Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Sink hook up
I have the white model what do need to hook it up to the sink and does the water pressure is what makes the sprayers turn
  • 868 Answers
You have to have 120v power supply/Drain (disposal)/Air Gap(breather)/water pipe access / correct space to fit the dishwasher
Posted on May 26, 2008
How to disconnect sprayer hose on kitchen faucet?
Turn off the water supply valves beneath the kitchen sink. Turn on the faucet and squeeze the trigger on the sprayer to empty any water left in the supply lines, faucet and sprayer.
Trace the sprayer hose from the end of the sprayer to where it connects to the faucet. Use pliers to loosen the connector holding the sprayer hose to the faucet.
Remove the sprayer hose from the faucet to expose the male threads. Wipe the threads dry with a towel. Wrap the threads with pipe-joint tape. Twist a 3/8-inch threaded brass flair cap onto the male threads. Use the pliers to tighten the cap.
Reach beneath the sink and loosen the mounting nut securing the sprayer support to the sink or countertop. Use a basin wrench if you are unable to reach the mounting nut with your hand.
Slide the mounting nut off the hose attached to the sprayer beneath the sink. Pull the sprayer support and the sprayer from the hole in the sink or countertop.
Insert a sink hole cover into the hole left by the sprayer. Depending on the style of hole cover, it could snap in, or a mounting nut could hold it in place.
Things You Will Need
  • Pliers
  • Towel
  • Pipe-joint tape
  • 3/8-inch threaded brass flair cap
  • Basin wrench
  • Sink hole cover
Dec 01, 2017 | Plumbing
Frigidaire Model FDB780RCB0 I am getting water in the machine but it seems the arms are not turning what can I do to get that fixed?
The pump in the dishwasher is supposed to provide enough water pressure to turn the spray arms and make them rotate. The pump is faulty and not giving enough pressure or the arms are stuck.
Try spinning the arms, if they rotate smoothly, you will need to replace the pump.
Aug 03, 2008 | Frigidaire Dishwashers
Calcuim build-up in Hansgrohe 06128830 - what is best fix? (CLR Rx done)
It sounds like you have already checked the obvious places at the cartridge and the filter screen at the end of the hose. If you have good flow through the hose with out the sprayer attached I would suggest the blockadge was in the sprayer. If you look into the hand sprayer from the hose connection you will see a yellow ring with a white plastic flap in the middle. This is the first check valve as well as the flow restriction device. This little assembly can be removed [for cleaning] by pushing in on the white plastic part and hooking the yellow ring and simply pulling it straight back and out of the handsprayer. A cork screw or dental pick works well for this. Once removed you will need to hold this little assembly over something other than the sink and unsnap the grey end from the yellow housing. You will most likely find some debris in this little grey end around the spring at the flow restriction device. This is common after a water heater replacement due to the amount of debris stirred up during the flushing process. Once cleaned you will need to reassemble and reinstall the check valve assembly for proper function of the unit. If you need any further help feel free to contact me at Hansgrohe. 1-800-334-0455. Press 2 for tech and ask for David Scarborough. I'll be happy to help.
Feb 08, 2013 | Hansgrohe Plumbing
American Standard Kitchen Faucet Low water flow
I had the same issue with an American Standard faucet that I installed new 6 months ago. The diverter can be the issue if you have a sprayer attachment. Try unscrewing the sprayer head from the hose it's attached to. Now run the water full pressure with the hose pointed into the sink, obviously :~). After running the water for about 1 minute, connect the sprayer head back onto the hose, make certain the flat rubber washer and ring gaskets are seated in their grooves properly, and tighten until you have no water leaking from the sprayer head/hose connection. Now try the water through the faucet. If the problem was a temporary diverter issue, your pressure should be fine now. Good luck
Oct 31, 2011 | American Standard Kitchen Faucet 6310 020...
We have a Delta kitchen faucet with a pullout sprayer everything was fine for over a year then it started making a bang bang rattle sound very loud only when the hot water is on it only does it about ever...
Delta comes with a limited lifetime warranty. call them to get free parts. I believe you will need to check several things. Remove the spray head from the sprayer hose, point the hose into the sink drain and turn the faucet on. If it no longer makes the banging noise, replace the spray head. You need to look for a leaking spray hose under the sink also. If the faucet is making noise, replace the ball and cam assembly under the faucet handle. One other thing that I have run into is that the shut-off valves under the sink can also go bad and cause banging and vibration.
Sep 06, 2010 | Delta Model 470: Signature Kitchen...
Sink sprayer hose makes noise
hello, you may have a air pocket in the line try shutting of the water supply and then sqeeze the handle and slowly turn the water supply back on with the hose handle squeezed on till the air is forced out, hope this helps
Jun 07, 2010 | Moen 87530 Touch Control Single Handle...
New faucet, sprayer hooked up right, no water going into hose?
check the sprayer handle by disconnecting and blowing into it and pressing sprayer handle and/or for possible kink at main body or hose by disconnected sprayer point hose into sink and turn on water. If no water the the diverter in main body is not working properly and needs to be reassembled or replaced
Jul 01, 2009 | Price Pfister Marielle Kitchen Faucet with...
No water flow in kitchen sink
Sorry to say, you will need to replace that faucet, and also when you are shopping for a replacement, inquire about a rosette to cover the hole left by the voided sprayer.
Good luck...
Feb 24, 2009 | Home
Kenmore ultra wash
This could be due to lime deposits from your water or very hard water. If you fill a glass from the sink is it real cloudy? Also it could be due to low pressure from being clogged or if you have galvanized pipes they may be clogging up and causing low water pressure which is not rinsing off the dishes with enough water. To test the water pressure in your house turn one sink on and then turn the other one on. If there is a large drop in pressure this means your pipes may be starting to clog up. If you found this solution helpful please rate it.
Thanks - Tech101
Jun 24, 2008 | Dishwashers
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
