Question about Maytag PDB3600A Built-in Dishwasher
Dishwasher detergent door won't release soap
Hello, I own a Kenmore dishwasher, model 665.1677580 and the detergent door won't open to release the soap. The detergent cup and door are clean, the dish rack doesn't interfere and the door uses a bimetal switch. Any tips on how to test the switch or a timer?
Thanks,
Bob
  • 1 more comment
  • LYB923 Jun 25, 2008
    I have a Kenmore with the same problem (not sure of model).  I was blaming the detergent.  Have you found a solution?
  • llchildress Oct 07, 2008
    I also have a Kenmore with this problem--and it's driving me crazy! Even when I pre-wash most everything I'm having to rewash most of the top rack anyways because I think it's spraying around a lot of dirty water and no soap. And of course, my warranty ran out about 1 week before this started and I declined renewel. Has anyone tried replacing the detergent dispenser?
  • Anonymous Oct 19, 2008
    Same problem, different manufacturer. Can anyone tell me what opens the detergent powder door during the wash cycle?
It could be as sinple as a broken sring that forces the door open. If the door will not hold itself completely open, that is possibly the real issue.
Posted on Nov 18, 2011
There's an answer at: http://www.partselect.com/dishwasher+cup-wont-open+repair.htm.
Pretty in depth, but not a simple fix.
Posted on Aug 06, 2010
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: dishwasher detergent door won't release soap
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
l
Posted on Sep 30, 2010
My Asko D1716 dishwasher works fine apart from the soap dispenser. It won't open to release the soap.
Most likely it's a corroded door catch or a bad solenoid. Hopefully it's not the main control board. You'll need a repair manual or technician. A work around would be to use detergent tablets in the compartment
Mar 02, 2012 | Asko D1716 Built-in Dishwasher
I have a Kenmore Quiet Guard 2 (model 16994400) and the soap door doesnt open during the washing cycle.
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
heatman101
Jan 05, 2011 | Kenmore 24 in. 15932 Built-in Dishwasher
Detergent door does not open, it completes cycle without using the detergent
  1. The most common problem with the detergent doors on KitchenAid dishwashers is that they either don't open during the cycle or open only halfway. Before looking into more complicated repairs, make sure that the door is able to open. Check the seal around the door and the door latch for soap- and food-related gunk, and scrub it off if present. Sometimes this can keep the detergent door from operating properly. Consider switching detergents, as some liquids and pouch-style dish detergents can gum up the detergent dispensers. Also, make sure that there is nothing blocking the detergent door when the dishwashermag-glass_10x10.gif is loaded. Because of the location of the detergent door, a large item such as a cookie sheet or a pan can prevent the door from opening. Run the dishwasher through a cycle without anything placed in front of the detergent dispenser and see if that solves the problem.
  2. Broken Timer
  3. KitchenAid dishwashersmag-glass_10x10.gif rely on an internal timer to complete the wash cycle properly. When this timer malfunctions, certain steps in the wash process (such as the release of soap from the detergent dispenser) can be interrupted. If the dishwasher detergent door is either not opening or appears to be opening late in the cycle, this is likely the mechanical culprit. A broken timer isn't something that's simple to replace without knowledge of dishwasher repair, so it's best to consult a professional if you suspect that this is the problem.
  4. Malfunctioning Door Components
  5. For the detergent door to function properly, all of its mechanical components must be in working order. Older dishwashers' detergent doors rely on a spring-loaded hinge to pop all the way open when the timer gives the signal. If the door doesn't swing all the way open instantly when it's manually released, the spring may need to be replaced for the dispenser to operate properly. If the particular model is newer and does not rely on a spring to open the door, chances are it either uses a wax motor or a bi-metal switch to release the detergent door at the appropriate time. If either of these components is dying, that can mean that the detergent dispenser will not operate properly.
thank you
vijay(vote for me)
Sep 23, 2009 | Kenmore 24 in. 16539 Built-in Dishwasher
heatman101
l
Apr 06, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Small door where soap goes does not open during cycle.
Most detergent cups are spring loaded and released by either a mechanical trip or by a bi-metal strip latch. If your model is a simple dial timer type, look for a mechanical linkage between the timer and detergent cover. If it is a touch panel control, look for the other type. The bi-metal strip type has a heating wire wraped around it that can open electrically or burn out physically.
Mechanical types can be checked by rotating the timer knob 360 degrees while watching the detergent cover linkage. Electrical types require use of an ohm meter to check the resistance of the heating element on the bi-metal strip.
If you are using powder type detergent, make sure it is not caked when added to the cup or it can jam the rotating type covers.
Feb 15, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
The detergent door doesn't open
Please reply your exact model number so we can see what the door looks like.
Jan 23, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Kenmore 16163 401 dishwasher
The dispenser flap should be spring loaded to spring open if the lock is released. If it doesn't spring open you should make sure that the spring is placed correctly on the hinge of the flap - if it doesn't spring open it won't get the detergent where it needs to go during the wash. We had the same thing.
Dec 17, 2008 | Kenmore 24 in. 16163 Built-in Dishwasher
Rinsing detergent from dispenser
Use gel run a few cycles and help clear and then don't overfill w gel soap
Nov 13, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
I have a kenmore dishwasher. the soap dispenser lid was not opening and releasing the soap, now the lid is opening but it's leaving the soap in the dipenser. have used the pellets that contains the liquid...
disasemble the pump housing and remove the debris that are located in the housing, not enough pump pressure to spin the spray arms to desolve the detergent
Apr 09, 2008 | Dishwashers
Soap door won't open
The detergent cup itself can become clogged with old dried detergent that prevents it from opening. Sometimes just cleaning the cup takes care of the problem. In case it will not solve your problem, the unit should be replaced. Good luck!
Sep 13, 2007 | Kenmore 17252 Free-standing Dishwasher
Maytag PDB3600A Built-in Dishwasher Logo
2,573 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
