Question about HP Compaq nw8440 Notebook
Hd for hp nw8000 laptop. pn:345855-001
Can I buy a new "plug and play" hard drive (pn 345855-001) with windows XP installed and ready to go??? How much???
    Brigadier General:
  • 6,966 Answers
To my knowledge, unfortunately no. The hard drive would be blank and often would have to be formatted prior to initial usage. Thereafter, it would be necessary to install the Operating System (in your case Windows XP). Often manufacturers would package with their laptops recovery CD(s) that may be used just for this purpose. Alternately, you can use an OEM Windows XP installer and use the key/serial number printed on a sticker normally found underneath laptops. Incidentally, you are not limited to the 60Gb specs of the 345855-001 (original P/N), you can at your option choose a bigger size HD, say 160 or higher Gb, and can be bought from most computer parts store not necessarily from HP/Compaq. The only stipulation is that the new HD should be ATA-6 IDE, 2.5-inch form factor (9.5mm height), 7,200 RPM.
Hope this be of initial help/idea. Pls post back how things turned up or should you
need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 22, 2008
  • 207 Answers
Yes u can it depends upon the size of the hdd
it starts from the price range of 80$ go bestbuy
I have a old gateway pc and I would like to install a Hard Drive from a Dell pc into it. Can it be done?
Swapping the hard drive from the Dell into the Gateway will not work because the Dell hard drive has been installed with Dell specific drivers and configurations.
When you install the Dell hard drive into the Gateway you need to wipe the hard drive and install a fresh copy Windows XP onto this hard drive and the Gateway device drivers etc.
Oct 29, 2012 | Computers & Internet
My old hard drive on my COMPAQ PRESARIO C306US died, after I replaced the drive I tried reloading windows XP and I get an error that the hard drive could not be found. I loaded Ubuntu and it recognized the...
check the HD if its properly inserted,if the old one is working before then the new one you bought my be a damage one. try to replace another HD to see if which HD is working or not.
Jun 06, 2011 | HP Compaq Presario C306US Notebook
I have a HP G7-250CA in which the Hard disk crashed during a bios update. I have put in a new hard drive and now want to do a fresh install of Windows XP as I do not have the recovery disks. I keep...
can you please explain to us how the hard drive crashed during a bios update ?
or how do you know that the hard drive crashed during bios update
many thanks
And did you try to reinstall windows while original hard drive was still in the laptop
did you press the F11 key as soon as you pressed the power on key
Mar 07, 2011 | HP G70-250us Notebook
Not able to play mkv and other hd formats video in my hp laptop
For these format play on computers, you need to download Media Player Classic and install.
to download MPC click HERE
Hope this helps
Jan 31, 2011 | HP Compaq nw8000 Notebook
When i plug in my seagate 1tb hard drive the light on the HD comes on and my computer makes the du dut sound like it always does when i connect my 8gb flash drive but is not showing up in "My...
right click my computer, select properties, and locate the hardware button. pull up the list of all installed hardware and look for anything that has a yellow exclamation point next to it. right click and select update drivers
Dec 26, 2010 | Computers & Internet
Have a HP SR1010V, 33GB HD - XP Home. Want to 1) replace HD with a 100-200GB HD OR 2) ADD a 100-200GB HD and 3) ADD a DVD drive. What is best way to copy data to a new HD and to boot the new HD. Rather...
The easiest route would be to install the new hard drive in place of the old hard drive and place the old hard drive below the new hard drive and make it a secondary hard drive or slave drive. Once you have them installed this way you can install Windows XP Home to the new hard drive once you have it installed to the hard drive then you can copy everything from your old hard drive to the new one. Once you have everything copied from the old hard drive you can then format it within Windows to have 33GBs of space to store anything you wish. If you need more detailed instructions don't hesitate to reply.
May 19, 2010 | HP Compaq Presario SR1010V (568656) PC...
Hd may be corrupted
Yes, definitely you can buy replace with any 2.5" laptop hard disk make sure that you buy HD with correct interface, if you old HD is IDE then buy IDE hard disk , elsei if SATA buiy SATA harddisk
Sep 13, 2009 | Dell Latitude D600 Notebook
Crashed hard drive
You have to reinstall Operating System again as it seems to me that Ur system files got corrupted ,So it is better u format c: drive and install Windows again..
Dec 11, 2008 | Dell Inspiron 2650 Notebook
HP Compac NX5000 wont load XP Home on new hard drive
This situation leads me to believe that the CD or DVD drive is faulty,,or the install disc you are using is scratched or dirty.
Try cleaning the disc and begin again.
Another option is to take the hard drive out and using a 2.5 to 3.5 inch HD adapter ,,plug into a desktop PC as a slave.
And copy your WinXp cd onto a partition on your laptop HD.
Then using a Win98Se floppy boot disc you can access the winXP and install from there.
Nov 12, 2008 | HP Compaq nx5000 Notebook
Files copy errors during the XP installation process are often an indication of BAD RAM.
If you have dual RAM modules, try install with 1 memory module installed
May 19, 2008 | HP Compaq Presario SR1350NX (PP196AA#ABA)...
HP Compaq nw8440 Notebook Logo
75 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
