Question about Frigidaire FGF376 Gas Kitchen Range
Frigidaire lp gas oven
Ovan flame is only about 14" long. takes forever to pre-heat and the ignitor stays on.
    Problem Solver:
  • 9 Answers
YOUR OVEN GLOW IG NITER IS SUPPOSE TO STAY ON THAT'S NORMAL. WHAT YOU NEED TO DO IS CHANGE THE ORIFICES ON YOUR OVEN VALVE BECAUSE YOUR USING LP GAS MOST OVENS COME NEW SET UP FOR NATURAL GAS ALL OF THEM EVEN YOUR COOKTOP
ALSO
Posted on Apr 10, 2009
10 year old DCS Oven does ignite. Oven ignitor glows but maybe not enough to trigger LP from being introduced?
just because the ignitor glows it doesn't mean it's good,it takes 3.2 amps for the ignitor to open the gas valve and ignite the flame,usually if the flame doesn't ignite in around 40 seconds the ignitor is bad.also check the burner tube,your model number doesn't come up so i don't know if you have one or two ignitors in this oven but i've found that when the ignitor starts to fail and the customer waits to long to have it looked at the ignitor burns a hole in the tube and then both the ignitor and tube has to be changed,hope this helps and good luck with your oven.
Jul 19, 2013 | DCS RGU-486GD-L Range 48", 6 Burner,...
My oven takes forever to heat up if it does at all
If it's a gas range and you can see the ignitor glow, but there is no flame within 90 seconds after you turned the oven on - replace ignitor.
First Choice Appliance, Sacramento, CA
Jul 08, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Gas metal tube on bottom is noy staying lit. Takes forever to pre heat. It does ignite and gas does come out for a second then goes out.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Aug 23, 2010 | Ovens
Large oven is not heating properly.
Had same issue - replaced the ceramic ignitors and most of my problem was solved. Apparently ignitors require replacement every 3-5 years. When they start to go it takes forever for your oven to heat up ... they don't glow properly causes the gas valve stays partially closed - ie hence less flame/heat. It may also significantly increase the amount of time it takes for the burner to light at all - essentially for the same reason.
On my oven the other issue was the burner itself ... it had corroded somewhat so the flame didn't automatically 'move' around to the other side of the burner. I removed the burner & cleaned the surface with a brass brush - problem soved. So essentially I had two issues - burner requiring maintenance & replacment of the ignitors.
As an aside I'm no expert - just relaying my experience.
May 11, 2010 | DCS RDS-486GD Stainless Steel Dual Fuel...
Oven appears to start, takes forever to preheat,
This is what I would do: I would unplug the range and connect my test cord to your range cord. I use an ammeter along with my test cord to read the amp draw of the bake ignitor. If it cannot get above 3.5 amps I know the ignitor is bad or weak. Since the oven is working that means there is a good circuit. In order for the safety bi-metal to open the amp draw must reach 3.5 amps or better. So to me I am thinking bad ignitor. To get to it I remove the door oven racks and bottom, I then remove the flame spreader and unplug the quick connect to the ignitor. I remove the burner and ignitor and replace the ignitor on a work bench. I am too old to be bending over and trying to do any parts replacement inside an oven. LOL. I have a training film which shows how the silicone carbide ignitor works HERE. Post a model number and I may have a service manual, do not forget to rate the answer.
Feb 26, 2010 | Kenmore 30172 / 30174 / 30179 Gas Single...
I have a frigidaire gas stove model #FGF337AWJ.
I went through that once and believe it or not it was the ignitor. Instead of a thermocouple these new ovens use the amount of current going through the ignitor to prove the flame. Seems like after it gets ot a certain temperature the amps drop off enough to cut out the flame and then it will try to recycle. If it is not that it would be the thermostat but they very seldom go bad. I would reolace the ignitor first I think it will solve your problem.
Nov 14, 2009 | Frigidaire FGF337BC Gas Kitchen Range
Changing to LP ... Oven flames very hi during pre heat
Convert the gas regulator to LP. Then adjust all burner orifice outlets clockwise until the correct flame height is achieved.
Aug 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Frigidaire gas oven not heating
replace the bake ignitor its getting weak
Jul 01, 2009 | Frigidaire FGB24T3A Gas Single Oven
It take a long time for my gas range to pre-heat
the oven flame seems to be to low, that flame most be at least 2 inches long. not counting the sides of flame from one side of the burner to the other, but from where the flame begins at the metal of the burner.
Dec 11, 2008 | Frigidaire Kitchen Ranges
Oven does not stay lit.....
HI thanks for your question. yes the igniter stays on all the time the flame is on, it keeps the safety valve open to give you gas. and yes the new igniter will work. thanks
Oct 15, 2007 | GE Profile JGSP48 Gas Kitchen Range
Frigidaire FGF376 Gas Kitchen Range Logo
193 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
