Question about Ricoh Aficio AP3800C Laser Printer
Ricoh Copier C3500 error sc553
How can I reset the machine
Dirty toner on paper top after printed
Posted on May 27, 2008
Error sc553
check your fuser for paper wrapped around it - if so remove it - if not check the thermistors for toner on them - do sc reset and should be fine
Sep 27, 2013 | Ricoh Aficio 2018D All-In-One Laser...
Error code sc553
lower pressure roller heating problem replace fuser assy and reset code or have tech come out
Apr 02, 2013 | Ricoh Toner for Aficio MPC2800, MPC3300,...
Ricoh MP 2050 / Error SC 553
SC553 means an overheat error on the pressure roller, but this RTB corrects this to an overheat error on the heating roller. As a solution the heating roller thermistor should be replaced or the connections of this thermistor are faulty.
Sep 05, 2011 | Ricoh Office Equipment & Supplies
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
Code SC553
Heating problem, change your fusing thermistors, or power supply unit
Jul 06, 2011 | Ricoh Aficio 450 Copier
Ricoh DX4640PD priport machine with SC556 code - what is this, I can't get past it to open the drum unit or anything? Thanks
And how about error code SC553?i try log in test mode and use program clear mermory.the machine still code SC553
Apr 04, 2011 | Ricoh Priport VT6000 Copier
Ricoh Aficio MP C3500 Error Code SC529
It would help to know the code. Like SCxxx.
Mar 26, 2009 | Ricoh Aficio MP1600SPF Copier
What is the sulution for e541 copier machine ricoh 5832
SC 541 indicates a problem with the heating unit thermistor in the machine.
This type of inquiry requires service support from your local authorized dealer or original point of purchase. This type of service code can not be reset by the user for safety reasons.
Feb 23, 2009 | Ricoh Office Equipment & Supplies
Ricoh Aficio AP3800C Laser Printer Logo
1,473 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
