Yamaha YAS-70 speaker remote problems
I can not change the "sound field program" mode to other modes (music/movie/sports/game). Also the DEC. MODE button doesn't work. It worked when I first hooked up the system. All other buttons work. What have I done wrong and how do I fix it.
  • magnus72 May 05, 2009
    Same problem here. Sound field buttons, EQ and dec mode buttons not working.
Same issue here.
Posted on Mar 08, 2011
I want to set the receiver to surround sound. The indicator only shows two speakers I want it to show five
What is the source of your sound? By default, receiver will use only those channels that are used in the input signal - if you play CD in stereto, it will use only 2 front speakers. If you play DVD with 5.1 audio, it will use all 5 speakers (+ subwoofer if you have one).
However you can use one of the bulitin "sound field program" modes to mix the 2 channel stereo music to all speakers. On front panel, press "PROGRAM < >" buttons to select the one you like. Or on remote control, repeately press MOVIE, MUSIC or STEREO buttons. You can check your manual for description of each sound field program.
Oct 11, 2014 | Yamaha RX-V661 Receiver
Yamaha RX-V575 sound issue
try other sound settings first, eg music, stadium, games, all the other sound options. if same results your centre speaker could be gone. or you need to increase the volume of the centre speaker in setting mode. do this first before assuming the speaker is no good. hope this helps
Mar 29, 2014 | Yamaha RX-V575
YAMAHA SOUNDBAR PROTECTIVE MODE
Have the same problems, look's like protective mode, yes......
Contacted the dealer, probably i have to return this one and get a new.When i get any answers i will post theme here.
Jun 24, 2012 | Yamaha YAS-101 Front Surround Sound Bar...
Yamaha Rx-V367 Subwoofer not working, I have new Polk Audio PS10 hooked up with Y-Adayer and Subwoofer Cable to Subwoofer Jack on backn of receiver. No sound in Radio mode which other 4 speakers work, in...
Have you looked at the manual?
The NEW thing doesn't work.
Does the subwoofer work for setup? That would certify the hardware and speaker definitions are ok.
The PC has the responsibility for defining and sending out something between headphone and full-blown 7.1 though the HDMI. Check your PC sound controls and the "Information on HDMI" section of the manual.
For the radio mode, probably the only analog stereo source you have, read up on the STRAIGHT decoding mode and Sound Field programs.
May 08, 2011 | Yamaha RXV367 Receiver
My home theatre was connected successfully playing the cd movie, but after turning off the dvd and go back to watching tv the sorroung system speakers do not give a sound to the television. is it that i...
hi,
select tv input on ur theater system. u can hear audio fro the frond left and right speakers. if u want to hear the audio from the surround speakers, then press the A-MODE button on ur remote to select different type of sound modes. press again and again to select different sound field. select one which suits u.
ok
Dec 27, 2010 | Curtis DVD5091 Theater System
Wiring speakers to amp for both 5.1 channel and 4 speaker listeni
I am assuming that you want to have a normal stereo ( 2 channel ) from, CDs, Radio Etc.. To be able to play from all of your speakers for a more surrounding sound experience, for parties or just more sound. I am also assuming you currently have your speakers wired like standard 5.1 in the bottom diagram on page 19 of your receiver manual. To change the way the sound is coming from your speakers you will need to refer to the “Sound Field Programs” part of your manual starting on page 52. You will want to be in the input source you would like to change “ie: radio” Let assume you want to change radio, once the radio is on; Rotate the “N” Program selector, (or press “5” and then “12” Prog < /> repeatedly ). You will want to change to program, “7ch Stereo” this should take your 2ch signal and send it to all connected speakers. If this does not work, please let me know.
Feb 23, 2009 | Cerwin Vega E-78 Main / Stereo Speaker
Surround sound
Hope this helps,
you need to press system menu on the remote..
on the front panel display acually on the DAV unit "DEC. MODE" appears..
Press enter..
Press the up and down buttons to cycle through the options, what your looking for is "PRO LOGIC", "PLII MOVIE" and "PLII MUSIC" ..
Select one of these and this should work.
All the best
Jun 25, 2008 | Audio Players & Recorders
Yahama Yas-70 Speaker System
I have the same issue
May 22, 2008 | Cameras
Sony kv 32ts36_speaker sound is distorted
the speakers can only be accessed from the inside of the set. try using the sound Field button on the remote ( the one with the music symbol). change to effects off it may be in surround mode and causing the speaker to buzz.
May 02, 2008 | Televison & Video
125 people viewed this question
 Grubhead
Grubhead
