Re: NAD 3150 speaker "clips"
Thanx for your reply. Just to be clear as I was not initially, the problem is broken speaker connection spring-type "clips" Two of them are broken, so I was wondering if they could be repaired, or is there a replacement solution.
Thanx again, I really appreciate your time!
Don
vintagethangs@gmail.com
  • 4,234 Answers
Yes these clips can be replaced. There are a number of suppliers on the net that provide speaker parts. Look around and find one that will fit. As long as the hole is filled (no gaps) the speaker integrity won't be broken. The exact shape is not important. Figure on $2-$5 for the part. If you are looking for the specific NAD part, that will be a bit more difficult. I'm assuming that the clips are on the speaker not the receiver. If hte clips you are talking about are on the receiver end, this gets a bit more complex. Try calling NAD service and ask for the part. It may not be cheap, but there should still be some around.
Dan
Posted on May 22, 2008
NAD 3150 cuts out
Hello. Slapping and it working is a tail sign that there is a loose connection, bad solder point, loose wire. When a circuit board gets hot, solder joints separate and an opening occurs in the circuit. Open it up and get a visual. Look for cold solder joint, make sure all the connectors are secure. Good Luck
Feb 13, 2014 | Audio Players & Recorders
How to connect a CD player to an NAD 3150 amplifier
These depends on the model of your CD player, use the corresponding
RCA plug or a 3.5mm plug for portable CD player to the Tape Input
of your NAD 3150
Nov 01, 2012 | NAD Audio Players & Recorders
Hello i own NAD 3150, its not working, all the indicator lights ( power, protection and soft clipping glows)
HI...
It's either failed power supply capacitors or one or more power transistors in the output amp have gone bad
Oct 05, 2010 | NAD Audio Players & Recorders
I cannot get my front speaker wires to connect in without falling out of the unit. Do the wires need to be a certain gauge to lock them down?
No enough info: does your system has spring clips or binding posts for speaker connection? Sometimes spring clips are not spring loaded, so you have to lift some type of clip, push wire in than lock the wire down. Can't see from the picture-is it Sony DAV system? If you're using too thick wire, that may pose the problem.
Oct 24, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
NAD 3150 doesn't play any sound
I, too, have the 3150 and have experienced problems with it. With me the INPUT knob is touchy and needs micro turns sometimes to get both channels to come through. Also, it sounds like the pots are dirty as I get a scratchy sound while adjusting the knob. I have been told that these units are great middle of the road audiophile units. Actually, for the price of a used unit you can't do better. I just had an NAD 2400 THX amp delivered today and am using the 3150 as a preamp. My girlfriend is not feeling well and sleeping in the bedroom, though, and I can't listen to it :( The few minutes I heard of Steely Dan's Cousin Dupree made me bout **** myself (until I got the dirty looks). Sorry I wasn't more help! Goooooo NAD!
Jun 30, 2009 | NAD C325BEE Amplifier
Coin Tray Wont Stay Closed
The plastic spring clip had become stressed and had "moved" out of position resulting in no "retaining presure,hence the coin tray/fuse cover would not stay in the "Closed" position."Simple" $6.75 fix.
Dec 29, 2008 | 2002 Subaru Forester
Nad 3150 speaker repair or replacement ideas
The speaker can be reconed. What specifically is the problem with it?
Dan
May 21, 2008 | NAD Audio Players & Recorders
152 people viewed this question
 Grubhead
Grubhead
