Question about Kenmore 98702 Stacked Washer/Dryer
Washer lid will not open after cycle
The lid latch will not release after the cycle has finished. We tried busting it open, but nothing has worked. Any ideas? Thanks!
  • cvj75 May 22, 2008
    thank you so much!! i had a HUGE load of clothes in there and was worried they'd stink forever! i'm going to have someone else come do the electrical...
    Genius:
  • 1,028 Answers
Suspect bad lid latch there is usually a 4-6 delay after washer stops before latch will release anything much longer proably lid lock ..remove 2 screws bottom front panel front drops and comes off switch is on right remove screw each side of top lift up 2 screws hold latch in place remove wires and screws and replace latch
Posted on May 22, 2008
Bosch logixx 8 sensitive
first off never ever kick the door closed, this is not a toy. having said that look below the door you should a lower panel, remove this panel and you will see your lint filter but take that as water will run all over. just to the side you should a tab hanging down. pull on this tab it should release the door, if not try and unplug your washer for a couple of minutes and see this will reset the board, then just turn the dial to any cycle but don't push start button wait a few seconds it should release. let me back up a little your washer may have a small round cover on the lower panel, if does take this off instead of the panel you will still see the tab sticking out. i hope this helps, if these tips do not open your you may need to call for a service rech.
Jan 12, 2014 | Washing Machines
Lid is not locking properly, washer sensor is overfilling, and the washer wont spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Pl click if helped.
Apr 28, 2013 | Whirlpool WTW4950XW Washer
Wont drain and spin
Pl click if helped.
Apr 17, 2013 | Whirlpool WTW4950XW Washer
Whirlpool Wfw9050x will not advance to spin cycle
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. Or
http://www.youtube.com/watch?v=TB_W6sPdzkM
Pl click if helped
Apr 08, 2013 | Washing Machines
Kenmore washer front load 417 wont spin
Click if helped
Feb 18, 2013 | Kenmore 24032\24036 Top Load Washer
Door on WD420 will not open
There is an electrically controlled lock on the door that prevents opening while the machine is in operation, and sometimes for a short period after a cycle has finished.
Sometimes this lock can get stuck and requires some persuasion to release.
This may sound odd but try it:
Make a fist with your hand and bang the door, near the latch, with the side of your fist. Do this firmly, but obviously not so hard that you will damage the door or, more importantly, your hand. This can often release the latch that should have released automatically.
Apr 07, 2010 | Hotpoint Aquarius WD63 Front Load...
Aquarius 1100 - door won't open
lift lid of top reach to front and pull the wire cable up to the door latch make sure u unplug machine first
Sep 07, 2009 | Hotpoint Aquarius WF220 Front Load Washer
LID WON'T LATCH ERROR CODE FL
With that code FL “ Failed to lock” I would start looking at the lid latch mechanism. See this link from another site for lid latch problem.
http://fixitnow.com/wp/2006/09/06/maytag-neptune-fav6800aww-top-load-washer-op-code/
If you want to try to repair or get a better understanding of how to diagnose and repair this machine take a look at the service repair manual.
http://www.servicematters.com/maytag_library/docs/16022808.pdf
I hope this will help with your decision to try a repair or replacement.
Good luck with your issue.
Jan 02, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Door won't open
you can take the 4 phillips screws out of the corners of your soap dispensor, the lid of the dispenser willlift up and youll see wrapped around in there eitehr a floresent green or orange plastic wire. that is a manual release cord for the latch assy. this will allow you to get your clothes from the machine, form there look into why the latch never released
Nov 17, 2008 | Maytag Neptune MAH5500B Front Load Washer
Top loading washer door locked
check the panel for triped breakers - check the plug for the washer - the door latch usually release itself after fewhe latch minutes- if nothing works try to force lid open with a thin screwdriver from the side were the door latch is
Sep 14, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 98702 Stacked Washer/Dryer Logo
297 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
