Question about Whirlpool Duet GHW9150P Front Load Washer
MY refrigerator is running but is not getting cold.
You can tell is on the light comes on, and you can hear it get running but it does not get cold enough to keep a lot of food in it.
  • czangie4 Jan 21, 2009
    my refrigerator will not get cold the lights work and when you plug it in you can hear the motor start.
  • bomberuk May 12, 2009
    New fridge not been used for long time now light come on motor is running and can feel it getting warm/hot so know that working all working part are clean like new so don't know what the problem can be except it lost it gas? if so what are my options,
  • 21 Answers
This has several issues you might need to look into.
First, your refridgerator you selected shows it is a front load washer. I know that can't be right.
Second. Your temp setting. It should be set in a manner that allows the humidity to exhaust out.
Third, Your refridgerator compressor is about to go out.
Fourth, you are placing alot of warm food into refridgerator, and holding the door open too long. This sometimes shuts the compressor off.
Also peer behind your refridgerator. Is there alot of debris, dirt, brooms, etc behind there. If so clear it out completely.
On the front of some refridgerators there is a grill that can be removed carefully. You will see cooling fins on the inside of this.
Very very gently remove the dirt and debris off of this. The fins bend very easily, so becareful.
At the same time check drip pan, and empty if needed.
If none of these things seem to do the trick, contact a service technician, something tells me it is your defrost sensor, or compressor.
Posted on May 26, 2008
My refrigarator is work but not cool. it is getting a bad sound
Posted on May 20, 2009
Not staying cold
tell me do you hear a buzzing sound for about 5 sec ending with a click sound. every so often?? if so then you have a start device (relay) problem on the compressor you may think the unit is running b/c the lights are on and fan is on but if you hear that noise coming from the back of the unit while turned on then its the start relay or worse case the compressor is locked up..9-10 though usually its the start device
Mar 15, 2012 | Kenmore Side by Side Refrigerator
Amana DRS2662AW Lights are on and I can hear the motor running but no cold air is coming out of vents. Freezer is defrosting. I have vacummed out coils on lower front.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 07, 2011 | Amana ASD2326HE Side by Side Refrigerator
The freezer light is on and you can hear it click to come on, but nothing is running or getting cold
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Nov 15, 2010 | Haier Freezers
My u-line 75rfb-00 refrigerator wont get cold the light comes on the motor sounds as if its working but it only gets cool not cold ?
Then you need to see if the compressor is running or is it the fan? You migh be hearing the compressor come on for a short while. The fan might not be running. Replace the fan if its not running
Sep 26, 2009 | U-Line 75R Refrigerator
Warm in freezer and refrig
On some Amana refrigs , the defrost thermostat has to close before the fan will come on . The coils will get cold and since the bimetal clips onto the coils , it will get cold as they do . When cold enough , bimetal closes and the fan will come on . Are the coils getting cold ? If so , then the compressor is working . You could also have a bad fan motor instead of bimetal . Recheck to see if you hear the fan in freezer now .
Aug 15, 2009 | Amana 23.1 cu. ft. Side-by-Side...
Refridgerator has power but does not get cold
Can you tell me if you hear the compressor running under the refrigerator? Is fan running beneath the refrigerator? Need to get the exact Kenmore model number found when you open the fresh food section. Let me know, Sea Breeze
Mar 19, 2009 | Kenmore Refrigerators
Hi thanks for the question. check the freezer ,is the fan running. check the back freezer wall for frost build up. pull fridge from wall. remove back panel. clean all coils . thanks the appliance doc
Oct 06, 2008 | Maytag MSD2454G Side by Side Refrigerator
defrost it. sounds like ice blockage. Take out freezer drawers unscrew inner back panel. In the t/l/h side there is a hole left of the fan which blows cold air that goes into fridge (side of light unit).
Use a hairdryer to dislodge/defrost this pipe. The polystyrene backing can also be moved to reveal the freezer pipes.Defrost this also. This hopefully should solve problem, if not a freezer or fridge thermistor may have to be replaced which is the coloured cable on the r/h/s of inner freezer which cost approx £20 each
Aug 26, 2008 | Refrigerators
The unit is nolonger cold and ice is melting
i have the same problem as above. the lights are on in both the refrigarator and freezer. I do hear the motor (fan) running but there is nothing cooling coming out.
Feb 15, 2008 | Whirlpool ED5GTNXMQ Side by Side...
Whirlpool Duet GHW9150P Front Load Washer Logo
3,311 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
