Question about HTC Touch P3450 Smartphone
HTC touch When I get an incoming call my phone does not ring until I wake it up then it flashes incoming call and goes right to notification please help
  • 3 more comments
  • dave_55 May 22, 2008
    satya258
    thanks but that did not work
  • SusieCase May 22, 2008
    Exactly the same problem. Does not come out of sleep. So you end up missing calls. The callers say it rings like normal, then dumps into voicemail.
  • dave_55 May 24, 2008
    its a software issue HTC is aware of problem nooooooooooo fix
  • Anonymous Jun 10, 2008
    My HTC Touch P3450 is not ringing sometimes when others try to contact me. So the call goes unanswered. But the caller can hear the dialing sound.
    Please help me out. Please mail me any soluions to tnirmalkumar@gmail.com
  • 321mehelp Sep 22, 2008
    Same exact problem.When getting an incoming call phone does not wake up and I miss the call.
I have the same problem with the phone. Any solutions out there?
Posted on Jun 09, 2008
Software update coming soon end of June fixes a lot of these issues
Posted on Jun 08, 2008
Does not do the trick. I'm wondering if it's just an issue with the power switch. Defective phone.
Posted on May 23, 2008
  • 3 Answers
Go to settings --> sounds n notification --> notification tab --> check the play sound checkbox and checkout which ringtone is assigned,
Posted on May 22, 2008
My htc hd2 wont ring or vibrate even after i have did a factory reset
go to settings, then press the menu button so you go to all settings, tap sounds and notifications, then along the bottom tap notifications, then from the event drop down list select "phone: incoming call" and then on the ring type drop down list select "vibrate and ring"
that should do it ;.)
Oct 12, 2010 | HTC HD2 Smartphone
How do i put ringtones on my htc/6900
It's really simple, just drop the mp3s in the windows/rings folder and you are good to go
If you dont know how to set the ringtone go to Settings-Sounds & Notifications-Notifications and find phone-incoming call and change your ringtone
Dec 30, 2009 | HTC Touch P3450 Smartphone
HTC Touch Diamond will vibrate, but won't ring on incoming calls
I just had this problem - and I have been messing with it for an hour.... but I finally fixed it - Try this - touch the speaker symbol on top (The system status window should pop-up) then touch the speaker symbol again (Now you should have two tabs - one for system and one for ring) Touch ring and slide it up. This worked for me.
Aug 02, 2009 | HTC Touch Diamond Smartphone
HTC Touch doesnt ring on incoming call
Hi. First thing, you can check your sound settings, by tapping Star Menu, then Settings, then Sounds & Notifications, and through that page, you can check if your incoming call alert is on (just sound, or vibrate and sound), you can try to change the ringtone to see if your current ringtone is damaged or not. (Since other sounds are alright, there shouldn't be any problem in your hardware or in the sound volume levels) Hope this helps.
Jun 14, 2009 | HTC Touch P3452 Smartphone
Phone doesn't ring, but other sounds fine
:) Sometimes happens to me also. I faced a similar problem before, I think one of the installed programs on your device does it, I couldn't remember the name of the application now but whenever I launch it, my phone sound goes to minimum, Just to let you know. Have a nice day.
May 21, 2009 | HTC Touch Cellular Phone
Phone doesn't ring for an incoming call
pls reset ur device for some reason the call handling software has been corrupted dont worry just backup ur data and reset the device as follows
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
if not solved then go to www.htc.com for latest Rom update download and update backup ur data first
pls rate me fixya if i solved ur problem
Feb 28, 2009 | HTC P4350 Smartphone
HTC Touch Pro T7272 - Sound problem
go to htc.com and download the last rom for touch pro and it will be fine!
NB: I downloaded the arabic rom wich have two features
1- on the first Installingthe rom is english
2- As u can active arabic, you can also disable it if you are foreign users but it will be better to install it without acivating arabic (case 1-)
Link: http://www.htc.com/mea-en/SupportDownload.aspx?p_id=140&cat=2&dl_id=516
Jan 07, 2009 | HTC Touch Pro Smartphone
You may have already done this, but the first step is to check your various settings.
Go to Start > System Tools > Settings
First, go to the "Profiles" menu and make sure your phone is NOT in Silent mode.
Then, if your phone still isn't ringing, go to the "Sound" menu and make sure your Ring tone and various other sounds are set appropriately.
Finally, you should try turning off and on your phone and seeing if this corrects the problem.
If none of these tasks work, there may be a hardware issue with your phone and you should bring it to your carrier's local store and ask them to fix or replace it.
Aug 04, 2008 | Samsung SGH-D500 Cellular Phone
try installing this Hotfix
http://www.htc.com/us/SupportDownload.aspx?p_id=88&cat=0&dl_id=101
Hot fix for resolving ring tone and system sound loss problem in HTC Touch Date: 2008-08-28     CategoryHotfix
In some cases, there may not be any ring tone and system sounds on the HTC Touch when the device has not been soft reset after a few weeks of usage. Performing a soft reset will resolve this problem. You can also download this hot fix and install it on your device to prevent this problem from reoccurring.
May 26, 2008 | HTC Touch P3450 Smartphone
HTC Touch P3450 Smartphone Logo
192 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
