Red , Green And Blue.
Thanks for responding so quickly before. I installed 2 new IC's to my Phillips projection TV, adjusted the convergence successfully, but now I have a different problem. All the people are green. They look angry, lol. So i went to the back of the set just above the boards, There's a small black box with 6 knobs. 3 for focus and 3 more, one for each of the colors. I tried adjusting using the 3 color knobs, but I just kept getting either too much blue, red or too much green. When i decreased the color levels, it was too dark. And when I thought it looked just right, the peoples' lips are purple. indicating that some coloring is still off. Please help. Thanks alot.
  • Nelson
    Nelson May 22, 2008
    Thanks a lot. I'll try that tomorrow afternoon.
  • 8,617 Answers
Heres the best way to set a phillips screen controls. Go into the picture controls and set picture or contrast to roughly 75%, then set brightness to 50% and then set the color level completely off. Then adjust the screen with the 3 color controls untill you recieve the best black and white picture as possible. If you are unable to achieve a good black and white picture change the coolant in the green and blue tubes. But if you can get a good black and white picture stop there then turn your color level back up and the picture should be correct. Let me know if you need further assistance.
Posted on May 22, 2008
My set is 10 yrs old. In the upper left and lower
Try adjusting the convergence. If it won't move see below- red IC in particular
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Oct 18, 2009 | Sony KP-43HT20 43" Rear Projection...
The Screen looks 3D & Colors don't line up on my big screen????
If the convergence is off more than 1/2 inch or so you can't adjust. you have a failure of hardware. most likely the output IC. This set has 2 outputs for convergence. Each output contains 3 circuits, Six circuits altogether 2 red ,2 blue and 2 green. The normal customer adjustment will only alow adjustment of blue and red. They should be converged onto the green. There is a much more complex adjustment in the service mode for Geometry and convergence. These adjustments are only needed when you replace a failed componnent like the output ic. These ICs have been upgraded several times since the production of this set. The latest and most powerfull version is STK394-160. If feel up to it I suggest changing both outputs and the corresponding output resistors. Then do a complete geometry and convergence alignment.
Apr 16, 2009 | Hitachi 50UX57B 50" Rear Projection...
Hitachi Television
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Feb 18, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Phillips 60pp9202/17f projection convergence
what about blue? this is an indication that maybe one of the convergence ic have failed. generally you replace both. falure of the ic can also be sympton of other problems.. The oputput ic resistors. the covergence power fuses. but the first step is to replace the ics
Nov 03, 2008 | Philips 60PP9202 60" Rear Projection...
Convergence
If the red isnt responding via the remote you will need to replace the STK392-110 Ics as the service menu adjustment will not correct it 100% due to the IC being faulty and the red and half the green is controlled by one IC and the blue and other half of green is controlled by the second IC so without changing both ICs the set will progressively get worse. Both ICs are stk392-110. You can get replacements at the following link along with instalation instructions
http://servicemanuals.vstore.ca/
Jul 13, 2008 | Toshiba 55H70 55" Rear Projection...
Need the correct convergence IC number for my Phillips Phillips Magnavox rear projection tv P6034C. I am getting the double picture syndrome . It also appears as if I cannot adjust the red convergence...
Thats not the full model number should be something like 43P6034C or etc. Please respond to this same post and I will let you know the correct Ics and resistors because phillips / magnavox will always burn at least 2 often 4 of the convergence resistors as well.
Jun 26, 2008 | Televison & Video
Phillips rear projection tv model #60pp9202/17f
  • Screen looks 3D
Feb 25, 2008 | Philips 60PP9202 60" Rear Projection...
Converging green?
jaymz, you can`t move the green, the green tube is always mounted in the middle and is not adjustable from the convergence menu. red & blue should be converged one at a time on top of the green, once you have accomplished this the crosshatch grid will be white and that means your done :)
Nov 30, 2007 | Philips 43PP9202 43" Rear Projection...
Convergence problem
Blue convergence IC is bad! Blue CRT OK!
Required for repair---pull chassis,replace STK392-110 X 2.
Re-assemble,adjust convergence as needed.
Oct 12, 2007 | Toshiba 57H82 57" Rear Projection...
JVC 56wp30 convergence
Your TV most likely a convergence failure. ( common problem )
  • Screen looks 3D
Here are some photos of convergence problems.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jul 30, 2007 | JVC AV-56WP30 56" Rear Projection...
Televison & Video Logo
256 people viewed this question
Top Televison & Video Experts
Electro Med Services...
