Question about Dryers
Frigidaire electric washer dryer combo
I have a frigidaire w/d combo (electric) that the dryer doesn't heat. It works but I have to keep restarting the dryer. I have a simple booklet on ti. It said maybe a fuse is blown, but I dont know where a fuse would be.
  • 45 Answers
I am asuming that when you say it works you mean it runs but not with heat? the thermo fuse is behind the back panel of the dryer the unit needs tobe pulled out to get to the back, you should see a bigger black thermostat next to a smaller thermo fuse, you can just jump the thermo fuse to see if that is your problem. it is not a fuse like you think of in your home.
Posted on May 22, 2008
Why would a frigidaire flse60rgs1 combo dryer runs but not heat and washer not start?
check out house breaker and could be heating element problem or thermostat issues ,not enough info for more respond .
May 18, 2014 | Washing Machines
What could it be
Hello Reese,
I see that you're having a Problem with your Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer. I see that the washer will not work until dryer is turned on and the dryer will not heat. I would recommend giving the appliance a hard reset. You will do this by either unplugging it or switching the circuit breaker off that the appliance is attached to. When you do this you will want to leave it off for 3-5 minutes. Once the 3-5 minutes has elapsed, bring power back on and try to restart it. If you are still having trouble with the washer not working until dryer is turned on and the dryer will not heat. I would suggest contacting your local authorized technician to diagnose and see why you keep receiving this error code.
-Best Regards-
Jan 20, 2014 | Frigidaire GLEH1642DS Front Load Stacked...
I have a stackable Frigidaire washer/dryer combo and the problem is that when you push the start button, you hear an electrical buzzing but the dryer won't start. When you take the panel off it st
Hello Mike Brady - From what you have described it seems like the dryer is experiencing a wiring failure or a communication error with the control board. Contact a professional to move forward accurately.
Jan 08, 2013 | Frigidaire FEX831CS Top Load Stacked...
Open ground at dryer outlet
Hi robert_cr334
Go to the following webpage and see that you have the wiring correctly
Bud
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Oct 15, 2012 | Frigidaire Dryers
Frigidaire dryer model fern7800ds0 doesn't heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 14, 2011 | Frigidaire Electric Dryer
Is there a reset button on Frigidaire stackable washer/dryer combo. Dryer will not come on, washer works fine. thanks
Sorry to read about your problem.
Sorry no reset switch.Their is a 80% chance you have a defective heat coil or coils. or the heat selector switch is defective. in addition you may have a clogged dryer vent.
I suggest you place a call to a service company.
I tried to help you. Please help me and vote/rate this response thanks.
If you live in Denver area, I can help you.
Dec 25, 2010 | Frigidaire Washing Machines
Wire Scraping sound and sparks inside rear dryer drum area.
Probably the rear bearing has failed and caused the drum to rub against the heating element. Hey, is this the guy that said he heard a noise last month? LOL
Feb 01, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
114 people viewed this question
Top Dryers Experts
