Kenmore wacher drains but the allows drain water back in after cycle is done.
The washer drains fine, but then after the cycle is done the water left in the drain tube flows back into the washer. I'm not sure what part(s) are needed to order. Any help would be greatly appreciated.
    Problem Solver:
  • 4 Answers
Turns out the washer was fine. The drain pipe running from the house to the city sewer line was clogged causing the water to back up. One call to Roto-Rooter and problem solved.
Posted on May 24, 2008
  • 5,911 Answers
I think your problem could more of a plumbing or installation issue, rather than a problem with your washer. Please refer to the link below for advice on basic washer installation tips.
http://www.fixya.com/support/r389335-basic_washer_installation_tips
You may need to double check your drain line to ensure it is not too long, it is installed at the correct height, and that it has the required air gap to drain properly. Please post back if you have any further questions. I hope you find this information helpful.
Posted on May 22, 2008
I have a Kenmore 80 series washer it will not stop filling with water so it wont go into agitate cycle, help
Has your drain for your washer backed up recently? Or is the drain hose from the washer sealed into the drain pipe, meaning that you can't just lift the hose out anymore? There needs to be air around the drain hose or it will cause the washer to allow water to be siphened threw the drain by not closing the filling valve. This can also happen if your drain is backed up. Rooter the drain out and make sure that the drain hose is not sealed up to the drain pipe and see if that fixes your problem.
Feb 12, 2012 | Kenmore Washing Machines
Washer works fine until it starts filling on the rinse cycle, then the water just flows out of the drain. Last night the water was running for 3 hours, before I realized it. The tub fills fine when it is...
Make sure the drain hose is not sealed to the drain pipe, and that the hose is not shoved into the drain allowing the end of the hose to reach the trap. That will prevent the machine from syphoning out the rinse water as it fills.
Mar 29, 2011 | Washing Machines
F21 clogged hose water left in the washer after spin cycle is done how do I get the hose off the washer and then how do i check if the clog is on the in side
Yoy will need to take off the bottom cover (3 star screws), locate the drain pump at front (the drain hose goes to it). It has a strainer in it which you turn counterclockwise to remove this will allow you to clean it out. Then one of the three tumbling blades inside can be removed to clean out the boot to the drain pump. Good luck!
Jul 05, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore topload washing machine that wont switch to drain
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Then, see the Whirlpool / Kenmore Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Normally, this would appear to be a Lid Switch or Neutral Drain problem BUT since it is re-filling , it sounds like a Timer problem.
See the Service Manual for how to test / replace the timer.
Apr 16, 2010 | Kenmore Washing Machines
I have a Kenmore N2. What would make my front load washer fill back up with some water after the drain and spin cycle is complete?? IF I let the washer go until it's done and go downstairs to take out,...
first, run a rinse,drain & spin cycle. after it finishes filling, shut the water supply (taps) off. If water enters the washer after the drain, it has to be sifoning back in from the DRAIN hose. Check to see if the drain hose is not going up above the washer more than a few inches
Dec 03, 2009 | Kenmore Washing Machines
Kenmore HE3 washer stopped at 11 minutes left in cycle and just hums. Won't drain rest of water or spin out. Help!
Something must be stuck in your pump's impeller and not allowing to spin and send the water down the drain. Remove the rubber boot seal and check the impeller for obstructions. The pump is located at the base of the washer on the right side.
Aug 21, 2009 | Kenmore HE3T Washer
Washer stops after aggatating and wont drain
My Kenmore 70Series washer goes through the wash cycle then just stops when it is to drain and then spin.
Jun 10, 2009 | Whirlpool Washing Machines
Water still in bottom of tub after drain/spin cycle
I removed the drain hose from the bottom left rear corner of the washer & cleaned a large amount of gooey sludge from the bottom of the drain inside the washing machine.
Feb 14, 2009 | Kenmore 12502 Top Load Washer
Kenmore 2 Way Tumble Action Front Load Washer
no thats two different problems. The rubber piece (boot) forms a seal to prevent the water from leaking out, that should be replaced. Water might have leaked and ruined the pump. At the end of all cycles is there still water in the tub? If so your pump is either clogged or has gone bad, and thats why the washer wont go into extract.
Jul 09, 2007 | Kenmore 44102 Front Load Washer
Kenmore Elite Fronloader Water Problem
the water inlet solenoid valve has debris stuck inside of it, thereby not allowing complete "off" mode. best to remove it and clean the water path thoroughly. valve is found by tracing the inlet water hose.
Jun 03, 2007 | Kenmore 46462 Front Load Washer
Washing Machines Logo
76 people viewed this question
Top Washing Machines Experts
