Question about Nintendo Wii Console
The video/audio outlet port is busted - Nintendo Wii Console
  • mward8107 Nov 22, 2008
    i have audio but no video
  • kat071407 Jan 02, 2009
    once wii has been in the a/v port, removed (to move to different tv), then later reinserted (to come back to previous tv), i have found that my video port no longer works on 3 different tvs where the wii was once plugged in. none of my plug and play games work now... the wii seems to have fried all three of my video ports on three tvs within a 12 hour period! ...any suggestions??
Okay..... nobody else knew what to do so heres what i did and it works. i bought an rf modulator. i hooked it up to the tv, bypassing the original a/v ports (the modulator has new a/v ports) turned the tv on to the channel i selected on the modulator, and now i have audio and video again.... not sure why my video ports went out in the first place (on 3 tvs-see prior posting by me) but at least we can play games now without buying replacement tvs. good luck!
Posted on Jan 02, 2009
How do i connect my dell latitude D610 to my Ilo tv?
Computers have become all-out media centers, capable of playing movies, music, and video games and even of streaming live television. Modern computers also come with an assortment of ports and outlets that allow easy connectivity to other devices, including televisions. Today's HDTVs can display high-resolution images ideal for showing off the media available on your computer, and they're relatively easy to connect.
Determine which type of cable to use; it will depend on which ports both your computer and TV share. Older computers and TVs will only have S-Video or VGA ports. Ideally, your computer and TV will both have HDMI ports, which allows for high-definition video and audio transfer. Consult your owner's manuals for port identification before deciding on which cable to use. Connect the computer's video outlet, either HMDI, VGA, or S-Video, to the TVs corresponding video input. These will usually be on the back of the TV and will be clearly labeled. Turn on your TV and set it to the proper video channel, which will correspond with the type of cable you have used. Some TVs have multiple ports for the same connection. Just set the video channel to whichever port you have used--for example, "HDMI 1" or "HDMI 2." On your computer, right click on your desktop and highlight "Graphics Properties," prompting a submenu to pop up. Highlight and click "Output to TV." Your computer's images should now be displayed on the TV instead of the monitor.
how to connect your PC or computer to a TV
http://www.online-tech-tips.com/computer-tips/how-to-connect-your-laptoppccomputer-to-your-tv/
Feb 22, 2013 | Computers & Internet
Want to get my pc on tv
I have audio but no video whyen a disc is
Turn off all devices in the video chain, INCLUDING your Xbox.
Unplug and re-plug ALL connectors, making certain that they all go in all the way.
Turn on everything.
If that does not fix it, then something is busted.
Remove anything between the TV and the Xbox and try it again.
If that does not work, either the TV or the Xbox is busted.
Try hooking up a DVD player to the SAME EXACT TV input.
If that works, your Xbox is busted, go buy a new one.
If that fails, go buy a new TV or try using another input on that TV.
Feb 07, 2010 | Microsoft Xbox 360 Console
Completely dead. I disconnected and reconnected to another outlet and still dead.
Hi
Chances are the port for the power outlet or the power supply of your printer is busted. If you can try a different cable for the power cord, that's one option that you can do. Hope this helps
Jan 08, 2010 | Office Equipment & Supplies
Proton model 300 AM/FM stereo tuner
IF nothing lights up and you are sure that the power outlet is working correctly (some power outlets are wired to be switched on and off by a wall switch so be sure that the power source is NOT the problem) then you may be busted. Check for fuses; I dont know this specific unit, but most power amps have some sort of inline fuse. If that doesnt get it, I would call PROTON and have them send you a new one.
r
Sep 21, 2009 | Pioneer VSX-54TX Receiver
RCA audio system,and three disc. autio radio works , but the three dicc player will not play any audio discs. I think the tuner is out of programing. Haveany suggestions. it is a am fm radio and compact...
I always encountered that kind of problem,the audio works but discs player not working.This kind of a problem of a disc player had three causes,first the lense is busted already secondly the MPEG MEMORY IC is busted,thirdly the roller that's moving back and port bringing the lense set stock up full of dirt this is most common problem.That why whateveryou did is not functioning.If you know how to open your unit it's better. First you do is to clean the roller with the use of a lighter fluid to take the old greases that already harden with dirt. After that all is clean put a first class greases type-A only little to the roller and wipe the lense with a cotton buds. If all this procedure nothings happens,you better change the lense with desame code number, to avoid conflict.If the lense is change still not functioning that's the time you change the MPEG memory IC.I assure it to you it's works 100%.
Jun 15, 2008 | RCA Audio Players & Recorders
Nintendo Wii Console Logo
75 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Troy Gorman
Troy Gorman
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
