Question about Motorola T5710 (22 Channels) 2-Way Radio
Moto T5710 Disassembly - Transmits Carrier Only. No Modulation.
I'm trying to disassemble my Moto T5710 2-way radio to see if I can repair the Carrier Only/No Modulation problem. Besides the two screws in the bottom part of the battery compartment, where and what other screws/steps do I have to take to open the unit. It appears to be firmly attached at the top and will not come apart.
  • bwilliam May 22, 2008
    Never mind.
    I found I had to pry off the front cover and there I found the other two screws.
    Unfortunately, now that I've opened the unit and done a basic inspection it appears to be completely dead. Batteries check good but now I don't get anything out of the unit. No display, no nothing. This may be a lost cause unless someone has some special "magical" suggestion to offer.
    Scholar:
  • 157 Answers
Hello bwilliam. Batteries can give you a false reading. Check your batteries under load. Good luck.
Posted on Oct 03, 2008
Transmits and receives no modulation out
I am not an expert but I think there can be little or no modulation of the carrier wave unless there is an audio input to the modulator. Like any audio amplifier a transmitter modulator (amplitude modulation) is quiescent without an input.
If the modulation amplifier and audio pre-amp are working and modulating the carrier wave and the antenna is ok then audio modulated radio frequency must be being transmitted.
It would be an extremely good quality CB that had a modulation meter. Mostly all they have is a meter giving an indication of the rf power being sent to the antenna and that rf (radio frequency) power would be the same whether modulated or unmodulated.
The modulation envelope, incidentally, is traditionally viewed or measured with an oscilloscope.
The indicated rf power could be verified using a field strength meter but the only practical way to discover if a standard CB is transmitting modulated rf is to listen to the transmission on a suitable receiver. If the squelch is turned down it will be obvious if the rf carrier wave is being received as the hiss would be silenced. If no audio is received it can be assumed none is being transmitted.
I suggest you try another microphone and lead and if that doesn't work it is clearly a job for a repair shop.
Oct 28, 2015 | Radio Communications
A uniden Madison base station with digital clock that transmits and receives but has no modulation
could be your final , could be the modulation transformer, could be your coax, could be your mic. Hows the SWR . under a 2.0 I hope.the smaller the # the better you get out .
Oct 25, 2015 | Uniden Radio Communications
Why is there no transmit modulation?
'mic gain' adjusted for optimum amount of modulation?
Oct 15, 2015 | Radio Communications
Microphone wiring
the rf power going out is geting inducted on the wires of the mic.try using some ferrites close to the coax on the pl259 connector and on the mic wire itself.
Mar 01, 2014 | Radio Communications
Adjust modulation pot cb
4 watts on am and 12 on ssb the modulation pot isn't going to help you . go to www.cbtricks.com and get the service manual.
Jul 27, 2013 | Galaxy Radios DX-979 40-Channels Base CB...
Uniden grant lt transmit and receives normally but when i key up on AM the AM power regulator gets hot quick i changed out the driver and final and replaced the regulator still does the same thing and it...
Sounds like a "short" if it affects modulation + power. Try to inspect board with magnifier for solder bridges, and bad resistors. Change a few resistors near back with new ones. take out slugs near back finals like L10 or L20's not sure if its same as Uniden Pc68xl. but try that. I found turning L19 up to top gave great Modulation. clip D9, Sread coils 1/16 inch in back. Try to get lower carrier. Carrier does not mean anything much. Modulation is what you need. With less Carrier it may cool down that chip. It may be too wound out.
Mar 26, 2011 | Uniden GRANT LT 2-Way Radio
No modulation with strong carrier
sounds like your Audio Output went out......not audio chip....may be your voltage regulator also....your voltage regulator IC is heat sunk....do you have a schematic?
Jan 23, 2010 | Cobra Radio Communications
Submerged one t5710 unit crossing a river; no longer transmits.
Probably not.
The electronics in the transmit / recieve circuitry (RF = radio frequency) work very differntly from those in the display and control circuits, which prob ablyexplains why the display works, but not the rest.
The major problem with water in RF circuits is that even after it dries out, it leaves a residue, or worse still some corrosion, which adversly affects the tuning of the RF circuits.
It may be worth trying to dry it out a bit more - put it somewhere warm but not humid like near but not too close to a central heating boiler, for a few days. However, I suspect it is now beyond repair.
Oct 07, 2009 | Motorola T5710 (22 Channels) 2-Way Radio
No modulation
Hello Rob55spiral, Most common malfunction in no modulation is the microphone. Swap out with a known working mic. #1 If problem is corrected, aquire a DVM and repair the broken cable connection in your microphone. #2 If still no modulation you have an internal componet malfunction. Please inform me of results.
Jun 27, 2008 | SI-TEX Radio Communications
No AM carrier or modulation. SSB transmits good
what cb is it ? it sounds like your am section is not getting powered up when you switch from ssb to am. If i know the model i may have a diagram of it here and suggest a place to start
May 02, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
Radio Communications Logo
282 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
