Question about SanDisk Sansa e250 MP3 Player
Samsung mp3 player
My mp3 player has resently frozen up completely. I am able to turn it on but it has locked up at the las song that was playing, no sound, not buttons will work once it is on so i have to take the battery out. The computer wont even recognize it when i hook it up with a usb cable.
Ps. Just to note something i believe this only occured after it fell
i believe this is the product
  • 8,596 Answers
Use Windows Recovery Mode method:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 25, 2008
Fuze locked up and failed this morning
attach the USB cable then Press and hold for 20 seconds the ON button & the Play button(>||)
Feb 05, 2010 | SanDisk Sansa Fuse MP3 Player
Creative zen became frozen
Let the battery completely drain, and after a while charge it using the charger available else thru computer without turning it on.. let it charge for 50% and then try switching it on. Try this if not get back to me.
Jan 21, 2010 | Creative Technology Zen MX Black (8 GB)...
Sony 2GB MP3 Player NWZB135 - Black. frozen screen
Push the reset button on the back of your MP3 its a SMALL hole labeled RESET. Use a small object and insert it into the hole. Press the button and turn it back on
May 30, 2009 | Sony Audio Players & Recorders
Mp3 is frozen after downloading a new song off of a website!!
let the battery die. hook it up via usb and reflash it using sansa firmware updater. it will erase everyting but at least it will start working again.
May 23, 2009 | SanDisk Sansa Fuze MP3 Player
I tried to remove a song, and now it is frozen.
if your ipod is frozen, hold down the center button and the menue button at the same ezact time. this should refresh your iPod
Feb 06, 2009 | Creative Labs Zen Touch MP3 Player
Mp3 player frozen
mp3 play only 10 sec of each song
Dec 10, 2008 | Gateway M640XL-QS Notebook
Frozen Completely
Press and hold the 'user' button with the play/on/off button. This should reset the player.
Aug 25, 2008 | Samsung YP-U3 MP3 Player
Response
There is no problem with the method. Turn the Samsung off, hold in the volume + button, plug it into computer while holding the volume +, and continue holding the volume + button for up to a full minute. Windows will eventually pull up the Found Hardware Wizard, reload the needed drivers, and will recognize the Samsung again.
May 26, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sasung K3 Im using mix cd's
play on your computer in media player make a new playlist with all of your songs and then download as a complete playlist to your mp3
Dec 28, 2007 | Samsung YP-K3 MP3 Player
I won´t turn on/off
hi, i'm from chile and i don`t speak much english, but i'll try to help you, because i think i've the aswer by my experince. when i was listening some song, and press for the next song, my MP4256FM frozen and i can't turn it off or nothing like that. after many times that i put play again the same song and frozen again, i understand that the MP4256FM will not read any song that in his name have a X,?,?,?,?, or ? (example axel.mp3 or introduci?n.mp3). So you have to change the name of the song on your pc and the ploblem will solved. I hope that this help you. bye! =) Jonathan Zu?iga el.zunhiga@hotmail.com
Jan 10, 2007 | Audiovox MP4256FM (256 MB) MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
