Question about GE JVM1490 Convection/Microwave Oven
Shorted capacitor? expensive? worth fixing?
My microwave/convection oven seemed to blow a fuse just as I pressed the start button. The circuit breaker in the cellar did not trip, so I assume it's an internal fuse. You wrote that this is a sign of a shorted high-voltage capacitor. Is that an expensive problem to have fixed (assuming I don't do it myself)? It's a built in unit, and I assume they'll need to access the back.
Thanks,
Julie
  • GE Master
  • 8,973 Answers
On some models, the high voltage capacitor is accessible by just removing the control panel (which is simple) but in other models you have to pull the oven from the wall and take off the outer cover.
If removal from the wall is necessary, I recommend two people for safety. You can find your installation instructions here.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
A typical home visit runs about $75, and the labor to repair the problem usually runs about that, too. Plus parts.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 24, 2008
It blows fuse
Possible there is a short within the circuit.
Please check the following for shorting.
1. Magnetron
2. High voltage Capacitor to the magnetron
3. Transformer
4. Surge filter
5. Electronic panel board.
Get tips from this link. Microwave
Jan 10, 2013 | Whirlpool MH1150XM Convection/Microwave...
My koc-81h4t daewoo microwave convection oven is blowing fuse,i tried to isolate the high voltage area,the griller is working fine,but when im tryin to use the convection,fuse still blows,take note that...
Possible that the high voltage CAPACITOR or the transformer is short. So you need to isolate the total HT circuit to confirm , if the connection to the magnetron was removed.
Also check for any short on the surger protector at the front end of the supply.
Jul 27, 2011 | Microwave Ovens
Hi, my microwave fuse blows when start button is pressed
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!any capacitors are discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Mar 10, 2011 | LG LMVM2055 Convection/Microwave Oven
Panasonic dimension 4 microwave/convection oven Micvrowave part of oven not working, convection oven/grill fine. Is it a problem with the magnetron? Is there some form of internal fuse?
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Dec 31, 2010 | Panasonic NN-C980 Convection/Microwave...
Microwave blows fuse in microwave mode grill function ok
It is most likely the capacitor has shorted or the rectifier has shorted. Check with ohmeter, but make sure it is discharged first by shorting the capacitor with a wire.
May 21, 2010 | GE Advantium 120 Convection/Microwave Oven
I have a sharp microwave / convection oven i would like to repair because it's from my motorhome and fits the hole for it nicely. it's a model R-8160. the convection part works and the microwave blows the...
When you press the Start pad to begin microwaving:
- does the fuse blow immediately or almost immediately?
That would be a shorted high voltage capacitor.
- does the fuse blow a few or several seconds later?
That would probably be a shorting high voltage transformer, or possibly the magnetron.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/xformer.html
http://www.gallawa.com/microtech/mag_test.html
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
We have the service manual, so let us know if you need more help.
Otherwise...
Jul 30, 2009 | Microwave Ovens
Microwave blowing fuses when setting programme
suspect high tension diode or bleed diode faulty. easy to replace but!!!!!!!!!!!!!!!!!!
BE CAREFUL. THERE ARE VERY HIGH VOLTAGES PRESENT IN A MICROWAVE. YOU MUST SHORT CIRCUIT THE CAPACITOR WITH A GOOD QUALITY SCREWDRIVER IE GOOD INSULATION. VOLTAGE CAN BE UP TO 1500 VOLTS AND IT CAN KILL.
IF YOU ARE NOT SURE WHAT TO DO, GET SOMEBODY IN
Jul 05, 2008 | Neff H7871N2GB Convection / Microwave Oven
My microwave/convection oven blew a fuse. replaced it and the convection works but when I try to use the microwave it blows the fuse again. what needs to be fixed?
Typically, when the fuse blows in the microwave, the high voltage capacitor fails and becomes shorted.
The door switches are also configured in such a way that if tampered with (in this case, failed switch or latch) the fuse will also blow. Check the capacitor first.
If you need further assistance let me know
Regards,
reg501
The FixYa Team
Jun 19, 2008 | Microwave Ovens
Microwave keeps blowing fuse
If it blows the fuse as soon as you hit the START button, it's almost certainly a shorted high-voltage capacitor.
If it blows a few seconds after you hit the START button, it's probably the high-voltage transformer. You'll possibly also smell a faint electrical burning smell from the rear vent after you shut if off.
If it blows the fuse as soon as it's plugged in, you probably have a shorted door switch, a shorted varistor, or an internally exposed wire shorting to the chassis, etc.
Nov 19, 2007 | Microwave Ovens
Unit Electrical Problem
Microwave can be very dangerous so it is best to have it looked by a professional
Would appreciate a solved rating for expert advise.
Oct 16, 2007 | GE JE1590 Convection / Microwave Oven
GE JVM1490 Convection/Microwave Oven Logo
82 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
