Question about Samsung HL-R5668W 56" HDTV
Samsung HL-5668W doesnt turn on
I change the lamp already the front Led still flashing (Lamps,stand by and time) and the TV wont turn on
techman
  • 3130 Answers
SOURCE: Samsung DLP HL-P5063W. . .no lamp!
You will need to have it diagnosed if you do not have the service manual, or the knowledge of how these circuits work. I can tell you to replace this or that but it would be a guess! You need to start measuring the voltages on the ballast circuit, as I have seen door switches, fan sensors, heat sensors cause all of your symptoms as well. Good Luck
Posted on Jul 25, 2007
SOURCE: Samsung HLN467W Flashing "LAMP" LED
I HAVE A TV SANSUNG HLN467W THIS NOHAVE POWER ( no video, not audio)
only see in the back a LIGHT GREEN, I NEED HELP
Posted on Sep 22, 2008
  • 1039 Answers
Remove the rear cover and check the lamp cover switch. Earlier versions used a black plastic switch holder that may break due to improper assembly. The part number for the holder is BP61-01240A. Newer versions use a metal tab attached to the engine. In this case, improper assembly may cause the lamp cover switch to be extended past its range, either breaking the switch or causing it to have an open contact. Replace the switch with BP91-01231A.
Note that in these models, when reinstalling the rear cover, it is best to remove the lamp cover first, install the rear cover, then install the lamp cover. This will make sure that the lamp switch is properly engaged.
Posted on May 02, 2009
  • 336 Answers
SOURCE: Samsung DLS not working(with new lamp)
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php Also make sure the door cover is closed because there's a switch that if it's not pressed it won't let the lamp light on.Have a bless one!
Posted on Mar 26, 2010
SD Tech
  • 14553 Answers
SOURCE: HL-R5667W Picture just went blank, no sound. When
two things to check here:
1. remove the lamp and examine it to make sure it is not shattered inside.
2. if the set had a high pitched or fan like noise before it failed, the color wheel needs to be looked at--I can tell you a easy way to do this.
Look at the lamp first--life span is 2000 hours.
I am here to help and the more you tell me the better I can help you.
SD TECH Steve
Posted on Jun 10, 2010
Testimonial: "Thanks. I will look at the lamp and the digital board."
The hazard back lights wont quit blinking when car is running even when i pull the fuse on a 2002 buick regal
What fuse are you pulling ?
Hazard Lamps
The hazard warning switch is part of the turn signal switch. The turn signal switch receives battery voltage at all times through the HAZARD SWITCH Fuse. When the hazard switch is placed in the HAZARD position, battery voltage is applied to the hazard lamp/turn signal lamp flasher. The hazard lamp/turn signal lamp flasher sends a turn signal flasher signal to the turn signal switch. The turn signal switch provides all of the turn lamps and turn indicators with the turn signal flasher signal, simultaneously flashing them on and off.
Turn Signal Lamps
The front turn signal lamps are made up of the front park/turn signal lamps and rear turn signal lamps. The front turn signal lamps flash with the rear turn signal lamps when a turn is initiated using the turn signal/multifunction lever. The turn signals will operate only with the ignition switch in the RUN position and will not operate during hazard flasher operation.
When the ignition is turned to the RUN position, battery voltage is supplied to the TURN SIGNAL Fuse. Battery voltage is then applied through the turn signal fuse circuit to the turn signal switch. When the turn signal switch is placed in the LH or RH position, voltage is supplied to the hazard lamp/turn signal lamp flasher. The hazard lamp/turn signal lamp flasher supplies a turn signal flasher signal to the turn signal switch. With the turn signal switch in the LH or RH position the corresponding turn signal indicator, rear turn signal, and front turn signal receive the turn signal switch signal and will flash. The front turn signals receive the turn signal switch signal from the turn signal switch via the BCM. The turn lamps are permanently grounded.
Replace the turn signal switch. Refer to Multifunction, Turn Signal, and Hazard Switch Replacement - On Vehicle in Steering Wheel and Column - Tilt.
Feb 11, 2017 | Buick Cars & Trucks
No pic or sound. the stand by light blinks green then the lamp light blinks red untill it turns off all toghther. the lamp is broken i just want to know if that is the only problem or if the driver may...
Flashing green standby led light at the front panel is an indication that the unit waiting for the lamp to turn on. Since the lamp led light flashes, the unit sensed it already burned out.
Faulty lamp driver has a different error code which is "flashing of the standby light 5 times".
Your unit will back to normal operation again after the lamp replacement.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Jul 22, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
Blue lite flash in front wont turn on
Most likely you have experienced a lamp failure, Part # UX21516.
I use Ebay for lamps all the time and really like a company called niosales.com
enter the part number and you will find either the bare lamp or whole assembly with them
they ship for free. Remove the lamp from the cabinet, if you heard a pop, that was the anode of the lamp failing.
http://stores.ebay.com/NEI-Lamps-and-Electronics?_rdc=1
Jul 11, 2011 | Hitachi 50VG825 TV
I have a 99 Pontiac Sunfire, 2.2L and my turn signals quit working. I replaced the combination switch and the flasher/hazard relay, and still no joy. The problem was intermittent, and now it's just dead....
It will turn on when I hit the button and the turn signals do work. All of this has led to my ABS lights to come on as well. ??????????? Your best bet , take it to a qualified repair shop or learn to do better explanation's ! Or lean to do automotive electrical testing .
Basic Electricity for Service Techs Ohm law Current Flow Opens Shorts
Electric Testing Techniques You Need to Know
How to Use Multimeter to Troubleshoot Common Problems
Do you know what a wiring diagram is ? How to use a DVOM - digital volt ohm meter ? Free wiring diagrams here http://www.bbbind.com/free_tsb.html Enter vehicle info. year make ,model and engine size. Under system click on lighting ,then under subsystem click on turn signals . Click the search button then the blue links .Check power an ground circuits ! This is how we diagnose electrical faults , not just replacing parts .
Turn Lamps
Voltage is applied through the TURN fuse and the turn/hazard flasher when the ignition switch is in the following positions:
• RUN
• BULB TEST
• START
The voltage travels to the contact in the hazard switch. The hazard switch is located in the turn/hazard-headlamp switch assembly. This contact is normally closed.
When the left turn signal is turned on, voltage is applied to the following components.
• The left turn indicator
• The left front park/turn lamp circuit 14
• The left rear turn lamp circuit 18
The turn lamps turn on immediately. The current flow heats up the timing element. The timing element is located in the turn/hazard flasher. The timing element repeatedly opens and closes the circuit. This action causes the turn lamps to begin flashing.
The voltage that is applied to the left front park/turn lamp is also applied to the left front marker lamp. If the headlamp switch is in the OFF position, the left front marker lamp will find a path to ground through one of the following lamps. The following lamps provide low resistance paths to ground:
• The right front marker lamp
• The right turn indicator
• The right front park/turn lamps
• The left front park/turn lamps
The left front marker lamp flashes with the turn lamps. The voltage drop across the marker lamp is much higher than the voltage drop across the other lamps. The lamps that are used for the ground path will not flash.
When the headlamp switch is in either the PARK or HEAD positions, voltage is applied through the following components:
• The EXT LP fuse
• The marker lamps
• The park lamps
When the left turn signal is turned on, the left marker lamp will have voltage at both connections. The left marker lamp does not light. When the turn/hazard flasher stops the voltage to the turn lamps, the marker lamp is grounded through the turn lamp. The marker lamp does not go on. The left front marker lamp flashes in the following manner:
• The left front marker lamp flashes on when the turn filament of the left front park/turn lamp goes off.
• The left front marker lamp flashes off when the turn filament of the left front park/turn lamp goes on.
Voltage is applied to the right lamps in the same manner, when the right turn signal is turned on.
Hazard Lamps
Voltage is applied at all times through the following components to the normally open contact of the hazard switch in the turn/hazard-headlamp switch assembly:
• The STOP HAZ fuse
• The turn/hazard flasher
When the hazard switch is turned on, voltage is applied to the following components:
• The front turn lamps
• The rear turn lamps
The following lamps flash on and off:
• All of the turn lamps
• Both of the turn indicators
The front marker lamps flash with the hazard lamps on, just as the front marker lamps flash when the turn lamps are on. If the headlamp switch is in the OFF position, the front marker lamps flash on when the hazard lamps are on. The front marker lights will flash on when the hazard lamps are on if the headlamp switch is in one of the following positions:
• PARK
• HEAD
When the hazard lamps are on, the following conditions apply:
• The turn circuit is always open.
• The turn/hazard flasher controls the lamp.
Park/Marker Lamps
Voltage is applied through the EXT LP fuse, to the headlamp switch at all times. Voltage is applied to the park lamps and the marker lamps when the headlamp switch is in the following positions:
• PARK
• HEAD
The front marker lamps are grounded through the turn filament of the respective front park/turn lamp. The front marker lamps light as a result.
Stop Lamps
Voltage is applied through the STOP HAZ fuse to the brake switch at all times. When the brake pedal is depressed, the brake switch closes. This action applies voltage through the turn/hazard-headlamp switch assembly to the following lamps:
• The high mounted stop lamp assembly
• The left tail/stop-turn lamps
• The right tail/stop-turn lamps
Jun 30, 2017 | 1999 Pontiac Sunfire
Sometimes the TV's lamp will not go on with the first Power-On
When the set shuts off again count the number of times the led on the front flashes and the color of it. ait will flsh a number of times pause and then repeat. this is an error code and will help diagnose the problem.
Apr 01, 2010 | Sony Grand WEGA KF60XBR800 60" Rear...
I have a philips dlp 55pl9773 has one red flashing led on the front when i do a hard reset tv boots up lamps lites led goes from flashing yellow to green for about ten seconds and then back to red flashing...
MY philips tv model number 55PL9773/17 WAS TURNING OFF THE SCREEN AND LEAVING THE AUDIO ON FOR ONE MINUTE. THEN THE YELLOW LIGHT STAYED ON. THEN THE LIGHT TURNED OFF. thEN I TURNED ON WITH THE REMOTE AND THE YELLOW LIGHT TURNED ON AND A FEW SECONDS LATER CHANGED TO THE GREEN LIGHT AND THE TV TURNED ON. AFTER A FEW MINUTES, BETWEEN 10 AND 30 IT DID THE SAME THING. NOW IT IS OFF WITH A BLINKING RED LIGHT PERMANENTLY ON. TO TURN IT OFF I HAVE TO UNPLUG IT FROM THE WALL. I REPLACE THE LAMP A FEW WEEKS AGO AND IT IS FINE.
Dec 01, 2009 | Philips 55PL9773 55" Rear Projection...
Tv turns on for about 1 minute then turns off by itself
could be the lamp. It is consumer replacable.
Aug 10, 2009 | Televison & Video
Can't find the flasher relay on a 2008 superduty
It doesn't actually have one this function is incorporated into the smart junction box.
The SJB monitors the multifunction switch position by sending multiple voltage reference signals to the multifunction switch. When the multifunction switch is in the LH or RH TURN positions, or the hazard lamp switch is pressed, that input signal is routed to ground.
When the SJB receives a request for a turn signal or the hazard lamps, the SJB supplies on/off voltage to the appropriate turn lamps.
The timed on/off cycle is determined by the SJB and is set to flash approximately 80 times per minute if both the front and rear turn lamps operate correctly. If an individual turn signal lamp is inoperative, the SJB fast flashes the remaining turn lamp approximately 160 times per minute to indicate to the driver of a bulb outage.
The SJB bulb outage is configurable and can be turned off for the rear lamps. This is to accommodate vehicles that have been upfitted with rear LED lamps in place of the traditional incandescent bulbs.
Apr 14, 2009 | Ford F-350 Cars & Trucks
Samsung HL-R5668W 56" HDTV Logo
133 people viewed this question
Jerry Greenberg
Jerry Greenberg
