Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
Sansa 250 2 gb
My Sansa has been working fin up till about three weeks ago when it suddenly would not charge when it said it was connected. Then last week it stopped even getting off of the startup screen... if anyone knows whats going on please tell me
  • callofdutyb May 22, 2008
    No thats not it its fully charged but it won't leave the very first *I noticed this is a popular problem with this model of mp3 hmmmmm*
    Problem Solver:
  • 44 Answers
Your USB might not be getting charge to it. might be, but see.
Posted on May 22, 2008
My sansa when its connected to my computer comes on works syncs and everything so as i disconnect it from my computer it' s dead and wont turn on
Three possibilities;
1) You have a dead battery because the battery is no good.
2) You have a dead battery because your Sansa is no longer charging the battery.
3) You have a dead battery because you didn't leave your Sansa tethered long enough to charge it up.
When you have the Sansa c250 tethered to the computer, you should see a tiny yellow lightning bolt flashing, and a battery icon that shows the amount of charge on the battery.
If you see the lightning bolt, but the battery does not charge after being tethered to a working computer or charger for 24 hours, you may need a new battery. You can get one on Amazon.com. Here's a link:
http://www.amazon.com/HQRP-Replacement-Battery-Universal-Protector/dp/B001NZ981S
If you see the lightning bolt, and the battery charges after 24 hours, AND your player works when unplugged--Problem solved! You just need to let it charge for a longer time.
If you do not see the lightning bolt when the player is tethered, and the battery indicator shows "empty," It's likely that the internal plug to your Sansa c250 has broken. Your Sansa is no longer able to charge the battery.
If you happen to be an electrical engineer, or otherwise have a shop full of electronics equipment (including signal injector, volt-ohm meter, needle-tip soldering iron, and stereo magnifying goggles with work lamps) you may be able to fix it yourself. Otherwise, forget it-- your Sansa is dead.
If it's still under warranty, try to get it replaced. Failing that, it's time to get a new MP3 player.
Hope that helps! Please post a message to let others know what happened to your Sansa player.
Nov 22, 2011 | SanDisk Sansa c250 (2 GB) MP3 Player...
My sandisk e 250 one gb ipod is not detecting in ubuntu 10.04 but is charging
you must follow 5 steps
1) connect ur device to windows xp or windows 7
2) go to sansa website download sansa updater and install it
3) then follow instructions by sansa updater it will then automatically search and install a program for detection of mp3 player on ubuntu install that program its around 16mb .the software will do this you just follow this
4 after completing sansa updater instruction ,go to settings you can now see a usb mode then change to msc mode for detection in ubuntu
5 for detection on windows change to mtp mode
Oct 22, 2010 | SanDisk Sansa e250 MP3 Player
PC does not reconize sansa 250
plug it in after you log on to your computer and wait for all the pop ups to go away then plug it in
Nov 25, 2009 | SanDisk Sansa e250 MP3 Player
My sansa willo not charge. It keeps shutting down
try checking every five minutes and turn it on.
Sep 29, 2009 | SanDisk Sansa e250 MP3 Player
How do i reset sansa c 250 to factory setting
All support for Sansa c200 series on this site:
http://www.sansa.com/support/sansa_c200/faqs
Follow the steps on this page of the "knowledgebase" containing key words "factory settings" to the Sansa Connect Recovery Tool:
http://kb.sandisk.com/app/answers/detail/a_id/863/kw/factory%20settings/r_id/101834
Remember: firmware install will erase all data from the player !
Sep 16, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Battery does notfully charge
I have a similar problem but when I use mine, it lasts 3hours per bar on the meter. It only does up to 98% and it overheats. If you take it off and let it cool and monitor it as it charges, you can get a full battery. Take it off charge around 70% and turn it off. Wait 2 hours and put it back on charge until it reaches 100 then take it off and it is charged. To see the battery charge
My Computer > Sansa Clip ?gb (Right-Click) > Properties
Look down at a battery shape with a green bar and a percentage beside it.
Mar 28, 2009 | SanDisk Sansa Clip MP3 Player
Music not synchronized
Try going to the actual file the music is in on your computer, then right click Send To sansa 250. If that doesn't work look on the options menu for USB mode and change it, that works on my 280.
Oct 05, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Says it's connected to the computer but isn't
what u could do is delete sansa e 250 program and then reinstall it with ur cd that u got with the mp3 player see if that works if doesn't work then make readjustment on ur hard drive, try to see if it will detect it if u try on another computer...
Apr 10, 2008 | SanDisk Sansa e250 MP3 Player
Sansa C250
Mine froze up and I just took the battery out. Then it stopped freezing up.
Mar 01, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
