Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool washing machine not completing cycle
Our washing machine gets stuck just before the rinse and sometimes we can get it working again. I have taken the yop section off thinking it was the timer except I cant get this off the panel. I just want to know if it is worth fixing? Please help!
  • sue00 May 22, 2008
    The lid switch seems to be fine?
  • Anonymous Mar 30, 2014
    Machine details are Whirlpool Fully Automatic 651 si, 6.5 kgs
  • 117 Answers
Don't gonna be the timer
If your washing machine gets stuck just before the rinse, than its gonna be the lid switch
Posted on May 22, 2008
  • Bob Hawlik
    Bob Hawlik Dec 22, 2013
    can i remove the switch and solder the two wires together?
Make sure your washing machine is on level ground, if the machine is off balance it will stop.
Oct 30, 2013 | Whirlpool Duet GHW9150P Front Load Washer
For some reason my GE GBVH6260 washer cycles are getting hung up on either the wash or rinse cycle. Some days it will stay stuck in the wash cycle & some days it will stay stuck in the rinse cycle for...
Most likely its your water inlet valve..(cold side is not letting water in). Very common problem that usually manifests during rinse cycle since rinse uses always cold water.
According to your model # , part # is WH13X10023
Jul 10, 2017 | Washing Machines
I have a fischer and paykel top loading washing machine for the last few years that that given use excellent service. In the last month when a programme is run the machince gets stuck at the rinse cycle...
Hi dude - is this a replica of the lights - where I put 0 theres no light, 1 is a light ok you follow? on the top is 8 lights from left - right the first 5 is always green, next 2 is orange & last is red! so I will try and see if we are on the same track...
Here goes - 0010 0101 is this what you have? - if yes then the pump is either overheating of severely blocked - more likely to be overheated.
This is how the washer works. it fills, washes then rinses - now pump starts up as machne joggles and agitates to set up for a spin, then final rinse - as it goes to end it does the same as in rinse.
Therefore I tend to think we would be looking at the same lights on your machine - to my illustration -
Keep the chin up - if you need to replace the pump then look up other F&P request or look up my solutions to help you.
Jun 24, 2011 | Fisher and Paykel Washing Machines
Hi, good evening. I have a zanussi iz12 washing machine that stops during rinse node and gives e20 fault (wont drain). I checked the pump - working fine. I've found that if i blow into the waste pipe the...
Hi there
I have an IZ12 jetsystem which sometimes works and other times it starts and then clicks and stops just before the water starts to run in. I usually turn it off and try it again a few hours later and then it starts to work again. Sometimes it is the next day before it will work again. Would anyone know the problem?
Jan 11, 2010 | Zanussi IZ12 Front Load Washer
When I push start nothing happens the lights are on. It stopped mid cycle while trying to rinse could the water be frozen
Switch off the machine completely. Remove all the clothes. May be one of the cloth has got stuck up with the spindle. Wait for sometime. Load again with clothes. Restart the machine and start again new washing cycle Unless you are in cold country and the temperature goes down to freezing temperatures there is no question of water freezing when the machine has been working for sometime unless it is static for a long period
Jan 04, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
DE code on WM0642HW TROMM washing machine We've been getting this error code on our washing machine for some time. The code is coming up quite frequently now. It stops the cycle so the load is not...
HI, this is a Door Open Error.
Possible Causes are..-
* Door not all the way closed
* Loose electrical connections at door switch and pwb assembly(Control Board)
* Door switch assembly is out of order(Miss aligned)
* Gasket on door may be creased in
Most common issue here will be a defective door lock switch. check all causes before replacing the switch.
Jul 11, 2009 | LG Washing Machines
Hotpoint wma46, my machine does't seem to be taking/emptying the condition during the cycle, i have taken the draw out and cleaned it but it still won't work properly any advice ??
Hotpoint wma46 This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question
Jul 08, 2009 | Hotpoint WMA46 Front Load Washer
Kenmore 90 series washer will get stuck in between cycles
Sounds like the timer has failed. It's a common problem.
Part number 8545379, $83.69 from
Feb 04, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool Ultima Wash II Intermittent Rinse/Spin
Hi, the water not drain , the drain pump was stuck , causes are the small linen and other foriegn materials are bind the pump infeller , pump connot completely turn . so drain stuck need to clean , also the drain hose have sedimentation of soap and dust.
Feb 03, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
187 people viewed this question
Dan Webster
Dan Webster
Sal De
