Question about RCA F36650 36" TV
Sound TV sounds starts to go up when TV is turned on like I am holding the volume up button on my remote...Please help!!!
    President:
  • 4,402 Answers
Sounds like the voulme button on the tv is stuck
Posted on May 22, 2008
How do i set up a new remote control for a samsung ht ws1 sound bar
2-Function Remote Stopped Controlling my Sound Bar - Verizon Forums
https://forums.verizon.com/t5/Fios...Remote...Sound-Bar/td.../559715
Apr 6, 2013 - It won't even control volume through the TV (Samsung). ... Did theremote ever turn on the sound bar, or have you been controlling ... Does the sound bar or TV have sound (sound but not volume control)? ... NO, UNFORTUNATELY THE FIOS REMOTE NEVER POWERED ON/OFF THE SOUNDBAR - I HAD ...
Your remote reprogramming woes solved - Rogers RedBoard
redboard.rogers.com/.../your-remote-reprogram...
Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code.... the Rogers remote to turn TV on/off but can't get the remote to control volume. ...New Samsung smart TV and I have entered all the proper codes but the ..... Doesanyone have a code for volume control of Samsung Soundbar HW-J250.
Wireless Genie remote Doesn't turn on/off the soundbar - AT&T ..
Jan 08, 2016 | Samsung HT-WS1 Speaker System
No sound
  • 1 Make sure that your audio cables are plugged in properly to the correct ports if your audio is distorted or noisy. Every cable should be inserted completely. If you still encounter bad audio, replace the cable and then attempt to use a different device with the old cable. This will help you pinpoint the source of the bad audio problem.
  • 2 Use the "Volume up" button on the remote or TV buttons panel to turn up the TV audio volume if the volume is quiet. If the volume is still quiet, check to see if your audio source device has volume settings. If it does, turn the up the volume on your device (see your device documentation if you need help with this).
  • 3 Press the "Mute" button on your remote control to disable the mute function if you can't hear any audio. Once disabled, press and hold the "Volume up" button on your remote control to turn up the volume. If there is still no audio, press the "Menu" button on your remote control, select the "Audio" menu, and ensure that the "TV Speakers" are set to "On." If you are still not having any luck and are using the built-in TV tuner, open "MTS Audio" inside the "Tuner" menu and make sure it is set to "Stereo/English." If there is still no audio, verify that all your audio cables (including the antenna cable if you are using one) are plugged securely into the proper ports on your TV and audio source device (if applicable). If you are using an antenna, reposition it to a clear, open area; preferably near a window. If your audio source device has audio settings, check to make sure they are set the way they should be (see device documentation).
  • Read more : http://www.ehow.com/how_7498064_troubleshoot-vizio-sound-problem.html
    Mar 08, 2014 | Vizio Televison & Video
    Hi, i bought dish universal remote . all buttons working but volume buttons not so please help me. my old remote was 1.5ir and new has 3.2 ir universal
    Hello, it sounds like all that you need to do is program your remote to the tv. Because I do not know the brand of your tv, I'll give you the power scan instructions. The power scan scans the tv for the correct remote code.
    1. Hold down the Clear TV button until all lights at the top of the remote light up
    2. Press the red TV POWER button
    3. Press and release the up arrow on the remote about once a second until the tv turns off.
    4. When it turns off, press the # (Pound) button
    5. Try powering the tv on/off, and try the volume. If one or more of these functions do not work, start over at step 1 again.
    Hope this helps!!
    Becki Barned
    DISH Network Customer Service
    Feb 02, 2011 | DISH Network IR Remote Control
    I Have a 5.3 IR Remote and a vizio VSB200 Sound Bar. The remote will not program to the Sound Bar. The Optical Audio is connected to the TV. What do I need to do.
    lojr,
    We have code to use with amplifiers, TVs, VCRs, and DVD players. I do not have a code that will work on this sound bar. What is the code you are trying to use? Did Vizio supply a code with your sound bar. They do have codes to use for their TVs to program DISH remotes. Please let me know if you have a code or you can contact Vizio to see if they have a code available.
    I have provided the Power Scan instructions on programming the remote to a sound bar. Use the VCR button to attempt to program the sound bar.
    If you have further questions, please post it here.
    Ray Calo
    DISH Network - Executive Offices
    Power Scan Instructions Power Scan Instructions
    1. While at the sound bar location, point the remote at the sound bar. Press and hold the VCR MODE button on the remote until all four MODE buttons at the top of the remote light up.
    filestream.ashx?id=435
    2. Press the RECEIVER POWER button on the remote.
    filestream.ashx?id=436
    3. Press the UP ARROW on the remote, about one press every two seconds. Stop as soon as the sound bar turns off. This process may take several minutes.
    filestream.ashx?id=438
    4. Press POUND (#) on the remote. The VCR MODE button will flash three times.
    filestream.ashx?id=440(VCR button instead of TV button)
    5. Press VCR MODE button, then red TV button on the remote to turn on the sound bar. Press VOLUME on the remote to confirm the remote controls the sound bar. If this does not work, return to Step 1.
    filestream.ashx?id=442
    Remember to press the SAT MODE button to return to the Satellite mode to change channels.
    Jan 13, 2011 | DISH Network IR Remote Control
    Have an Hitachi 60sx12b. the sound meter bar stays on. can manually adjust the sound up but will go back down to 0. tv remote or sat. remote doesn't work at all. Please help
    It sounds either volume down button is bad that turns volume down on its own or system control chip got defective and decreasing volume level.
    Press volume down button on tv front and check is it working properly.
    Let me know to find out further info to solve the issue.
    Thanks.
    Jun 05, 2010 | Hitachi Televison & Video
    When i turn the tv. on, the volume line appears all the way to zero. if i turn the volume up, it goes up but when i release the up button the volume goes down all by itself.
    It sounds like one of the volume down buttons is stuck in the activate position. The same as if you were holding the down volume button continuously. It could be either the volume down button on the TV or the remote. I would try remove the batteries of the remote then adjust the volume by the TV buttons.
    If the volume doesn't go back down then the remote is the problem. In order to fix the remote you may need to take it apart. This is normally easy to do just locate any screws that may be holding the remote together. If you don't see any screws then you will need to pry the two sections apart. Separate the circuit board and rubber buttons and clean them both with some rubbing alcohol and reassemble it. If it still has the volume issue you may need to replace it.
    If the problem persists with the remote deactivated then it's the volume button located on the TV. That is a little more difficult. You can try wiggling the button or some canned air (used to clean computer keyboards) to blow it clean. However it may need to be disassembled to gain access to the switches for proper cleaning.
    Hope this helps.
    Oct 19, 2009 | Toshiba 32A33 32" TV
    Samsung TV - have sound/auto volume set to on. When TV is turned off and then on, tv volume is extremely low. Go back to sound menu, it shows "on" but if you go back and act like you are turning in on, the...
    Hello Blindrid,
    What I would suggest you do is Press your MENU button on the tv remote, Then down to SOUND and then Turn the AUTO VOLUME to OFF. Then come out of the menu screen.
    Just to check that it has all work correctly. turn you volume upto a certain number for example 25
    Then turn your TV off the turn it back on. Wait until it is displaying a picture then press the volume button Once either up or down and you should see that it will go to 24 or 26 depending on what button you pressed for the volume. This will keep your volume set to whatever you had it on before you turned the tv off.
    Hope this Helps Please leave a thumbs up.
    Cheers
    Little Dish Fitter
    Oct 06, 2009 | LG 37LG30 37 in. LCD HDTV
    Soyo Flat Screen TV Sound or Volume control is stuck
    Hi deborah card, Lets first make sure your remote is not causing your problem, Look at the light (led) on the remote, is it lit and pulsing? If not you are having a problem with the control panel,  Have you recently cleaned your tv with a liquid? If so you will need to dry the panel with a hairdryer, unplug the power from the tv, put it on low heat and hold it about 6 inches from the panel for a few minutes. With the tv still unpluged press all buttons on the panel a few times then plug back in and try it.  Let me know if this helps and please rate this solution.   lone99star
    Jan 11, 2009 | Soyo DYLT032D 32 in. LCD Television
    Programming my remote to control the sound on my TV
    Here is what is called a power scan. It will go through all the codes in the remote and find the right code for your tv.
    1)hold down tv button next to sat button in top left corner
    2) when all buttons illuminate press 500 into remote
    3)press pound sign
    4)Hello, please help..
    5)hold town tv button again.
    6)when all buttons illuminate press big red power button
    7)press up arrow once a second until tv shuts off
    8)press # pound sign
    9)try to turn tv back on w/ big red power button
    10)if tv doesnt turn back on try again from step 2 but use down arrow instead
    Jul 24, 2008 | DISH Network IR Remote Control
    Cannot control volume
    Dear Mbruce 1,
    With set on press and hold the "Power and Action Buttons" on set, for about five seconds, set will turn off and then back on.
    Please let us know!
    Toprol
    Oct 15, 2007 | Panasonic TH-50PX75U Plasma HDTV
    RCA F36650 36" TV Logo
    88 people viewed this question
    Top RCA Televison & Video Experts
    jason
    matt martin
    matt martin
    Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
