Question about Mitsubishi VS-6043 60" Rear Projection Television
Outer screen for mitsubishi vs6043
Do you know where i can get one of these
  • laneysway May 28, 2008
    I did just that, from a magnavox and it looks much better than it ever did.
    Problem Solver:
  • 26 Answers
To be honest, most of those screens come as a whole unit, meaning both. I replaced my screen with one off of craigslist from someone parting out an RCA tv (www.craigslist.org, make sure to set it to your area) and even though it was a little bigger and I had to custom fit a few things, it worked great. The funny thing too is, places will tell you you need a diamond screen which you cannot buy, but if you just grab the screens out of another TV and throw them in,as long as you have both it will work just fine.
Posted on May 28, 2008
  • Emery Miller May 29, 2008
    Rear projection screens are always an easy fix, it's just getting your hands on one. Glad to hear you got it fixed.
Broken screen on model WS-55311 MITSUBISHI
If its the outer protective screen that u need I have one. I didn't like the glare it provided me with so I took it off. Email me remarkable14u at yahoo dot com.
Dec 25, 2013 | Mitsubishi WS-65809 65" Rear Projection...
Outer screen scratch
Mitsubishi is currently offering the following parts
Model Number Model Description Part Number Part Description Price Available WD-52631 52" DLP TV I/B WD52631 OWNERS GUIDE $15.00 YES WD-52631 52" DLP TV I/QR WD52631 QUICK/REF WD52631/57731/65731 'G' $3.50 YES WD-52631 52" DLP TV 915P049010 LAMP (150W) (V33/V33Y/V33+) 'G' $249.00 YES WD-52631 52" DLP TV 290P137010 REMOTE 'G' $33.10 YES
Mar 27, 2008 | Mitsubishi WD-52631 52" Projection HDTV
While Mitsubishi is off, have spots between inter-projector screen and outer
yes you can disassemble the front screen assembly to clean any spots dont use windex or streaking will result just a damp soft cloth then dry
Jan 02, 2013 | Mitsubishi WD-57733 57" HDTV
The screen shield of my mitsubishi HD 1080 diamond projection tv is scratched and shows rainbow color dots in some places. What can I do? Can I fix it? Replace it?
The outer screen on most models is clear and called a protective screen and prevents glare---if it has that it has 2 more screens behind it.
Getting at the outer on is not so easy---the entire frame for the screens has to be removed, the inner screens removed to get at the outer screen to remove it (if 3 screens you can do without the outer one except if it got scratched before--next will be the next screen behind it.
Check with mitsubishi to see if the screen that is damaged is available or not.
Oct 29, 2012 | Mitsubishi Televison & Video
The outer screen of my tv is cracked and i was trying to find out where i could order a replacement
Idealy if you contact Mitsubishi online they can issue a list of service centres that can supply a new screen. Otherwise, have a look at ebay, you may find a supplier there.
You will need to order the correct screen as it may be made up of two parts, an outer screen and an inner optical screen, depending on its production age.
Hope that helps.
Nov 23, 2010 | Mitsubishi VS-60601 60" Rear Projection...
I have a mitsubishi vs-60607. The outer screen was damaged during transport.. First, does the outer screen have a name or part number?Second can it still be purchased?
gona be hard
try the old white tooth paste trick
abit of soft scotch/rag with white toothpaste - scrub easly
should get it better
Dec 29, 2009 | Mitsubishi VS-60607 TV
Outer screen gouged on mitsubishi vs-55609
How were you able to remove the plexi glass screen? I have the same problem, but I don't know how to remove it!
Jan 17, 2009 | Mitsubishi VS-55609 55" Rear Projection...
6043 6061 parts interchange
Well, you can use most of the parts, except that the shape of the boards are different, so you cant exchange the entire board as such.
May 20, 2008 | Mitsubishi VS-6043 60" Rear Projection...
How do I remove the outer protective screen on my Mitsubishi WS-55315?
There are trim pieces around the edges that can be removed by sliding a knife underneath and lightly prying. They should remove fairly easily, don't force them as they may break. Use the knife on the cabinet side and pry toward the center of the screen.
The tear on the inner screen may be best left as is.
lexan would be better than plexi as it is tougher, but try to get anti-glare if possible. Anti-glare plexi would be better than regular lexan.
Feb 17, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Ripped outer screen
Trew Did you ever find a solution to your problem? I also need a TV screen. I lost mine the same way.
May 13, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Televison & Video Logo
80 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
