Question about Cameras
Yahama Yas-70 Speaker System
I can not change the "sound field program" mode to other modes (music/movie/sports/game). Also the DEC. MODE button doesn't work. It worked when I first hooked up the system. All other buttons work. What have I done wrong and how do I fix it.
I have the same issue
Posted on Mar 08, 2011
Surround speaker is not working.
Make sure your receiver is in surround sound mode on the sound fields for that input. Some receivers have independent sound mode settings. example would be hdmi 1 is set to 2 channel stereo while hdmi 2 is set to PL II movie which is a surround sound setting. Hope this helps.
Feb 10, 2015 | Vizio Audio Players & Recorders
I want to set the receiver to surround sound. The indicator only shows two speakers I want it to show five
What is the source of your sound? By default, receiver will use only those channels that are used in the input signal - if you play CD in stereto, it will use only 2 front speakers. If you play DVD with 5.1 audio, it will use all 5 speakers (+ subwoofer if you have one).
However you can use one of the bulitin "sound field program" modes to mix the 2 channel stereo music to all speakers. On front panel, press "PROGRAM < >" buttons to select the one you like. Or on remote control, repeately press MOVIE, MUSIC or STEREO buttons. You can check your manual for description of each sound field program.
Oct 11, 2014 | Yamaha RX-V661 Receiver
Yamaha RX-V575 sound issue
try other sound settings first, eg music, stadium, games, all the other sound options. if same results your centre speaker could be gone. or you need to increase the volume of the centre speaker in setting mode. do this first before assuming the speaker is no good. hope this helps
Mar 29, 2014 | Yamaha RX-V575
How do i change the time on a columbia CL5055 its set an hour behind and i can not change it to the correct time!!!
hold down the set button until the display flashes. You may then cycle through the modes and fields to be set by pressing the mode button. The opposite two buttons (strt/stp / clr) are used to add or subtract to the field that is flashing or in set mode.
Sep 18, 2009 | Columbia All Sport Digital watch
Onkyo Tx SR606 Listening Modes "Not Available" Via Optical I have my Sky+ Box plugged directly into my TV with an optical cable from Sky box to my 606. I had no problems changing the listening modes untill...
check to see if the DIRECT icon is illuminated on the panel...if so, cancel the DIRECT function. This is only a thought, also check HDMI settings as well as optical mappings...
Jun 01, 2009 | Onkyo TX-SR606 Receiver
Wiring speakers to amp for both 5.1 channel and 4 speaker listeni
I am assuming that you want to have a normal stereo ( 2 channel ) from, CDs, Radio Etc.. To be able to play from all of your speakers for a more surrounding sound experience, for parties or just more sound. I am also assuming you currently have your speakers wired like standard 5.1 in the bottom diagram on page 19 of your receiver manual. To change the way the sound is coming from your speakers you will need to refer to the “Sound Field Programs” part of your manual starting on page 52. You will want to be in the input source you would like to change “ie: radio” Let assume you want to change radio, once the radio is on; Rotate the “N” Program selector, (or press “5” and then “12” Prog < /> repeatedly ). You will want to change to program, “7ch Stereo” this should take your 2ch signal and send it to all connected speakers. If this does not work, please let me know.
Feb 23, 2009 | Cerwin Vega E-78 Main / Stereo Speaker
Can not get 3 speakers on my samsung home theater to work!
There are a few settings that will just give you a stereo output. The first one is with the Pro Logic II. If you press the PLII Mode button on the remote it will go through a series of settings from MUSIC ➞ CINEMA ➞ PRO LOGIC ➞ MATRIX ➞STEREO ➞ MUSIC. Pro Logic setting will only produce sound from the front speakers and Stereo from the front speakers and the sub. Put it on Matrix for 5.1 surround sound.
Also for speaker settings follow the instructions below.
Signal outputs and frequency responses from the speakers will automatically be adjusted according to your speaker configuration and whether certain speakers are used or not.
In Stop mode, press the MENU button.
Press the Cursor down button to move to Audio and then press the ENTER button.
In the SPEAKER SETUP, press the ENTER button again.
Press the Cursor button to move to the desired speaker and then press the ENTER button.
For C, SL, and SR, each time the button is pressed, the mode switches alternately as follows : SMALL ➞ NONE.
For L and R, the mode is set to SMALL.
SMALL : Select this when using the speakers.
NONE : Select this when no speaker is connected.
Press the RETURN button to return to the previous level.
Press the EXIT button to exit the setup screen.
It also seems that with this system, if you are on 5.1 surround but your music source is only in stereo, you will only hear stereo.
Nov 20, 2008 | Samsung HT-Z310T Theater System
Surround sound
Hope this helps,
you need to press system menu on the remote..
on the front panel display acually on the DAV unit "DEC. MODE" appears..
Press enter..
Press the up and down buttons to cycle through the options, what your looking for is "PRO LOGIC", "PLII MOVIE" and "PLII MUSIC" ..
Select one of these and this should work.
All the best
Jun 25, 2008 | Audio Players & Recorders
Sony kv 32ts36_speaker sound is distorted
the speakers can only be accessed from the inside of the set. try using the sound Field button on the remote ( the one with the music symbol). change to effects off it may be in surround mode and causing the speaker to buzz.
May 02, 2008 | Televison & Video
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
