Question about Sony Handycam DCR-SR42 Camcorder
Recharging in Australia
Will I have problems using and recharging in Australia if I buy this camera from USA.
and is the NPFH70 battery the one for this camera
  • cats100 May 22, 2008
    I live in Australia
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 480 Answers
Hey cats100,
You should not have a problem using the included charger since it is rated to 240v, but you will probably have to purchase a plug converter. According to the manufacturer the battery that should be used for this camcorder is model # NP-FH40. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Posted on May 23, 2008
Why is my nikon coolpix L20 battery exhausted even with new batteries
If you are using rechargeable batteries, It could be that your camera's battery charger circuit is defective. If your camera is out of warranty, the cheap solution would be to buy an external charger. Another possibility is that a short circuit or defective electronic component is drawing excessive current and draining your batteries. If that is the case, you will need to have your camera repaired. Nikon USA Repair Depot's number is 1-800-645-6687 9AM-8PM EST, Monday to Friday. They will tell you how to return your camera for repair and they will give you a free estimate if it is out of warranty.
Sep 01, 2014 | Nikon COOLPIX L20 Digital Camera
L26 won't turn on
First, I would check your batteries. Start by removing them and making sure that the battery contacts in the camera and on the batteries are clean. If they are dirty. A new pencil eraser can be rubbed against the contacts to remove any oils or residue. Next, I would make sure your batteries are charged. A quick way is to check is to take them out and put them in another device that takes two AA batteries and see if it works. If the batteries are bad, put two new alkaline (non-rechargeable) batteries in your camera to see if it powers up. If it does and you wish to use those batteries, be sure to go into your menu and set the camera to use alkaline batteries because there voltage output is slightly different from rechargeable batteries . Remember that you cannot recharge those batteries and trying to do so can damage your charger and cause the batteries to explode. If the camera will not power up with new batteries, the camera will need to be sent in to Nikon USA for repair (see the Nikon website for information). If the camera powers up with the substitute batteries, either your rechargeable batteries have gone bad or you camera's battery charger is defective. For problems with the internal charger, it is probably more cost effective to buy an external battery charger then to send the camera in for repair unless your camera is still under warranty. External battery chargers are available for under $20. There is one other possible cause of battery failure. If the camera's internal circuitry has an electrical problem, especially a short circuit, the camera will draw excessive current from the batteries and run them down. If that is the case, you would obviously need to send your camera in for repair.
Jun 23, 2014 | Nikon COOLPIX Cameras
Why battery exhausted can not charge
This is my standard response to your type of question. It covers all the possibilities:
First, I would check your batteries. Start by removing them and making sure that the battery contacts in the camera and on the batteries are clean. If they are dirty. A new pencil eraser can be rubbed against the contacts to remove any oils or residue. Next, I would make sure your batteries are charged. A quick way is to check is to take them out and put them in another device that takes two AA batteries and see if it works. If the batteries are bad, put two new alkaline (non-rechargeable) batteries in your camera to see if it powers up. If it does and you wish to use those batteries, be sure to go into your menu and set the camera to use alkaline batteries because there voltage output is slightly different from rechargeable batteries. Remember that you cannot recharge those batteries and trying to do so can damage your charger and cause the batteries to explode. If the camera will not power up with new batteries, the camera will need to be sent in to Nikon USA for repair (see the Nikon website for information). If the camera powers up with the substitute batteries, either your rechargeable batteries have gone bad or you camera's battery charger is defective. For problems with the internal charger, it is probably more cost effective to buy an external battery charger then to send the camera in for repair unless your camera is still under warranty. External battery chargers are available for under $20. There is one other possible cause of battery failure. If the camera's internal circuitry has an electrical problem, especially a short circuit, the camera will draw excessive current from the batteries and run them down. If that is the case, you would obviously need to send your camera in for repair.
Jun 16, 2014 | Nikon Coolpix S4000 Digital Camera
Nikon coolpix p520 will not switch on
The most common cause of your problem is either a power problem or a functional problem with the camera. If the following does not work, you need to send your camera to Nikon USA for repair because it is not the power:
Jun 15, 2014 | Nikon Cameras
Medion md85099 Why does it show Battery exhausted with new battery in?
I cannot find the L23 on Nikon's website, so I have no idea if it uses AA batteries or a battery module, but here are some general suggestions for troubleshooting your problem:
Apr 27, 2014 | Nikon Coolpix L23 10MP Black Digital...
Won't charge
First, I would check your batteries. Start by removing them and making sure that the battery contacts in the camera and on the batteries are clean. If they are dirty. A new pencil eraser can be rubbed against the contacts to remove any oils or residue. Next, I would make sure your batteries are charged. Since you did not state which model Coolpix camera you have, I do not know if your camera uses AA batteries or a battery pack. If it uses AA batteries, a quick way is to check is to take them out and put them in another device that takes two AA batteries and see if it works. If the batteries are bad, put two new alkaline (non-rechargeable) batteries in your camera to see if it powers up. If it does and you wish to use those batteries, be sure to go into your menu and set the camera to use alkaline batteries because there voltage output is slightly different from rechargeable batteries . Remember that you cannot recharge those batteries and trying to do so can damage your charger and cause the batteries to explode. If your camera uses a battery pack, I would buy an external charger from Nikon. They are inexpensive and if it turns out that the charging circuit in you camera is defective, it will save you a repair bill by providing you with an alternative means for charging your batteries. If the camera will not power up with new batteries, the camera will need to be sent in to Nikon USA for repair (see the Nikon website for information). If the camera powers up with the substitute batteries, either your rechargeable batteries have gone bad or you camera's battery charger is defective. For problems with the internal charger, it is probably more cost effective to buy an external battery charger then to send the camera in for repair unless your camera is still under warranty. External battery chargers are available for under $20. There is one other possible cause of battery failure. If the camera's internal circuitry has an electrical problem, especially a short circuit, the camera will draw excessive current from the batteries and run them down. If that is the case, you would obviously need to send your camera in for repair.
Jan 30, 2014 | Nikon COOLPIX Cameras
Hi, Can I use rechargeable lithium-ion batteries in my Fuji S1730 camera. Thank you. Roy.
Hi Roy,
If your camera uses normal AA or AAA batteries you will have no problems with the rechargeable batteries. If you are considering to buy rechargeable batteries always try to buy the higher mAh range batteries. The higher the mAh the longer battery power will last.
Feel free to share if this solved your question!
Regards
Nov 29, 2010 | Cameras
I just charged my camera's batteries and an error
Your camera is telling you that the batteries have insufficient power. First thing to check is that the battery contacts on both the batteries and inside the camera are bright, clean and free of grease or oil.
Assuming that you're using the original NiMH rechargeable batteries which came with the camera, then you almost certainly need to replace them with new ones as they cannot be reused indefinitely.
To test whether the problem is with your rechargeables or with your camera is very easy. Just buy a set good quality, non rechargeable, alkaline (e.g. Duracell) AA batteries. If the problem disappears then you know that you need to buy new rechargeable NiMH batteries next time.
There is also a small possibility that you have a faulty recharger but it's unlikely. The only way to test it without special tools is to try getting your NiMH batteries charged in a borrowed recharger. If the batteries get fully charged then the error message on your camera will vanish and you'll need to buy a new recharger. Just make sure that the charger is designed for NiMH though or you will damage your batteries and possibly the charger.
Jan 15, 2010 | Canon PowerShot A560 Digital Camera
Sp 350 battery
It Needs a Lithium battery- only lithiums have the density to cope with the demand - no need to buy expensive Olympus Originals
Try www.sevendayshop.com for starters
Plenty  of sellers out there.
Oct 14, 2007 | Olympus SP-350 Digital Camera
Sony Handycam  DCR-SR42 Camcorder Logo
32 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
