Question about GE Dishwashers
  • Dwayne Smith May 23, 2008
    dishwasher wont run
  • 868 Answers
A model number would be a great start
Posted on May 22, 2008
Brand new dishwasher wont run
Because it doesn't have legs??? Seriously, I need a little more information. Make/model, new unit or replacement? I presume you installed it because an installer can't leave until it works. Is this dishwasher replacing an old one or a new install? Is the electrical tied in correctly? Is the water hooked up and running? Info, info, info!
Oct 19, 2013 | Whirlpool Dishwashers
My Maytag Dishwasher wont run
check to see if your float is work properly. the float is the little dome that sits in the front lefthand corner at the bottom. lift it up a couple on time gently and make sure there is no debris such as a spoon preventing the float bob from going all the way down.
Apr 17, 2012 | Maytag MDB6759AW Dishwasher
Doesn't drain after washing dishes
Thank you for contacting
There are various factors when a dishwasher wont drain water completely.Such as clogged drain hose,worn belt,pump assembly,bad motor,defective timer,drain valve etc.Please check the bellow links to read the article thoroughly to troubleshoot your problem:-
Please get back to us if you have further query else please accept the suggestion.
Jun 01, 2011 | Roper 24 in. RUD3000 Built-in Dishwasher
My G.E. Dishwasher run through its cycles but the water pools and wont drain
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
May 15, 2011 | Maytag Dishwasher
Dishwasher wont run water or turn off
This sounds like the float switch is stuck or bad. You might be able to wiggle the float or float rod around to free it up. Otherwise you will need to check the float switch itself and replace. This is easy and inexpensive. This link will walk you thru checking and replacing the float switch. It may be a different model but the process will be the same. If you need a diagram or illustration of your specific model enter your model # there.
Jun 28, 2010 | Whirlpool 24 in. GU980SCG Built-in...
Dishwasher wont run
Stuck Key Pad.
Jul 29, 2009 | Dishwashers
Haier dishwasher wont run and shows a code OP
Did you every get your this problem solved? I am having the exact same problem
Jun 10, 2009 | Haier ESD400 Stainless Steel 24 in....
Kenmore dishwasher 587.15159400
to whom it may conern:
about six month ago I purchese the dishwasher, But It just stopped working, the green clean light just blinks all day and night, but wont start it's, when I push the red start button comes on but turns off about 5 seconds later turns of, and wont run and clean my dishes. Could you please help me get strat the dishwasher to start up and run again. Thank you patrick c smith
patrick c smtih
phon 951 805 5187
19050 rockman street
lake elsinore, ca., 92530
actt, 5049 9485 2176 1660
Aug 13, 2008 | Kenmore 15769 Built-in Dishwasher
Dishwashers Logo
59 people viewed this question
Top GE Dishwashers Experts
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
