Question about Philips 50P8341 50" Rear Projection Television
Have power but no sound or picture
TV turns on and has a black screen with nosound or picture
  • Philips Master
  • 3,459 Answers
This is a common problem with older Philip Magnavox projection sets. Over time one of the IC chips on the main power board begins to fail. You can find replacment chips and repair instructions on www.magnavoxhelp.com.
Posted on Jun 29, 2008
    Scholar:
  • 87 Answers
Do you have high voltage? Check by turning up one of the screen controls to see if you have retrace lines.(pinstripe diagonal lines across the screen) If present turn the screen control back down until the lines just disappear. Check diodes 6003, 6012, 6025, and resistor 3669. If you don`t get a retrace line by turning up the one of the screen controls, check for missing voltages or shorted components in the horizontal output and power supply circuits. Note: Philips TV`s can be tricky even for experienced technicians. Good luck
Posted on May 22, 2008
2 Suggested Answers
Ecollier2012
  • 3459 Answers
SOURCE: have power but no sound or picture
Goto www.magnavoxhelp.com. They have a kit that will fix this common problem.
Posted on Jul 04, 2008
My Samsung TV has only a faint picture and full sound.
My LED TV has sound, but no picture. - Tom's Guide
www.tomsguide.com/answers/id-2771720/led-sound-picture.html
Dec 28, 2015 - The RCA TVs generally only have a 1 year limited warranty so that ... LG LEDLG LED TV has no picture (black screen) but still has sound TV has ... I Have SAMSUNG UA46 F6400 LED 3D TV I want TO CONNECT MY ... SolvedSamsung ledTV no picture solution; Sony vizio led tv has faint picture solution ...
TV Has Sound But No Picture Troubleshooting Guide ...
? 2:30
https://www.youtube.com/watch?v=ysHfaQKI45M
Aug 31, 2012 - Uploaded by Repair.com
Here are some steps to ease you through TV picture loss-from prevention ... But now when I turn on the tv there only sound nopicture. ... had sound etc. with very very faint picture if you look very closely (which I was). .... How To Fix Samsung LCD TV -Samsung TV Repair (Blank Screen) - Duration: 9:21.
Samsung LCD TV No Picture but has Sound - Electronics ' DSLReports ...
www.dslreports.com > ... > Electronics
DSLReports
Jan 26, 2016 | Samsung Televison & Video
Vizio 42", have picture for about 5 mins then screen goes black.
also check the power cord wire coming from the back of the tv is loose from the tv side or perfect.
Oct 26, 2008 | Vizio Televison & Video
Sharp Lc-26sb24u white screen with sound
You will get a white screen when you unplug the t-con from the main board. Doing so removes power to the LCD panel. Verify that all of your voltages from the power supply are correct. If they are, I'd look at the t-con board. It sounds like there is a problem with the t-con that is pulling down the main board.
May 11, 2012 | Sharp LC Televison & Video
I turn my tv on the picture and sound all work and after about 20min the picture goes to a black screen and I still have my sound. I turned the tv off wait about 5 min turn it back on the picture come on...
If you have electronics experience - check the power supply and make sure you are getting the correct voltage to your inverter boards and main av board - also do you see any movement on the screen take a flashlight and shine on the screen - if you can see a dark image on the screen check inverter boards and power first.
thanks,
michael
Mar 21, 2011 | Element Electronics FLX3210 32 in. LCD TV
Hitachi tv no picture or sound.
my hitachi projection tv 53uwx10b screen is black with no sound or picture when the power button is on
Dec 29, 2009 | Hitachi 53UWX10B 53" Rear Projection...
My syntax Olevia LT30 HV turned on and displayed blue screen for 1-3 sec and than no signal nosound??any advice seems to be inverter issue.
Since you lost both sound and picture, I would suggest to take a look at the power supply for bad filter capacitors, look for bulging on the top of capacitors. If the backlight inverter board is bad you should still get the sound.
Apr 23, 2009 | Syntax LT30HV 30 in. HD-Ready LCD...
Loses Picture, Goes Black... Sound stays on
Sounds like power supply. Probably time for a new tv. You have already got almost 20 years service.
Dec 05, 2017 | RCA F36685 36" TV
Jul 02, 2008 | Philips 50P8341 50" Rear Projection...
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Philips 50P8341 50" Rear Projection Television Logo
96 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
