Question about Canon DC100 DVD Camcorder
Initializing DVD-RW Discs
When I turn on my DC100 it tries to initialize the disc on its own, but then says error or can't read disc. If I go to menu and try to click on initialize manually, it will not even come up with options. Is there anything to do or try? Should I try a few brands of discs, or should any work?
THanks
Dan Stetzer
  • Nupz Sep 08, 2008
    I did plug into the wall and did that.... But it does not even work that way... What nxt?
  • Anonymous Dec 24, 2008
    cannot remember how to initialize disc
  • 4 Answers
This camcorder only takes DVD-R and DVD-RW, it will not work with the +R discs. I've used Maxell and Fujifilm discs and they both worked fine. You have to make sure the camcorder is plugged in the wall when initializing or else it won't initialize.
Posted on Jul 14, 2008
    New Friend:
I to am having the problem years later with the DC10 not initializing disc. It is very frustrating after following directions, replacing the expensive battery and buying different disc to no avail is this camera accepting the dvd-r disc. If anyone can help it would be most appreciated.Thank you
Posted on Mar 04, 2013
Nec dvd rw nd-3450a write error
Open the dvd writer & clean the pick up lens with ethyl alcohol or isopropyl alcohol by using cotton swab.
Nov 24, 2011 | Dell Computers & Internet
The dvd wont initialize blanc discs so that i can record with it.i have used different disc as well
Do you mean it won't format/initialize the disc? Alternative possible problem, when you put in a disc, does it not recognize that a blank disc is in the unit? Only DVD-RAM discs need formatting. DVD-RW discs need to be initialized. DVD-R disc do not need either formatting or initializing. (This unit does not write to DVD+R or DVD+RW discs.)
In the case of DVD-RW discs that can't be initialized. Check if this has already been done (or if you need to unfinalize the disc).
If the new disc is not being recognized as a blank disc, the recorder may not be recognizing the disc (dirt, scratches or manufacturing issue) or the recorder is not focusing on the disc properly. In the first case, clean the disc or try a different type of disc (Samsung claims that their discs will be most compatible). In the second case, the unit may need service.
I hope this helps.
(usually tracking and focus problems will be seen on both recording and playback (even with commercial discs).)
Oct 30, 2010 | Samsung DVD-R155
I just bought new discs for my Canon DC100. The
It's possible that, for some reason, the disks aren't compatible. It can almost drive you crazy trying to figure out why. To find out for sure if this is the case, try some new Panasonic discs, with the same specifications as the old ones that worked, and see if they work. If they don't work, you're probably having a dvr issue with the laser lens or related parts within the camera. There are many issues with dvrs that develop over time, requiring replacement parts and service. In those cases, it's usually better to get a replacement camcorder. The new HDD camcorders are immune from a lot of problems inherent with dvr and tape recorders.
Apr 18, 2010 | Canon DC100 DVD Camcorder
My recorder has stopped accepting NEW DVD-RW discs and ejects them. There is no problem loading DVD-R (new or recorded)or loading previous recorded DVD-RW, initializing and re-recording I have tried...
I had the same problem. After trying several brands, the only one which is working perfectly is Maxell (yellow discs). I found them is the US (Seattle), have not seen them in France where I am leaving. Hope it can help !
Nov 08, 2008 | Pioneer DVR-5100H DVD Recorder
No disc read on dc100
There are only 4 possible solutions,
1. Dirty or faulty discs, but as you've tried different discs this doesn't seem likely.
2. Condensation has developed in the camcorder, leave it in a dry indoor temperatured place for a couple of hours and try again.
3. Dirty lens won't let the laser read the disc. Look for lens cleaning camcorderkit in a store.
4. Manufacturing error
Hope this will help you.
Jul 14, 2008 | Canon DC100 DVD Camcorder
Delete
Unless you're using DVD-RW discs, you won't be able to delete any recordings. Changes cannot be made to DVD-R discs once they are recorded on.
May 02, 2008 | Canon DC100 DVD Camcorder
Recording
The device defaults to initializing discs to DVD-VR format. I believe this is incompatible for all devices except other DVD recorders. You need to reinitialize the disc to DVD-R format from the menu. These should then work in other players.
Mar 12, 2008 | Samsung DVDR120 DVD Recorder
Initializing disc
Yes - you're trying to initialise a +R DL.
Two problems
1. The DC210 only takes - format DVDs
2. You only need to initialise DVD-RW discs (see page 57 of the manual)
By initialising the DVD+R you have written to it once. having done that, you cannot write anything else to that disc. I find it easier to use DVD-RWs so that I can re-use them.
Good Luck.
Dec 01, 2007 | Canon DC210 DVD Camcorder
Loading DVD-RW discs
I have tried several different DVD-RW makes. Puzzling??
Nov 03, 2006 | Pioneer DVR-5100H DVD Recorder
Canon DC100 DVD Camcorder Logo
760 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
