Question about Kenmore 74602 Gas Dryer
No second ignition
The dryer ignites fine from a cold start, but will not start a 2nd time during operation. The igniter lights up fine but the valves do not open to let the gas out.
Thermal fuse is fine and tested. It does not seem to be the solenoid "coils" because they open the valves from a "cold" start. Radiant sensor glass is clean, not broken, and not smokey inside - so it looks OK.
Any ideas? Is there a way to test the radiant sensor? Thanks in advance. . .
  • Smarthomey May 27, 2008
    I had my doubts, but replaced the coils. . .
    . . . and everything worked! Thanks oldfixer. . .
Oldfixer was right on the money! I had the same issue (would fire off the first time then just cycle through lighting the igniter, no more fire) - replaced the coils - and she's good as new! Thanks oldfixer
Posted on Aug 14, 2008
    Genius:
  • 1,028 Answers
Still suspect coils they have been known to not pull in on restart especially after a warm up if sensor bad probably wouldn't start first time both coils come in a kit replace both
Posted on May 22, 2008
White knight gas tumble dryer lights then cuts out
Flame sensor next to the burner is eather bad or there is a bad connection at the flame sensor (that's why the kick works)
Jan 05, 2014 | Dryers
My ford windstar 2003 hesitates during cold weather or wet conditions. But good during idle. Some time shows blinking engine light.
The flashing and rough running is to to a misfire or misfires cause by arcing due to moisture on ignition components. Eventually these misfires can lead to other problems such as damage catalytic converter. Start by identifying which cylinder(s) is/are misfiring. The arching can be reproduced with a spray bottle filled with soapy water. Spray the ignition components (wires, coils, distributor cap...)and look for the vehicle to idle rough. Replace any faulty component.
Feb 20, 2013 | 2003 Ford Windstar
Resetting the passlock
1. First, insert the ignition key and turn the ignition switch to the "On" position (Do not start the engine). Leave the switch on for 11 minutes. The security light may flash or be on steady during this 11 minute period. Make sure the light is no longer on or flashing before proceeding to #2 .
2. Turn the ignition switch off for 30 seconds.
3. Turn the ignition switch to the "On" position (as in step #1) for 11 minutes again.
4. Turn the ignition switch off for another 30 seconds.
5. Turn the ignition switch to the "On" position for 11 minutes a third time.
6. Turn the ignition switch off for 30 seconds one final time.
7. Turn the ignition switch to the "On" position one final time and wait 30 seconds.
8. Attempt to start the engine. If the engine starts and runs normally, the relearn is complete. If the engine does not start, Go to this link for info
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Sep 08, 2012 | 2000 GMC Yukon Denali
Gas Dryer Ignition Issues
did you try bypassing the cycling t-stat also?
Aug 25, 2012 | Samsung Dryers
My kenmore dryer will start and run when cold after it heats up the flame (gas dryer)goes out then after 3 or 4 mins. i can see the igniter light but will not start a flame after 5 or 6 seconds the igniter...
gas valve coulkd be bad if not opening after a certain period of time the ignitor will turn off and attempt a few times more,does it have a soilenoid valve also open and clean any carbon that might be built up over yrs
Jun 21, 2009 | Dryers
Kenmore front load washer won't heat
The gas burner assembly uses solenoid coils in a circuit with the flame sensor to safely ignite the burner. When the dryer starts a heated cycle, the circuit through those components is energized. The igniter glows until it reaches the proper temperature to ignite the gas, at which point the flame sensor trips open and the current flowing through that circuit is diverted to the gas valve coils so the gas valves open, and the burner lights and continues to burn. If the solenoid coils on the gas valves fail, the gas valves won't open for ignition. If the gas valve coils are weak, the burner lights during the initial ignition sequence from a cold start but it fails to light the burner on subsequent ignition attempts. In this situation, replace the valve coils. I Had the same problem with mine and I fixed for like $25.00 US. Its not hard to do look at the video. Either buy your part from them or to get it fast and not out of this world go to "repairclinic.com
Nov 17, 2017 | Dryers
Stops while driving
this is usually due to a dirty throttle body. just beware if you do try to clean it you will need to preform the idle relearn procedure. this does work, ive done it personally.
A. Accelerator Pedal Release Position Learning Procedure.
1. Make sure that the accelerator pedal is fully released.
2. Turn ignition switch “ON” and wait at least 2 seconds.
3. Turn ignition switch “OFF” wait at least 10 seconds.
4. Turn ignition switch “ON” and wait at least 2 seconds.
5. Turn ignition switch “OFF” wait at least 10 seconds (how would you know if you get it right?)
B. Throttle Valve Closed Position Learning
1. Make sure that accelerator pedal is fully released.
2. Turn ignition switch is “ON”.
3. Turn ignition switch is “OFF” wait at least 10 seconds.
Make sure that the throttle valve moves during above 10 seconds by confirming the operating sound (i never get this right because i never heard anything)
C. Idle Air Volume Learning (Throttle Position Learning)
It's best to time with a watch/clock.
1. Perform “Accelerator Pedal Released Position Learning”.
2. Perform “Throttle Valve Closed Position Learning”.
3. Start engine and warm it up to normal operating temperature.
4. Turn ignition switch “OFF” and wait at least 10 seconds.
5. Conform that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
6. Repeat the following (steps 7a, 7b) procedures quickly five times within 5 seconds.
7a. Fully depress the accelerator pedal (HARD)
7b. Fully release the accelerator pedal.
8. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the Check Engine Light (CEL) stops
blinking and turned ON.
9. Fully release the accelerator pedal within 3 seconds after the CEL is ON.
10. Start engine and let it idle.
11 Wait 20 seconds
12Rev up the engine two or three times and make sure the idle speed and ignition timing are within the specifications. (this is fine because SES light lets you know if you did it right the way it blinks)
Oct 25, 2008 | 2005 Infiniti G35
Kenmore Dryer won't re-light after initial start
The following link explains a little theory about glow bar style igniters:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
I know the link is for replacing an igniter on a gas range, but the types of igniters used and the theory of operation is still the same. First, you will need to determine if your igniter is still good. The link provides you with the tolerances you need. If the igniter is still good, I would recommend replacing the gas valve solenoids (coils). There are two of them on the burner assembly near the igniter. One is a two terminal, the other is a three terminal. One coil is the gas main, the other is the pilot position. Typically, a weak or bad igniter will not allow the burner to ignite at all. If the coils are bad, however, they may allow initial ignition, but once the burner assembly gets hot, they may shut off. I've seen this happen before. Test your igniter just to be sure, but I'm leaning towards the coils being faulty. It is strongly recommended that you replace BOTH coils at the same time if one or the other is defective. They are generally sold as a set. If you post back with your COMPLETE model number I can assist you in trying to locate replacement parts if you like. I hope this information helps you. Let me know if you require additional assistance.
Oct 24, 2008 | Dryers
No second ignition
replace the solenoid coils and it will work.
May 22, 2008 | Kenmore 74602 Gas Dryer
Kenmore 74602 Gas Dryer Logo
81 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
