CAN I GET ASSISTENCE,TO INSTALL MY PRINTER,VIA INTERNET?
THIS IS APPLICABLE TO YOUR PRINTER THERE ARE THREE TOTAL SOLUTIONS
Driver_1.00.01.zip file and save to your desktop. Use a file compression software to unzip the file located inside MyBook_vista_windows7_Driver_1.00.01.zip to your desktop. You will now see a file called "MyBook_vista_windows7_Driver_1.00.01.exe" or "MyBook_vista_windows7_Driver_1.00.01" on your desktop. Double-click on "MyBook_vista_windows7_Driver_1.00.01.exe" or "MyBook_vista_windows7_Driver_1.00.01" to launch the driver installation program. The wizard will display a message saying that it is ready to install the driver, click Next. Accept the license Agreement and click Next Click Install to start the installation of the drivers. The driver will be installed without further interaction and should take only a few seconds to install. When the installation is finished, click Finish to close the installation utility. Reboot the computer system before connecting the My Book Essential or Premium Edition hard drive. After connecting the My Book Essential or Premium Edition hard drive, Windows will automatically detect the unit and a new hard drive icon will appear in the My Computer window. Your My Book Essential or Premium Edition hard drive should now be ready to use.
Here are the recommended steps to connect to a wireless base router 1. Check and remove power from both your router and the DSL ROUTER/CABLE ROUTER MODEM 2. Wait one complete minute until applying power to modem then wait one minute before applying power to wireless router. 3. Ensure you have green lights across both devices, specifically, the recieved and sent lights. These same lights will tend to blink rapidly when there is active data, at times this will still blink, and a DNS error will prevent you from connecting to the internet. If this is the case, call your ISP Internet service provider 4. Check your authentication Security key on your router first, then check all your wireless devices to ensure they are on the same network name, key, and channel with the same type of encryption as the router 5. Start one device at a time and check for connectivity, if your still experiencing a problem, check the settings on all your wireless adapters, device drivers, internet browser settings, firewalls and proceed. 6. still have problems, connect a rj45 cable from the router directly to your computer to at least see if your wireless settings are bad or if the router may be bad. 7. Contact your ISP to determine if your receiving singal 8. Avoid using a splitter or parital power backup for yours routers 9. Still having problems, change your wireless router only after your ISP changes their faulty modem 10.Attempt the same process when setting up your new wireless router and or modem
