Question about Bunn BT10B Coffee Maker
STAINLESS DECANTER HAS COFFEE STAINS ABOUT 2" UP ON THE INSIDE AND CANNOT REMOVE IT. WHAT CANI DO???
  • mljones56 May 22, 2008
    problem not solved
  • mljones56 May 26, 2008
    I TRIED BLEACH BUT AFRAID IT WOULD RUIN THE LINING. THANK YOU
    Problem Solver:
  • 15 Answers
You have two options:
Mechanical: Use toothpaste, works great.
Chemical: Use something that dissolves coffee (solvent). My personal favorite is vinegar (a weak acid) but you may want to get more creative and use a more aggressive solvent like dishwasher gel, which you smear on and leave overnight.
Posted on Jun 22, 2008
  • 21 Answers
You may try putting about 2 oz of bleach on the inside, fill with hot water, and let it sit for a couple hours. Use a baby bottle brush GENTLY. So many people ram things in to their pot, to stir rags etc around, this actually scratches the shell.
Rinse well, and drip dry upside down so the water comes back out. Do not dishwash.
Try this and see if this works.
Posted on May 26, 2008
SAYS COFFE READY PUSH LARGE CUP AND A COUPLE OF DROPS COME OUT THAN SAYS FILL AND PUSH STEAM HAVE DONE AND REDONE SEVERAL TIMES STILL NOT GETTING A CUP OF COFFEE TOOK TANK OUT AND CHECKED FOR FLOTATION IT...
Hello.
1 Perform the initial setup on the coffee maker. Make sure the coffee maker is not plugged in. Slide the empty funnel into the funnel guides, fill the decanter with cold water, open the lid and pour water from the decanter into the brewer, put the decanter back on the base, then close the lid and wait three minutes for the internal tank to partially fill. Open the lid, fill the decanter with cold water again, and once more pour the water directly into the brewer. Put the decanter back on the base and wait for water to flow out of the funnel and into the decanter. Once it has stopped flowing, pour out any water that is in the decanted and plug in the coffee maker. Press the on switch to turn the coffee maker on and heat up the water in the tank.
2 Ensure the lid is completely closed. If the lid is open, the Bunn coffee maker will not brew coffee.
3 Check the see how much water is in the water tank. The Bunn coffee maker will not begin brewing coffee if less than 20 ounces (4 cups) of water is present in the water reservoir tank.
4 Delime the coffee maker. Unplug the coffee brewer and allow it to cool down. Remove the sprayhead by turning it by hand and set it aside. Insert the flexible deliming tool into the sprayhead tube until all but two inches are showing. You may need to twist and force the tool to go in. Slide the tool in and out several times to loosen lime buildup.
Check the sprayhead for lime buildup. If there are flakes of minerals, they can be removed with a toothpick. Scrub the sprayhead with soap and water. Rinse the sprayhead with water and replace it in the coffee maker. Pour water into the water tank and turn the coffee maker on, allowing water to run through without making any coffee. This will flush any lime fragments through the system. Empty the decanter
Thanks.
Sep 18, 2011 | Jura Capresso Impressa S90 Espresso...
How do you clean coffee maker?
Start a cycle and run 4 ounces of white vinegar and 16 ounces of water through the coffee maker.
May 29, 2011 | Bunn NHB Coffee Maker
Cleaning mr coffee ecm3 how
Deliming
SUGGESTED CLEANING SCHEDULE
Type of Water Cleaning Frequency
Soft water every 80 brew cycles, Hard water every 40 brew cycles
Your espresso maker may be delimed using one quart of white household vinegar. Clean the water tank first, following steps l-5:
1. Make sure the steam control knob is in the center off position and that the plug is disconnected from the electrical outlet.
2. If the machine is cool and the pressure has been released, remove the pressure cap and pour 10 ounces of undiluted white household vinegar into the water tank.
3. Screw on the pressure cap and allow machine to sit overnight with the vinegar solution in the water tank.
4. Remove pressure cap and discard vinegar through the top opening of the espresso maker.
5. Rinse the water tank thoroughly with tap water, repeating this step twice.
To wash internal parts:
Make sure you clean the inside of the water tank first. Remove the pressure cap and pour 10 ounces of fresh white household vinegar into the water tank. Screw the pressure cap back on top of the water tank. Make sure the cap is on tight. Insert the filter holder into the brew head and place the glass decanter with lid on the drip tray. Plug the machine into the electrical outlet and turn the power switch on. An indicator light on the power switch will tell you the machine is on. Place a cup with cold water under the steam nozzle. When vinegar begins to flow into the decanter, insert the nozzle into the water and open the steam nozzle slowly by turning the steam control knob downward. After a few seconds, close the steam nozzle by turning the knob back up to center. This will clean any residue left in the nozzle from frothing milk. When all the vinegar has been pumped into the decanter and the flow has stopped, turn the power switch to the center off position and allow the machine to cool. Repeat steps 1-7 twice using only tap water to rinse any remaining traces of vinegar out of the machine.
Decanter cleaning
1. Pour warm white vinegar in the decanter and let soak for 20 minutes.
2. Discard the vinegar, Wash and rinse the decanter thoroughly using a
soft cloth. Do not use harsh abrasive cleaners.
Dec 12, 2010 | Vacuums
Mr. Coffee coffee maker replacement decanter NOT available ISD 17
I am in your boat! I have been searching for ISD17 for my dust collector, for 3 months now. I have called Mr Coffee, they told me the item would be available August (end of) and nothing. If I hear anything of find I will for sure come back and post! Although it doesn't solve your problem, I just thought you would like to know you are NOT alone.
Jul 20, 2010 | Coffee Makers & Espresso Machines
Can a replacement decanter be obtained??? for a bt10b
Yes- any reputable Bunn dealer or repair depot should have a replacement decanter for this unit. For a list of repair depots in your area, go to www.bunn.com,
Oct 29, 2009 | Bunn BT10B Coffee Maker
The coffee maker over flows with coffee
You might have to reprogram the brew level. Does it over fill the decanter or is is over flowing from the brew basket?
If from the decanter then reprogram, there are instructions behind the front panel.
If from the brew basket then adjust coffee grind and or volume, also check and clean the sprayhead.
Jul 14, 2009 | Bunn CWTF35-3- Stainless Steel
Bacon grease in my bunn coffee pot
Did you let the vinegar mix with the hot water in the tank for 2 hours? If this didn't fix the problem, please call 800-352-2866 with the model and date code and we will be happy to assist you with this problem.
Mar 29, 2009 | Bunn BCW Coffee Pot and Decanter Warmer
Kenmore Dishwasher - stops cleaning dishes - 2 techs just scratch their heads - any suggestions? water is hot, changed soap, still not even coffee stains inside cups are cleaned, let alone the rest.
ensure spray arm holes are not blocked, the water level is good, the spray of water is strong, it is heating and the tablet is entering the wash, not much else can cause a bad wash. note dishwasher may not always be able to get rid of some coffee stains.
Mar 04, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
How do I make coffee with a Grindmaster Pourover Coffee maker?
COFFEE PREPARATION PROCEDURES
1) Place filter into brew basket.
2) Put the proper amount of coffee into the filter.
3) Slide the brew basket into holder.
4) Place empty decanter on warmer located directly under the brew basket and turn corresponding warmer switch ON.
5) Pour decanter of fresh water through pour-in opening at top of brewer.
6) Hot water will be delivered through the sprayhead. This distributes the hot water evenly over the coffee bed within the brew basket. The coffee will drain from brew basket into the container below.
7) Red light indicates warmer is ON.
8) Before brewing next pot, remove brew basket from brew rails and dump filter into waste basket.
Please rate this a fixya
Feb 08, 2009 | Grindmaster Pourover Brewer - 18
Coffee is not flowing thru system
you anti leak valve or leak stop in the bottom of your filter holder is broken. You can pull it out with no problem . Leaving you with no drip stop but your coffee will go into you decanter
May 25, 2008 | Cuisinart 12 Cup Digital Thermal Coffee...
Bunn BT10B Coffee Maker Logo
67 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
