same problem and by a luck I fixed it. Not sure if the method to the madness had anything to do with it, but I'll put it down in the order that I did everything. 1. reset to factory defaults 2. pulled all cartridges out. it prompted me to put color in first, then black. message was still blinking so i took out color and put it back in again. 3. i did the partial reset by holding down cancel and left arrow while i unplugged/replugged the printer. 4. no the printer started displaying "remove and check color cartridge" (or something to that degree) 5. i took out color cartridge, cleaned the contacts with water on towel, and replaced cartridge. 6. same message still being displayed, but it allowed me to print a maintenance report. so i then cleaned cartridges and aligned cartridges through standard menu. 7. msg still being displayed, so i turned off/on printer again. this time it came back up with no message at all. 8. printer now works
hope this helps and works for ya'll too!
Sep 29, 2008 | HP PSC 750 All-In-One InkJet Printer
Error Msg: Ink Cartridge Installed Wrong
http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu01850&lc=en&cc=nz&dlc=en&product=441115&rule=46212&lang=en
Nov 06, 2007 | HP PSC 1410 All-In-One InkJet Printer
Cartridge error light on
I just recently had the exact same problem. I went to the HP site and went to the Software and Drivers section for software and patches to download. I scrolled to the very bottom and downloaded the one marked "HP Print Cartridge Utility" and installed it. It fixed it in about 5 seconds. I hope that helps! Here's the link I used: http://h10025.www1.hp.com/ewfrf/wc/softwareList?lc=en&cc=us&lang=en&dlc=en&product=374568&os=228
Aug 18, 2006 | HP PSC 1315 All-In-One InkJet Printer
My HP 1315 has printing problems
pull out the cartridge and scrub its point with a simple eraser (common eraser for pencil)and fix again then check
Jul 16, 2006 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1350 All-In-One Thermal Printer Logo
1,683 people viewed this question
Ben Johnson
