Question about GE Spacemaker JVM1640SJ Microwave Oven
Fire in microwave
Microwave will not power up. control panel not lit at all. verified power to outlet, and replaced 2 20A fuses. still no power to appliance. if an interlock tripped (flame or high temp), would it automatically reset or does the interlock need to be replaced?
  • William Miller
    William Miller May 11, 2010
    An interlock is a door switch.
    It sounds like you may mean a thermal cutout or thermal fuse (which does not reset) or a thermostat which does reset.
    Assuming you have a model JVM1640 (if not, please reply back with your model number), then yours has thermostats, but they won't reset if they have failed.
    There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
    If you still need help, please reply back with your brand and full model number.
  • GE Master
  • 9,098 Answers
Seems like I've answered this one, too.
Two 20A fuses?? In a recent GE?
The interlock is a door switch, not a thermostat or thermal fuse. A thermostat will reset (unless defective) but thermal cutouts and thermal fuses are one-time devices.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 24, 2008
Microwave went totally dead while operating; there is power to the outlet.
If the control panel lights up intermittently, then you either have a loose connection somewhere near the panel, or a failing component on the circuit board itself.
Jul 10, 2015 | LG LMV1813ST Microwave Oven
Replace fuse
follow the next steps and fix it. use the VOM . God bless you
1. No power to outlet (overload or fault in microwave or other appliance).
2. Blown main fuse - likely due to other problems.
3. Open thermal protector or thermal fuse.
4. Defective controller or its power supply.
5. Clock needs to be set before other functions will operate (some models).f8629014-97b9-47e3-91bd-92cf0f66526b.gif
Jun 16, 2013 | Samsung SMH7178STD Microwave Oven
Kenmore microwave 911 41479791 no power?
see this causes and fix it. God bless you
No Lights or Power, Unit seems Dead First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.
Sep 24, 2012 | Microwave Ovens
No power to microwave
Hello
Check the Power Cord
Verify that the power cord is properly connected the outlet; the plug might have been removed to make way for another appliance. Do not connect the microwave to an outlet via an extension cord or plug adapter; the oven must be directly connected to an outlet.
Switch the Outlet on
Turn the outlet on, if possible, using the switch on the wall behind the counter or on the plug itself. Some microwaves have a separate power switch that must be in the correct position before you can begin cooking.
Reset the Oven
Unplug the oven, wait a few seconds and reconnect the power. A power surge could have temporarily rendered the oven inoperable. The oven should start up as normal when you connect the plug to the outlet.
Check the Fuses and Breakers
See that the fuse or breaker protecting the oven's circuit is still active. Replace the fuse if it has blown, or reset the breaker to restore power to the oven. Stop using the microwave if it repeatedly blows fuses or trips breakers.
Oct 04, 2011 | Microwave Ovens
GE MICROWAVE MODEL JVM1750DM1WW NO POWER AT ALL. HAVE ALREADY CHECKED THE OUTLET AND CHECKED THE BREAKER. ABSOLUTELY NOTHING WORKING.
If the microwave control panel doesn't light up, then your fuse is blown. unplug the microwave. unscrew the vent grill, (2) screws at the top of the microwave. then you should see 1 screw holding the control panel. after removing that screw, gently push up then out. there should be a metal plate on top of the control panel. remove that plate and the fuse will be in that opening. replace fuse and microwave should begin working.
Feb 09, 2011 | Microwave Ovens
No power on the unit. I have power at the outlet. Is there a fuse in or on the unit?
Yes, the microwave has a fuse behind the control panel. it can be purchased at a radio shack or a store like wise. Usually when the fuse blows, it's from a power failure or something inside the microwave getting to hot/overloaded and it will blow the fuse to prevent it getting to the point of catching fire. So my advise is, after changing the fuse and it happens to blow again, then you have an internal issue. Parts for microwaves are expensive and replacing it with a new one usually out weighs the cost of repair.
Dec 28, 2010 | KitchenAid KHMS155L Microwave Oven
Hamburger in foil wrap put in microwave - shorted unit out
Hi- The first thing here is safety. If the power supply is good- 120v at outlet- then address the fuse in the cabinet. Open door, remove screw(s) holding control panel, and tilt out panel. Fuse should be visible. Check for continuity. If bad, replace with 15amp appliance fuse. Plug in and check for operation. If fuse blows again, unplug and start looking at a new microwave. Let me know if this info helps. Have more if needed- Thanks- Ed
Mar 15, 2010 | Whirlpool MH6141XK Microwave Oven
No Power
HI, there is a inline fuse located inside the microwave ion the power supply board. check for continuity. replace the fuse if necessary. if the fuse is OK, replace the power supply board.
Jun 01, 2009 | Kenmore 62702 Microwave Oven
Microwave/small appliances do not turn on when plugged on to the power outlets on one wall.
What does "control panel has all fuses working" mean?
Are you saying you have an old-fashioned fuse panel in your house, instead of a modern circuit breaker panel?
If so, then I would suspect a bad connection in the panel.
If you indeed have breakers, a breaker can snap into the on and positions and still be bad.
Either problem sounds like it should be handled by a qualified electrician.
The power company or your insurance company would likely reimburse you for all or part of the electrician's bill, but you shoudl call first to be sure.
It's possible to have a faulty neutral connection in your wiring. That can lead to damage of several appliances and bulbs, and even pose a real fire or smoke hazard.
Please do not hesitate to get things fixed when you have home electrical problems!
Nov 04, 2007 | Samsung MW5351G Microwave Oven
Whirlpool GH518XP microwave hood combination Power off, wont come on at all
There are several parts which can cause the unit to be dead, mainly the fuse, thermostat, thermal cutout, or control panel. You can find critical safety info and disassembly tips ay my site via my listing here: http://tinyurl.com/yzjozk You can get handy exploded views and order any neededparts here: http://tinyurl.com/gv383 Not sure about that model number though - you might want to verify that.
Jan 20, 2007 | Whirlpool GH5184XPQ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
66 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
