Question about Haier HL32BG 32 in. LCD Television
Sharp aquos cycling on and off
Hi. I just bought a 32" sharp aquos LCD (model 32d64u), got my high def cablebox all setup and enjoyed watching tv for 2 nights. Then tonight in the middle of watching a show the power on the tv shut off. Then on, then off. it did this every 8 seconds or so for at least 5 minutes before I unplugged it, waited a while and plugged-in again... Same problem. I've disconnected every a/v connection between it and my cable box and dvd player and it still does this. I guess I should just return the tv? Like I said, it is brand new. All help appreciated!
  • buzz911 May 25, 2008
    Thanks a lot for the advice. I thought about it and decided since it was so brand new I just wanted a new one, I didn't want to stress about it being something that was going to recur. I swapped it for a new one and it's been fine so far. For what it is worth, I had tried taking the batteriesout of the remote and it still did it, so that wasn't the problem. I suppose like you say it was probably a power supply issue. Thanks anyway.
    Problem Solver:
  • 8 Answers
There is a firmware upgrade to the main board that corrects this issue. contact the servicers at www.asnyonline.com
Posted on Jun 30, 2008
  • 80 Answers
Sounds like a power supply or button problem.
its under warranty call 1800-BESHARP
Let me know what they find
Posted on May 22, 2008
Sharp aquos no power
probably the power supply is faulty. Just watch the bellow added video to understand how to check the power supply a flat panel tv .
Testing LCD TV Power Supply BoardsSTEP BY STEP
http://electro-medical.blogspot.com/
Sep 12, 2015 | Sharp AQUOS LC-32D44U 32 in. LCD TV
The demo mode apears every 30 minutes. I can't really stand it. How can I shut it doen for ever? Sharp aquos LED 40"
I'm not certain of the specific model number of your set, but this should be the same for all Sharp Aquos models.
First, navigate to TV input, and select menu
Next, enter setup and select, "ez setup"
In the ez setup menu, select "home", not "store", for television location.
This should turn off the demo mode and solve your issue.
Jun 10, 2011 | Sharp AQUOS LC-40C32U 32 in. LCD TV
Can i hook up my xbox 360 to my aquos tv with just the red, yellow, and white cable? Right now I am not getting a color pic
Yes you can but it won't be Hi def. It sounds like you're trying to connect the cables to the Hi def input (Red, blue, green, white and red for the audio) That's not the right place to connect to.
Dec 28, 2010 | Sharp AQUOS LC-32GP1U 32 in. LCD HDTV
Sharp Aquos Resolution
According to the manual for the TV, you need to change the resolution on the computer itself first.
The computer resolution should be 1024 X 768 at 60Hz or 1360 X 768 at 60Hz.
After the adjustment made on the laptop, then try the resolution change option.
Jun 11, 2009 | Sharp LC-32D64U LCD TV
Speaker distortion on SHARP 37" Aquos Hi Def
When you are changing channels you are using the tuner of the sat reeiver. the tv does not know you are changing a channel . It is just receiving a constant signal from the SAT receiver. I would suspect a problem with the receiver. Try another one first .
Apr 24, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
Jan 08, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Can't get all my cable channels
what cable company do you have because you should have a cable box because only a cable box can scramble the frequency so you can get the channel you subscribe for
Dec 17, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp Aquos LC C3242U - Intermittant Sound Switching from Mono to Stereo
Not sure if I just got lucky or if the problem is solved..I hooked up my Sharp Aquos LC-32D64U the other night and I had the blue audio box pop up. Mine was only in Mono and would not switch to Stereo...Well, Local cable company is of of Hi-Def boxes but I thought what if my Digital box is bad/old or has some sort of problem. I went down to comcast cable company switched to a different digitial box..came home, hooked it up and so far no blue audio box, plus now it shows that it's in stereo..good luck
Aug 30, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Sharp Aquos rattling bass
the sharp some models dont put a spacer between the speaker and the case causing the speaker to hit the case at med to high volume you can check this and make you a spacer out of washers on each screw that mounts the speakers between the case and peaker frame make sure that the washers or spacers you use dont contact the speaker core. and dont do anything that will void the warrenty if nothing else let the store fix it.
Dec 12, 2007 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Haier HL32BG 32 in. LCD Television Logo
121 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
