Question about Casio G-Shock GW500A-1V Wrist Watch
Setting prolem how can i cannge form 24 hour format to 12 hours i have casio 1289 g-shock
All you have to do to set the watch from 24h to 12h is press the adjust button-the seconds flash-now press the g button/light and that switches to 12h-then press the adjust button and it,s done.
Posted on Oct 28, 2008
  • robbiezee33 Apr 16, 2012
    Thanks! You answered the question succinctly and clearly...problem fixed. The question wasn't how to obtain the Casio G-Shock manual; though some may want it.
  • Casio Master
  • 13,433 Answers
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
Posted on Jun 09, 2008
    Else, though your answer is useful and certainly an attempt to be helpful, you didn't answer the question that was asked. Solution two on the other hand, does just that.
12 hours early
Try this:-
First set the watch to 24 hour format rather than 12 hour format.
Nov 05, 2013 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Can not change from 24 hours mode to 12 hours mode on CASIO DW9052-1B
1. Press [A], the top left button, and the seconds should start flashing 2. Once you have some digits flashing, press [D], bottom middle button, and will switch between the 12h/24h formats 3. Wait a few seconds and the digits should stop flashing and return from the time set mode, to timekeeping mode.
Here is a link to a manual directly from Casio, showing you all of these steps. As per the explanation on top of the manual, this should work with 3 different models of Casio watches, including yours. http://ftp.casio.co.jp/pub/world_manual/wat/en/qw1659.pdf
Have a good day
May 06, 2011 | Casio G Shock DW9052 1V Illuminator ...
How do I change 24 hour time to 12 hour
You have to press the ADJUST button then you hold down the MODE button and while you are holding down the MODE button press the G (illuminator button)
Jan 27, 2011 | Casio G-Shock Classic DW6900-1V Wrist...
I dont know how to set it to 12 hour. for my Casio G-shock 1289 DW-6900CB
Press the "adjust button" until display flashes.By pressing "mode" button
go to 12/24h setting.Press the lower left button to switch between 12/24h.
When finished press the "adjust"button again.
Jan 21, 2011 | Casio G-Shock GW500A-1V Wrist Watch
I have a g7900 gshock watch. on the little manual says toggle 24 hour/12 hour i have to press button D, but it didnt work out. i want my time to be on 12 hour format. please help me with the steps.. thank...
Bottom right button will change watch from regular time to military time. Just one push is all it takes...if you have the g-9700 the button color is red...hope this helps.
Jan 09, 2011 | Casio G-Shock GW500A-1V Wrist Watch
How to adjust the time on a CASIO W-59 watch
Hi Harry,
Your Module number is 2271.
1. To set the time, press and hold button A (left top) until Seconds digits start to flash.
2. Press button D (lower left) to move flashing in the following sequence to change other setting:
Seconds >> Hour >> Minutes >> 12/24 Hour Format >> Year >> Month >> Day >> (Then back to Seconds)
3. While a setting is flashing, use E (+) (bottom right) and B (-) (top right) to change it.
Note: When in the 12/24 Hour Mode, use E and B to toggle between 12-Hour and 24-Hour Mode.
4. Press buton A to exit setting screen.
Your time should now be set.
You may also download a manual for watch/Module number:
http://pathfinder.casio.com/resource/manuals/module_2271.pdf
This should give you all the info you need to operate all the functions of your watch. Thanks.
Regards, Bill
Sep 27, 2010 | Watches
How do you set a g-shock's time from 24 hours to 12 hours?
mcdevito75 here, You should be able to thru the MODE button. Best Bet, contact Casio at 800-706-2534 Optn. 2 hope this helps.
Jul 12, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
I have a casio 2747 and i am having setting the time digitally because i dont want military time and it refuses to change plzz help me
On the Casio 2747 you can easily change between 12-hour and 24-hour (i.e. Military time)... Follow these steps:
1. Make sure you are in Timekeeping Mode (i.e. digital display shows date at the bottom).
2. Press the "D" button (i.e. bottom-right button) to toggle between 12-hour and 24-hour timekeeping.
Note: 12-hour timekeeping mode will display an "A" or "P" for AM and PM.
Mar 10, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
How to change from 24 hour to 12 hour on g shock
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Feb 18, 2010 | Casio G-Shock GW500A-1V Wrist Watch
How do I change my Casio twin sensor alti thermo watch from 24 hour to 12 hour format?
Press and hold the top left button for 2 seconds to go into the time adjustment mode.
While you are in this mode press the top right button to switch between 12 hour and 24 hour modes.
Press top left to return to normal.
Oct 09, 2009 | Casio Watches
Casio G-Shock GW500A-1V Wrist Watch Logo
351 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
