Question about Frigidaire ATF6000ES Front Load Washer
ATF6000ES The lights flash, the door lock actuates but won't latch. What is wrong?
  • 868 Answers
Replace the door latch assembly
Posted on May 23, 2008
Frigidaire front load washer is flashing E90
Hello davis_04 - Error Code E90 typically means that you have the unit may possibly be experiencing an issue with the lock motor assembly, have a faulty motor door latch, door light switch or a defective EOC. You would need this to be diagnosed by a professional technician in order for the wall oven to properly be repair.
Nov 12, 2012 | Frigidaire ATF6000ES Front Load Washer
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Back driver door won't lock or unloc without manualy doing . 2008 chevy impala
Hello, this is caused by a bad door lock actuator. the door lock actuator is part of the door latch. the door latch will need to be replaced to correct this problem.
  • Remove the rear door outside handle. .
  • Remove the interior trim panel.
  • Remove the water deflector
    May 29, 2011 | 2008 Chevrolet Impala
    How do I replace the door lock actuator on a 1999 Mercury Villager w/o damaging the connecting rods and door track?
    SECTION 501-14A: Handles, Locks, Latches and Mechanisms 1999 Villager Workshop Manual REMOVAL AND INSTALLATION Actuator —Power Door Lock, Front Removal
    1. Remove the front door latch. For additional information, refer to Latch—Front Door .
    1. Remove the power door lock actuator from the front door latch.
      1. Release the locking tabs.
    go here too
    http://groups.yahoo.com/group/villagerquest/
    Sep 26, 2009 | 1999 Mercury Villager
    Ge washer wcvh6260 ...... start/pause button flashes, won't start
    Does the 'door locked' light come on? If not, check the switch and it's actuator (a pin that is part of the door latch).
    Aug 22, 2009 | GE WCVH6260F Front Load Washer
    Rear door on driver side won't open,have taken the panel off the inside of car,seems like the lock won,t travelas far as it does on the other door.is there any way to open this door,thanks[1997 lincoln...
    Rear
    Removal
    1. Using a small screwdriver, remove the screw cover from the armrest of rear door trim panel (27406).
    1. Remove the two retaining screws.
    1. Using Trim Pad Removing Tool from Rotunda Windshield and Moulding/Trim Removal Kit 107-R0401 or equivalent, pry rear door trim panel from door inner panel.
    1. Disconnect electrical connectors.
    Installation
    1. Position rear door trim panel on door inner panel, aligning two locators on rear door trim panel. Reverse Removal procedure.
    ------------------------------------------------------------------------------------ Rear
    Removal
    1. Remove door trim panel and watershield. Refer to Section 01-05 .
    1. Check all connections of remote control links and cables. Service as necessary.
    1. Remove remote control assembly.
    1. Remove door latch remote control assembly from latch assembly.
    1. Drill out rivet at bellcrank and link (264B14).
    1. Remove three screws attaching latch assembly to door.
    1. Drill out rivet that attaches actuator motor to door.
    1. Remove latch assembly with actuator motor and door latch control rod lever link assembly.
    Installation
    1. Install new bushings and clip onto latch assembly.
    1. Install latch with links and power lock actuator into door cavity.
    1. Position latch assembly to door, aligning screw holes in latch and door. Install three screws. Tighten to 10-13 Nm (89-115 lb-in).
    1. Attach door latch actuator motor to door with a new rivet.
    1. Install bellcrank and link to door using a new rivet.
    1. Install inside door handle and remote control assembly to door.
    1. Open and close door to check latch assembly operation.
    1. Install watershield and door trim panel. Refer to Section 01-05 .
    Item Part Number Description 1 221A00 Door Handle to Door Latch Actuating Cable 2 26446 Rear Door Control Rod Retainer 3 377901 Plug Button 4 26412 Rear Door Latch 5 W623451-S2 Push Nut 6 224A32 Counter Balance 7 22450 Door Outside Handle Tension Spring 8 W701210-S309 Screw 9 224A20 Outside Door Handle Anti Rattle Pivot (2 Req'd) 10 22404 Door Handle 11 224A24 Front Door Outside Handle Spacer (2 Req'd) 12 264A64 Rear Door Actuating Rod 13 22408 Outside Door Handle Anti-Rattle Bumper 14 22428 Outside Door Handle Large Pad 15 N621906-S2 Nut (2 Req'd) 16 N807329 Screw (3 Req'd) 17 26595 Rear Door Electric Latch Actuator (RH) 18 W701566-S47 Rivet 19 431C04-A Rear Door Latch Striker Assembly 20 — Door Lock Striker Plate (Part of Door Shell Assy) 21 W525172-S Rivet (2 Req'd) 22 264B14 Bellcrank and Link (RH) 23 264A50 Bushing 24 N802034-SG Rivet 25 26420 Rear Door Latch Control Rod Link 26 W525172-S Rivet (2 Req'd) 27 21818 RR Door Latch (Inside) 28 A26460 RR Door Latch Push Button Rod 29 21982 Door Latch Rear Striker Assembly 30 N808377-S101 Screw (2 Req'd) 31 250A04 Rear Door Catch 32 N801010-S100 Truss Head Bolt (2 Req'd) 33 N804234-S2 Screw 34 266A74 Rear Door Latch Actuator Retainer 35 24630 Rear Door 36 26552 Rear Door Latch Control Escutcheon A — Tighten to 21-29 Nm (16-21 Lb-Ft) B — Tighten to 10-13 Nm (89-115 Lb-In) C — Tighten to 7-8 Nm (62-70 Lb-In) D — Tighten to 26-34 Nm (20-25 Lb-Ft) E — Tighten to 3-4 Nm (27-35 Lb-In)
    Mar 24, 2009 | 1997 Lincoln Continental
    1996 Ford Bronco door lock actuator
    These directions might sound a little goofy. I'm trying to orient your location with front and rear rather then left and right because it depends on which door you are working on. Front is towards front of rig and rear, oh I think you get it.
    1. Close window on door. 2. Using a flat screw driver pop off trim under inside door handle. I think there is a groove in the plastic to which the screw driver can be inserted. Remove screw. 3. Using same screw driver pop off trim panel with door lock and window control switches. Start lifting from end located at panel closest to the front of the rig. The panel towards the back end has a pivot point which holds the back of the panel into the arm rest. Dis-connect the two switches from the trim panel. 4. Again, using flat screw driver, pop off the trim pannel located at the upper door/window frame nearest the back of the rig. Remove screw. 5. Lift up the door panel to remove. Be careful the light bulb is attached to the door panel. Rotate light socket 90 degrees and remove. 6. From the rear of the door pull back the platic stick-on barrier. Don't remove the whole thing just pull it leaving about half of it towards the front of the door stuck on. 7. Remove the one 11mm bolt, located towards the bottom of door, which holds the rearwindow guide. Don't remove the two 11mm bolts which hold the horizontal brace. Nothing else needs to be removed, leave all rods and attachments in place. They all attach the the door latch and are not of any further concern.
    8. Now the easy part. The actuators and door latches are separate components. The actuator slides onto the door latch via two metal guides located on the door latch. The actuator is held into place with a plastic locking tab. The locking tab is part of the actuator housing. 9. This tab has to be pushed in to release actuator from latch. 10. Find on ouside of door - rear where the latch fingers? (I don't know what else to call them) are located in the notched door frame. At the bottom of the notch is a very narrow opening, just a ****. This **** allows access to the locking tab on the actuator. 11. Orient the screw driver in the end of the **** closest to the interior. Working on a right door, looking at the locking fingers, facing the front of the rig, your screw driver would be inserted at the left side of the ****. Pushing a flat screw driver into the **** will push the locking tab allowing the actuator to slide off the door latch. 12. A flat screw driver or other small pry tool can be inserted between the actuator and the door lock to help slide the actuator off the metal guides. The pry unit can be inserted where the rod from the interior manual door lock stem is attached. Mine had a yellow snap/flip keeper. 13. The actuator slides off from the interior towards the outside door panel. 14. Simple put pressure onto the locking tab with one screw driver and gently pry with the other one and the actuator should slide right off.
    15. I picked up an actuator at a u-pull it wrecking yard for five bucks and it worked fine. Dealer wanted $90.00 and auto parts wanted $127.00. When I pulled my actuator from the wrecked rig all door panels and interior where stripped. It took me literally 20 seconds to pull the actuator. 16. To install new unit slide actuator onto door latch rails and let locking tab click into place. You might have to manually move the interior door lock stem up and down until the finger on the actuator lines up with a hole on the plastic part of the interior lock stem.
    16. I Want to thank TommyRox in Texas on Ford Truck World and rivguy on automotiveforums.com for their posts.
    Jun 18, 2008 | 1996 Ford Bronco
    When you start a cycle the washer fills then turns then sounds as though its trying to empty the door lock light flashes and 2 other display lights flash
    It means your door is not shutting or latching
    Check for debris and nothing stopping it from shutting
    If not replace door latch(some parts lists call it door switch)
    its most likely not actuating so it wont advance to the next part of cycle.
    if not latch could be bad control board, id try latch first is cheaper and more common
    May 02, 2008 | Washing Machines
    Frigidaire ATF6000ES Front Load Washer Logo
    172 people viewed this question
    Top Frigidaire Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
