SOURCE: Check Card
R u taking it on memory or video mode. If camera in play edit mode then it will neither take pic nor video please chek Sangita
SOURCE: The camera says that the memory is full but it
Well you can try transferring Photos from the memory card to the computer by using a card reader, after transferring the photos just format your card by computer, for more help how to format the card please follow the below steps -
1. Insert your memory card into your card reader then insert the card reader to the computer USB port.
2. Open up 'My Computer'. You should see it under the list of available drives.
3. Check its contents first to make sure that you have the right drive.
4. In 'My Computer', right-click on the drive and choose 'Format'.
Once the process is completed, take the memory card out and insert it into your Digital Camera and try taking pictures again........ If further you have the same problem then you can try to reset your camera to default settings. also make sure you select the memory card to save the captured photos.
Please post comments if you need more help or information......
Good Luck!!
Thanks
