The COPS (coils) may have shorted the drivers in the PCM (computer). You should get a misfire code for each cylinder misfiring though.
Slim possibility, but very expensive unless you have a service contract.
LINCOLN:
1999-2004 Navigator
2002-2003 Blackwood
2003-2005 Aviator
MERCURY:
2003-2004 Marauder
ISSUE:
Some 1999-2004 Navigator, 2002-2003 Blackwood, 2003-2005 Aviator, 2003-2004 Marauder and 2003-2004 Mustang vehicles built before 12/19/2004 equipped with 4.6L 4V/5.4 4V engine may exhibit a runs rough, lacks power, and engine misfire, prompted by a MIL light and DTC codes P0301, P0302, P0303, P0304, P0305, P0306, P0307, P0308, and P0316.
ACTION:
Diagnose engine for engine misfire concern. If diagnostics determine an engine misfire which is characterized by leakage through exhaust valve(s), only replace the affected cylinder head(s).
SERVICE PROCEDURE
FOR VEHICLES WITH RUNS ROUGH/MISFIRE CONDITION:
I would try cleaning the Mass Air Flow Sensor heated wires with spray carb cleaner to disolve any accumulated varnish. Remove the MAF sensor from teh air intake system and spary it seeral times with carb cleaner or MAF cleaner. Do not touch or move the heated wires inside. See if that helps at all. P0316 - Misfire Occurred in the First 1,000 Engine Revolutions
Report results. Any other codes?
Here's info on P0316: Description: P0316 code is set in addition to any type B misfire DTC which occurs in the first 1,000 revolution test interval following engine start. Possible Causes: Damaged crankshaft position (CKP) sensor
Ignition system
Fuel injectors
Running out of fuel
Fuel quality
Base engine
Damaged powertrain control module (PCM)
Diagnostic Aids: Freeze frame data and the DTC P03xx are also stored, indicating in which cylinder the misfire occurred. Application Key On Engine Off Key On Engine Running Continuous Memory All - - GO to HD1 .
The MAF sensor uses a hot wire sensing element to measure the amount of air entering the engine. Air passing over the hot wire causes it to cool. This hot wire is maintained at 200°C (392°F) above the ambient temperature as measured by a constant cold wire. If the hot wire electronic sensing element must be replaced, then the entire assembly must be replaced. Replacing only the element may change the air flow calibration.
typical MAF
SOURCE: when slowing down , my 2005 aviator transmission
First check your tranny fluid levels.
If it is too high or too low this could be your problem and easy to fix.
If the levels are fine it could mean that it's either engine mounts,CV joint,U-joint...in this case you would need to see a mechanic.
Hope this helps.
SOURCE: keyless entry code for 2003 lincoln aviator
Every car different, call an auto rescue or towing company, the trucks are usually equiped with slim jims, that can be used to gain access to your vehicle.
Hope this helps.
Ed
SOURCE: 2005 Lincoln Aviator:spontaneous crack liftgate hatch??
aviators and explorers are known for that. the is a tsb out on that prob.
SOURCE: 2005 Lincoln Aviator. Replace busted speaker third row seat??
the sub panal doesnt come off seperate you will break it if you try and you will need to remove the whole side panal its e-z afer the panals removed good luck and remember dont force or pull to hard
SOURCE: 2005 Jimmy 4X4, 4.3L, P300 multiple misfire. Have
Try some injector cleaner in the fuel--there might be some water in the fuel also. Check the air cleaner.
