Question about Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
Ice Maker Problem Question
I know you've had a ton of questions on the ice maker, but I haven't really seen this one yet.
We have a Maytag MFI2568AES purchased in mid 2006. It's worked with no problems until this week. The order filter light had come on a couple of weeks ago, so I picked one up to change it when it was time. The filter still didn't indicated to "replace" yet, however our ice maker suddenly stopped making ice completely. No noises from the maker and nothing had been done to the fridge differently.
I changed the filter and ran water through it for a few minutes to make sure no air was in the line. This however did not fix the ice maker problem.
My husband is pretty good at fixing things, we just need to know where to start looking.
Please help.
  • 1 more comment
  • younglass May 31, 2008
    Our 'order filter' had been on until tonight when it changed to 'replace filter'. Now lights are flashing and the ice dispenser was making a lot of noise. Having read messages from some who have another model of the Ice20, I stuffed paper towels in the dispenser and the noise stopped; lights are flashing..replace filter, water, freezer and refrigerator temp lights. Maybe it's the circuit board in the back of the unit.
  • gpamike Sep 01, 2008
    same situation .... same model ... just quit making ice
  • vicalice72 Feb 02, 2009
    have the same ptrouble i get water out of the refrigerator but no ice
  • 45 Answers
Take the ice bin out look in the hole at the ice maker you may have a ice cube stuck between the tines of the ice maker if not look at tines somtimes they get crossed up if not that feel in the ice maker does it have water or ice in the maker? also there is a on off switch on the side of the ice maker make sure it is on, you will also see the white ice level arm you can move it up and down it is about 8 in long make sure it is free to move
Posted on May 22, 2008
  • reeasle Mar 25, 2011
    Thanks for this tip, When i first read it I thought it sounded lame, but the issue was the ice had apparently got bound up and was preventing the full rotation of the arm and the ice cube lever would stay in the put position. After removing the ice maker and cleaning out the stuck ice, it works fine.
Maytag MFI2568AES- ice maker making ice but cannot harvest
Sounds like the thermostat inside the ice maker that allows the heater to come on during harvest cycle is bad. You will need to replace the ice maker.
Ice Maker Kit For Maytag Refrigerator Model Number MFI2568AES
Sep 24, 2015 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag model MFI2568AES not making ice
8869f6a5-d8bf-4729-a06a-b1440ff441bc.jpgThe water dispenser control is only part of the dual water control valve. If water did not refill the empty ice maker tray after dropping ice into the ice bin the=> 67006322 Water Inlet Valve will need to be replaced. Let me know should you have questions, Thanks Sea Breeze
May 25, 2013 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag Fridge MFI2568AES - Ice maker not filling
Check water line going to fridge and ice maker! Does water come out ok?
Jun 17, 2012 | Maytag Refrigerators
Maytag Refrigerator MFI2568AES not cold enough. Hi! Our Refrigerator is working. The inside temp 66 and the Freezer is at 61 degrees. Any ideas? The replace filter light was on (it's time to...
The problem can be temperature not set properly or any of fridge or freezer door not closed properly and cool air is getting leaked out. This are basic possibilities which first needs to be checked. But if this possibilities are checked ok and still the problem is same, then its weak compressor issue. Click the link below for more details:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
And for ice maker problem
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks.Helpmech.
Oct 10, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Ice maker is not working on Mod. MFI2568AES
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Feb 14, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Ice maker not making ice..
heatman101
Oct 16, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Not making ice. dispenses water though
heatman101
Oct 10, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag refrigerator
IF BOTH WATER AND ICE MAKER ARE NOT WORKING YOU MAIN NEED THE MAIN BOARD. THERE IS NO FUSE.
Apr 24, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Mfi2568aes ice maker
it is under warranty call for service
Jun 20, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
445 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
