Question about Canon PIXMA MX310 All-In-One Printer
Time and Date set
How do I set the current date and time on my MX310? Thanks for help.
  • 2,039 Answers
1. Press the FAX button
2. Press the MENU button
3. Press (left or right) arrow until you see USER SETTINGS
4. Press OK button twice
5. Use the number buttons to enter the date and the time (in 24 hour format)
6. Press the STOP/RESET button to exit
Posted on May 22, 2008
Need to change date and time on my Dell pc laptop
Save the time and date in BIOS. Replace the CMOS battery if it still does not save.
Jan 09, 2013 | Dell GX745 Refurbished Desktop PC
How do you set the date and time on an Android epad
Its pretty easy. Just follow these steps:
- On your Android phone tap Settings.
- In Settings tap Date and Time.
- If you have the box next to Automatic checked the cellular network will handle the time.
- If not you can set the date yourself.
- Tap Select time zone to find and select the time zone you're in.
- Tap your selection and you're done.
Mar 12, 2011 | Computers & Internet
How can i change directly the time and date because i already update my time setting but when i received message the time and date was not the same for my time settings.
Select your time zone... from your date and time settings. Like countries you were at and adjust the current time. Thanks
Jan 08, 2011 | Nokia 2690 Cell Phone
How do you clear memory, and set date and time 712c
To delete all the records :
  1. Press the MEMORY button
  2. And while holding the MEMORY and the START/STOP button simultaneously for more than 2 seconds all records will be deleted.
To set date/time :
  1. Press the Date/Time Setting button to adjust the date and time (the year flashes on the display)
  2. Press the MEMORY button to advance by increaments of one year and press the Date/Time Setting button,
  3. Press the MEMORY button to advance by increaments of one month and press the Date/Time Setting button,
  4. Press the MEMORY button to set the current day and press the Date/Time Setting button,
  5. Press the MEMORY button to set the current hour and press the Date/Time Setting button (the time is set using AM/PM)
  6. And finally, press the MEMORY button to set the current minute and press the Date/Time Setting button.
Jun 14, 2010 | Omron Healthcare Omron Hem-712c 712 Blood...
Current time and date samsung tocco lite
On the main menu select Settings, then Time & Date.
Set Time zone updating to Manual.
Then SCROLL down i.e. drag the menu upwards (this is the bit that many don't realise.)
Then you will be able to set the time & date.
Sep 20, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
How do i set the time on my nokia 2630
Select Menu > Settings > Date and time. Select Date and time settings to set the date and time. Select Date and time format settings to set the formats for date and time. Select Auto-update of date & time (network service) to set the phone to update the time and date automatically according to the current time zone. Hope it helped...
Aug 05, 2009 | Nokia 2630 Cellular Phone
How reset time?
Set the date and time
You can set the date and time from the control panel. When a fax is transmitted, the
current date and time are printed along with the fax header. The date and time format
is based on the language and country/region setting.
Note If your HP all-in-one loses power, you will need to reset the date and time.
1 Press Setup.
2 Press 4, and then press 1.
This selects Basic Fax Setup and then selects Date and Time.
3 Enter the month, day, and year by pressing the appropriate numbers on the
keypad. Depending on your country/region setting, you might enter the date in a
different order.
The underline cursor is presented initially beneath the first digit; it automatically
advances to the next digit when you press a button. The time prompt
automatically appears after you enter the last digit of the date.
4 Enter the hours and minutes.
5 If your time is displayed in the 12-hour format, press 1 for AM, or 2 for PM.
The new date and time settings appear on the control panel display.
Regards...
May 27, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Ge model 27909 answering machine gives wrong time on playback
I found it on the manual, it was in programming section!
Date/Time
NOTE: Time set on handset will be transferred to the base unit automatically.
1. Make sure your phone is OFF (not in talk mode).
2. Press the menu button to go to the main menu and use cid/vol (3or4) button to scroll to Date/Time.
3. Press menu button to enter the menu. Year 2006 shows in the display.
4. Use the touch-tone pad to enter the last two digits of the current year (range: 00 to 99).
5. Press menu button to save the year setting and proceed to date setting.
6. Date 01/01 shows in the display. Use the touch-tone pad to enter two digits for current month and day respectively.
7. Press menu button to save the month/date setting and proceed to time setting.
8. Time 12:01p shows in the display. Use the touch-tone pad to enter four digits for current time and use cid/vol (3or4) button to toggle between "p" (pm) and "a" (am).
9. Press menu button to save the setting. Saved shows in the display.
NOTE: If you subscribe to Caller ID service, the current date/time is set automatically when you receive your first CID record and will override manually set date/time.
Jan 08, 2009 | GE Lands Phones
How do you set the date on an LG KS360
http://www.o2.co.uk/deviceinfo/device-pdfs/lgks360eng.pdf
Manual
Hope it helps.
Most cell phones get the info from the provider based on your triangulation.
It is in the Settings Menu.
Under DATE & TIME
More detailed Instructions....
Changing your date & time
You can set functions relating to the date
and time.
1 Press Menu or and select Settings.
2 Select Date & Time and choose from the
list below:
Set date - You can enter the current date.
Date format - You can set the date format.
(YYYY/MM/DD, DD/MM/YYYY, MM/DD/YYYY)
Set time - You can enter the current time.
Time format - You can set the time format to
either 24 hours or 12 hours.
Auto update - Select On, the phone will
automatically update the date and time.
Jan 03, 2009 | Cell Phones
Disable Calendar
The Settings menu provides you with various setting
options to customise the phone to your preferences
and needs. You can also reset the settings to their
default values.
To access this menu, press <Menu> in Idle mode and
select Settings.
Time and date (Menu 9.1)
Use this menu to set the current time and date on
your phone.
Home zone: set the home time zone. Select the
city that corresponds to your home zone. To set
daylight saving time, select Set daylight saving
time
Time: enter the current time.
AM/PM: select AM or PM in 12-hour time format.
Time format: select the time format.
Date: enter the current date.
Date format: select the date format.
Auto update: activate the auto time update
feature. Your phone will read the MCC (Mobile
Country Code) from the network and automatically
update the current time for the country that you
are in when you travel abroad.
Feb 20, 2008 | Samsung SGH-D900 Cellular Phone
Canon PIXMA MX310 All-In-One Printer Logo
354 people viewed this question
old marine
old marine
