Question about Mastercool 67680 Evaporative Cooler Air Conditioner
Replacing pads i forgot how to install the pads for my mastercool
  • Anonymous Apr 24, 2009
    I just finished replaceing the pads on my MasterCool.I went to Home Depot and bought some Aspen Snow Cool cellulose media replacement pads (MC63/MC64) 40W x 28H x 8D. Check the size of your pads before you buy. This site helpedhttp://www.kennspenns.com/coolerparts/ma...
How do I replace a rigid pad on my Mastercool swamp cooler?
Posted on Jun 14, 2010
    Problem Solver:
  • 8 Answers
You could check to see if the pump is still operating. If it fails, the fan will still continue to blow air into the house but since the pad is not receiving any water, it will only blow outside air into the house. It is just a plug in replacement fix and very easy to do. A new pump should cost only about thirty dollars or so.
With the cooler running, check to see if the pad is wet . if it is dry, it's a pretty sure bet that the pump is your problem.
Posted on Jun 01, 2009
We purchased a swamp cooler 4 years ago. The first couple of years it worked great. Now for some reason we can not get cold air coming trough. We can't find the manual for the machine. It is a Mastercool swamp cooler and was pretty expensive. I know if properly operated it should cool the house within 10 min. We need to run this all summer. My brother in law says we dont know how to operate the thermostate. ? Any suggestion would be greatly appreciated.
Posted on Jun 30, 2008
2 Suggested Answers
  • 7 Answers
SOURCE: We have a Mastercool II & it was installed ~ 3
The pads you need are at least 8 inches thick. If you have the contractor model, then the pads will be 12 inches thick.
Find a distributor in your town that sells cooler parts, if they dont have them, some of the big home improvement stores carry the pads for your cooler.
Make sure you are using a bleedoff or a dump pump to eliminate the hard water out of the cooler. If you keep those pads clean, they wiil last for many years.
Posted on Aug 07, 2009
New pads smell like urine. What can be done to eliminate this horrible odor?
Try some Downy fabric softener. Or replace them with Aspen pads.Thank you for choosing FixYa.com
May 18, 2011 | Mastercool 67471 Evaporative Cooler Air...
I have an older downdraft mastercool unit. The pads have a groove on one end. Which way do I install the pads? Groove top or bottom? In or out? Thank you, Rich
groove down and toward the inside of the unit, the groove is made to fit the long drain tray it sits on so the pad dries when not it use
Apr 19, 2010 | Mastercool 67680 Evaporative Cooler Air...
Need replacement pads for mastercool mrc55wa evaporative cooler
These pads are available in different sizes and styles at home improvement stores like LOWES or HOME DEPOT (in season)
Sep 18, 2009 | Mastercool 67471 Evaporative Cooler Air...
Water pump size and over saturated pads
Louis, The cooling does not come from the volume of water running over the pads. It cools by cooling the air passing through the wet pads. So, Yours is an impeccably logical argument that leads to a false conclusion. Bigger is not better in this caThe fishy smell is from the matting (pads) when kept saturated, Molds and algae will form if there is too much water also.. Best you get the original size pump Good luck and stay cool - Ned
Jul 25, 2009 | Mastercool 67680 Evaporative Cooler Air...
Jul 20, 2009 | Mastercool 67680 Evaporative Cooler Air...
New Mastercool pads smell bad
The cellulose pads in a mastercool are glued together and usually the adhesive is what you smell. It may take a while for it to go away. Strange as it may seem, as the pads get more mineralization and you use it more the smell will go away. Do not use a cooler for your whole house without plenty of exhaust through a window or an updux. Coolers work best when there is plenty of freely moving air.
May 14, 2009 | Mastercool 67471 Evaporative Cooler Air...
Summer
If it was not drained for winter, do so and then remove all scale from the pan, pump inlet screen, etc. Replace the pads if they are scaled up and remove any scale from the louvered panels. WITH THE POWER OFF, check the belt for cracking and check to drive motor and blower wheel bearings for smooth operation, oil bearings with oil ports. With clean water in the sump, a good drive belt, clean pump screen and clean pads, the unit is ready to power up and run test the float action/shut-off, water distribution through the arms, belt tension (just enough to prevent slipping). These units work best when they can fully evaporate the water, so let the air flow out as fast as it come into the cooled space to maximize the evaporative effect. Also note, these unit must be level to work properly.
Apr 27, 2008 | Mastercool 67680 Evaporative Cooler Air...
Mastercool 67680 Evaporative Cooler Air Conditioner Logo
1,993 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
Steve F
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
