Question about Canon PowerShot SD400 / IXUS 50 Digital Camera
Sd400 powershot camera wont power up. tiny plasic piece came out of battery door. the tab on the door itself seems to be intact.
  • Canon Master
  • 4,738 Answers
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
By the way, do you still have that little plastic piece? It's likely a push-piece that pushes in on a pin switch on the door. If you can find and glue it back exactly where it fell off, your camera just may work again.
Posted on May 23, 2008
Where can take my DSC-W1/W12 Battery door
I have several of these little Sony cameras and had the same problem with the battery door not latching on or locking up. If you want an easy fix, just look for your camera model number on Ebay and some sellers actually sell the complete battery door. You can also buy a For Parts Only camera with the same model number and use the battery door making sure it is intact of course? I doubt you can find or buy a battery door through Sony any more, a repair shop would charge an arm and a leg for such repair and that is if they even have extra parts for a camera that old?
I fixed one of mine by cutting two small pieces of a sewing needle, yes i know it souds corny and all but it worked. What usually breaks on these camera battery doors is 2 small tiny plastic tabs that that latch on to 2 tiny tabs attached to the camera body, when the door tabs break off theres no way the door can lock and so it just hangs open. I decided to measure 2 pieces of metal, more like rods from a needle and heated the tip and pierced through the battery door matching those tabs underneath. You do have to be very patient and careful with this as you don't want to miss the angle where the original tabs use to be. I did fix my camera even though you can see 2 tiny metal rod inserted through the battery door but it held up real good and still working.
Nov 18, 2014 | Sony Cyber-Shot DSC-W1 Digital Camera
Need to replace battery door on canon sd400 camera
I have the exact camera. Spoke with a local camera repair shop. They had to send it back to the factory for the part and installation and am waiting for it to be returned in the mail.
Jan 16, 2012 | Canon PowerShot SD400 / IXUS 50 Digital...
The camera comes on then beeps about 4 times then turns itself off, the lens is out and wont go back in. I have put a new battery in but still wont work
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Sep 28, 2010 | Canon PowerShot SD400 / IXUS 50 Digital...
Canon G3 camera just stopped working completely
Do you have a way to test the battery and you know it's ok?
Those batteries have built-in protection circuitry that can cut out or turn off the battery entirely if it detected a problem like a short circuit, etc. And it may not get over it.
Try a 2nd battery or the AC power adapter directly.
Also check that the 3 little pins in the camera DC input jack are intact, straight, and not touching each other.
Some camera's won't turn on if the memory card door is open or the card is ejected but I tested that on my G3 and it still turns on either way.
Ah.... and lastly... there is a little electrical limit switch connected to the battery cover door that disables the camera if the battery door is open. It gets pressed by a small plastic piece attached to the battery cover when you close the battery door. If the plastic piece or the tiny, recessed switch has an issue then the camera won't turn on The switch could be bypassed internally (not easy to do) if that was the problem.
Look for a tiny, thin, black plastic switch about as thin as a staple down in a recessed hole (slot) near the battery cover hinge. Try gentle pushing the battery closed switch "over" a little. You can tell which way to push by observing how the battery door slides into position as you close it. I was able to turn on my camera with the door open by doing this.
The switch is very tiny, don't break it.
If the battery door isn't closing all the way that would also cause the same issue.
Feb 18, 2010 | Canon PowerShot G3 Digital Camera
I opened up my battery pack, it smelled like smoke
Is your battery pack genuine? Often non-genuine batteries wont charge correctly and have been known to burn or short out. If it is genuine however you should have the camera, charger and battery checked out by Canon for any potential shortages etc. Li-ion batteries can be dangerous to mess around with, be careful when pulling it apart.
Apr 15, 2009 | Canon PowerShot SD400 / IXUS 50 Digital...
Canon Powershot PD630 will not turn on!
Hi
Either the fuse has blown or there is another problem with the main PCB or possibly the battery door indicator switch.
Open the battery door, by the memory card slot is a tiny switch; is the black tab for the switch still there or is it broken off and missing? Is it jammed down? Try holding the switch down with a pencil and press the power button... does it work?
If it doesnt seem to be the switch, it's probably the fuse. If you can solder well you can probably replace it yourself, and I will get the fuses tracked down and listed in the store so they are available to anyone who needs them.. they are cheap!
We are a digital camera repair business, if we can help please let us know! Good luck from Darntoothysam com
Thomas
Darntoothysam com
Oct 29, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Troubleshooting my canon
dust, use some compressed air to shift it. You will get some in a pc accessories store
Aug 16, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Won't Even Turn On
Feb 16, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Powershot sd400 elph,got wet
If you tried turning the camera on while the electronics were still wet, it may be too late to offer any help.
Assuming you do this again, any piece of electronics that is immersed in water may begin to corrode immediately upon exposure to air, and if you don't want to take the chance of corrosion, you should take your camera to a professional repair depot.
Without disassembling the camera and drying out the pieces manually, there's nothing you can do except open every available crevice (lense, battery area, CF memory slot), remove the battery and memory card (which can then be dried CAREFULLY by hand), and hope that all pieces of the camera will eventually dry out (I'd leave it in a dry, warm environment for at least 3-4 days - longer if you can wait).
Nov 30, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
Camara won't come on
It could be the batteries. To be sure about it, try your batteries in another appropriate appliance. Good luck!
Sep 07, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
Canon PowerShot SD400 / IXUS 50 Digital Camera Logo
66 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
