Question about Toshiba 61H70 61" Rear Projection Television
Toshiba 61H70 Weird Convergence Issue?
I recently inherited a Toshiba 61H70 with issues.
When first turned on, it does all sorts of strange things. The picture will look reasonably normal, then the convergence will go totally nuts like a "hall of mirrors" with each color warping in different ways, then it will blur and get lines on it like the old TV's when the vertical sync knob was turned all the way.
After 5-10 minutes, the TV settles down, and everything looks perfect except for a warping of the blue convergence near the bottom right corner of the screen.
Occasionally, while the TV is warming up, it will just shut down and flash the light on the front panel. It won't power back on. If I unplug the TV for 20 seconds and then plug it back it, the TV powers right back up.
The people who previously had this TV had the convergence IC's replaced in it a little over a year ago. They claimed that it solved the problem they had then, but that the problem seemed to come back as of late.
I assume that the convergence IC's will need to be replaced, but is there any other advice you could give me to prevent these IC's from going bad again? Are there any other things I should look for besides bad convergence IC's?
Thanks!
  • Toshiba Master
  • 8,617 Answers
They may have gotten some cheap convergence ICs, thats a real possibility. I would recommend switching the two origional STK392-110 with some STK392-150 they will run alot cooler and last alot longer. Just use a good coating of heat sink compound on the back of the ICs. I will post a link where you can get top quality Convergence ICs and they provide free instalation instructions with pictures so you can do the job yourself in under an hour and save quite a bit of money. Heres the link.
http://servicemanuals.vstore.ca/
Posted on May 22, 2008
Tip
Toshiba 61H70 Service Manual Download
Download Toshiba 61H70 Projection Television Service Manual
Models: 50HX70 / 55HX70 / 61HX70 / 55H70 / 61H70
Have you misplaced your Toshiba 61H70 Projection Television Service Manual?
Would you like a digital, searchable, pdf version of the Toshiba 61H70 Projection Television Service Guide?
Follow this link
(& click FREE) to download a pdf version of the Toshiba 61H70 Projection Television troubleshooting & repair instructions.
I hope that helps.
_______________________________________________
Toshiba 61H70 Manual Download
on May 10, 2010 | Televison & Video
Tip
Download Toshiba 61H70 Projection Television Manual
Have you misplaced your Toshiba 61H70 Projection Television Owners Manual?
Would you like a digital, searchable, pdf version of the Toshiba 61H70 Projection Television User Guide?
Follow this link (& click FREE) to download a pdf version of the Toshiba 61H70 Projection Television instructions.
I hope that helps.
Colors out of focus- like a really bad 3-d movie
the convergence issue can be usually repaired by replaceing both of the STK392-110 Convergence amps and the six 1.2 ohm 2 watt resistors. You can get replacement parts at the following link with instructions on how to replace the ICs.
May 21, 2009 | Toshiba 61H70 61" Rear Projection...
Tip
Follow this link
I hope that helps.
on May 10, 2010 | Toshiba 61H70 61" Rear Projection...
Tip
I hope that helps.
Toshiba 61H70
Does it look like a 3D image?
Would you be able to post a picture of the TV with the mention lines?
Aug 16, 2008 | Toshiba 61H70 61" Rear Projection...
Convergence when hooked to HDTV
Your set needs to be realigned in each format, then settings saved
May 06, 2008 | Toshiba 61H70 61" Rear Projection...
Possible convergence problem
You could replace it yourself. I had it done recently and the local repair shop charge $400 to do it (including cost of the chip).
Jan 30, 2008 | Toshiba TP50H50 50" Rear Projection...
Toshiba 61H70 61" Rear Projection Television Logo
223 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
