Question about GPX MW3836 MP3 Player
Downloading WE downloaded songs on my sons gpx mp3 player from a cd on a windows media player 9 using the instructions and after done mp3 player flashes error and # move fast
    Problem Solver:
  • 7 Answers
It is easier to get a SD memory card for it. Drag and drop the music onto the window which represents the SD memory card and then just put the SD memory card into the GPX MP3 player. I have the same MP3 player and it works nice... it was a good deal for the money! Take the savings and invest in a cheap SD memory card and you will be happy.... I was!
:-) Good Luck!
Posted on May 22, 2008
I can't download music to my San Disk 1GB MP3 player that I got for Christmas. I did not get a manual with it.
To put music on your Sansa e250 you will do this:
Download Windows Media Player 9 or 10 to your computer. I would use Media Player 10 as it is the newer player. After you download Media Player 9 or 10 open it up on your computer, and then hook up your mp3 player, it should be recognized by Media Player and then you can transfer the songs to it. You need to put the music cd in your computer cd player and download the songs to Media Player using Windows Media Player 9 or 10. I have also included a website where you can download the user manual, it will say e200, but the instructions are also for the e250. Good Luck, I hope this helps. Please rate me, Thank You.
http://mp3support.sandisk.com/downloads/um/sansa-m200-um.pdf
Dec 30, 2009 | SanDisk Sansa Clip MP3 Player
HOW CAN I DOWNLOAD MUSIC FROM CDS ON MY SANSA MP3 PLAYER? LISA
To put music on your Sansa e250 you will do this: Download Windows Media Player 9 or 10 to your computer. I would use Media Player 10 as it is the newer player. After you download Media Player 9 or 10 open it up on your computer, and then hook up your mp3 player, it should be recognized by Media Player and then you can transfer the songs to it. You need to put the music cd in your computer cd player and download the songs to Media Playeer using Windows Media Player 9 or 10. I have also included a website where you can download the user manual, it will say e200, but the instructions are also for the e250. Good Luck, I hope this helps. Please rate me, Thank You. http://mp3support.sandisk.com/downloads/um/sansa-m200-um.pdf
Dec 12, 2009 | SanDisk Sansa e250 MP3 Player
I just want to know how to get music off my computer to the mp3
I have copied the method that GPX uses to transfer your music from PC to player.
If you are using Windows Vista with Windows Media Player 11, you will need to follow these instructions.
Note: You will be able to download purchased/subscribed songs to the unit.
1. Start Windows Media Player 11 and then connect your unit to your computer. If you have not set up synchronization between your computer and this device, the Device Setup Wizard starts.
2. In Device Setup - Configure Sync, write a name for your mp3 player.
3. Click Finish. The window closes and the Sync feature in the Player is displayed.
4. From the left pane of this Sync feature, you can select from Playlists or Library and you will see the content of these folders in the center pane.
5. Select the songs or entire albums from the center pane.
6. Drag these songs or albums into the Sync List, which is the right pane of the Sync feature.
7. Click the Start Sync button on the Sync List pane.
8. Repeat steps 4-7 for any other items that you want to copy to your unit.
If you are using Windows XP with Windows Media Player 10, you will need to follow these instructions.
1. Start Windows Media Player 10 and then connect your unit to your computer. If you have not set up synchronization between your computer and this device, the Device Setup Wizard starts.
2. In the Device Setup Wizard, select Manual.
3. Click Finish. The wizard closes and the Sync feature in the Player is displayed.
4. Select the Library option. On the left pane select Sync List.
5. From the left pane you can select All Music or My Playlists and you will see the songs located within these folders in the center pane.
6. Select the songs from the center pane, and drag them to the Sync List.
If you are using Windows 2000, Windows 98SE, and Windows ME with Windows Media Player 9, you will need to follow these instructions.
Note: You will not be able to transfer purchased/subscribed songs to this unit using Windows Media Player 9. You need Windows XP with Windows Media Player 10 to do so. However, you will be able to download regular MP3/WMA songs.
1. Start Windows Media Player 9 and then connect your unit to your computer.
2. Click Copy to CD or Device.
3. In the Items to Copy pane, in the drop-down list, select the playlist, category, or other collection that you want to copy.
4. Check the box next to any file you want to transfer to your mp3 player.
5. In the Items on Device pane, in the drop-down list, click the device to where you want your music files transferred.
6. Click the Copy button.
7. Repeat steps 2-5 for any other items that you want to copy to your unit.
Jan 03, 2009 | GPX MW3837 MP3 Player
CAN'T DOWNLOAD SONG ON MY GPX MW3847 MP3 PLAYER
First, you need to ensure that the switch on the side is set to OFF...
then if you have Windows Media Player 9 and (Windows 2000 and before ie Windows ME/98) ,
Second, Hit the M Button and Make sure that you have the player set to USB
but then if you have Windows Media Player 10, 11 (Windows XP, Vista)
Hit the M Button and Make sure that you have the player set to MTP
and if you have no Windows Media Player ...
copy your music mp3 files using windows explorer or my computer
Jan 01, 2009 | GPX MW3836 MP3 Player
Why does it say error when i put on song onto my gpx mp3 player?
sEVERAL POSSIBILITIES:
* You downloaded protected music on your Windows 98/98SE, Windows 2000, Windows XP computer using Windows Media Player 9. Music was purchased online or the music was ripped form your own audio CD with Copyright Protection turned ON.
o You must use Windows XP and Windows Media Player 10 for online purchased songs.
o You must turn OFF Copy Protection on your Windows Media Player 9 before ripping your audio CDs into WMA files
* You downloaded protected music to your MP3 player using your Windows XP computer and Windows Media Player 10 with your player in USB mode. Music was downloaded from the internet, purchased or subscribed, or it was ripped from your own audio CD with Copyright protection turned ON.
o You have to use your MW3836 in MTP mode.
-Tha Mp3 Doctor
Nov 27, 2008 | GPX MW3836 MP3 Player
Deleteing assistance
Use Windows Media Player 9 or 10 - instructions available from microsoft's website and other websites:
short version:
Connect mp3 player to computer, open Windows Media Player, click on the icon of the mp3 player, and then go to the songs or music folder - find the song you want to delete, left-click the song, and hit "delete" on your keyboard
May 08, 2008 | GPX MW3837 MP3 Player
Gpx mp3 player downloads
you have to get music on to your windows media player and plug in your mp3 player and create your sync list for what songs you want on your mp3 player and it downloads itself in about i minute per song
Dec 25, 2007 | GPX MW3836 MP3 Player
Cant delete
Here's how you get it
you may have to open Windows Media Player but maybe not
a screen will come saying for you to choose either NO leave all the media on the device... or YES delete all media.
click YES but MAKE SURE you have the HOLD button on OFF. if you dont... it will not work
after it completes the task click FINISH
i tried for hours trying to figure it out and that made it work like a charm! =]
Nov 02, 2007 | GPX M2104 MP3 Player
GPX MW3337 sync problem
1- Check that your MP3 Player's File system is OK, you can do that using the DOS command (chkdsk /f). 2- Re-install your Windows Media Player 11. 3- Don't forget to update your system, too.
May 30, 2007 | GPX MW3337G
GPX MW3836 MP3 Player Logo
61 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
