ASUS M2N-SLIDeluxe motherboard does not detect samsung SATA optical drive SH-S203B.
Just as the subject says.
I have tried a standard sata cable and an optical drive specific sata cable.
  • samppari Jan 17, 2009
    Using my PC for only as a digital audio workstation, I have serious problems with the Asus M2N motherboard and my Samsun SATA disk drive. After checking everything else (audio interface drivers, windows, onboard audio device disabling), it's the hard disk drive that is causing the problems (dropouts, crashes, general sloppyness). Is there something to do? Sami
    President:
  • 2,351 Answers
Hi blckpythn,
If you're bios does not show the SATA drive, than it is possible the SATA controller is defective. I have come across this before.
Unplug the power cable from the PC.
Make sure the SATA data cable (Inside the connector) is clean. Take some alcohol, drip it on to a cotton swab. Clean the connector at both ends. Than clean the SATA connector on the board. Do the same for the SATA power connector. Please be sure everything is plugged in. (It takes very little for the SATA connectors to look connected but are not). Plug in you're power cable & boot to the bios by pressing the delete key. If the SATA drive is not seen by the bios, well you know all ready.
You can call Asus M-F 8:00AM to 5:00PM EST. Tech support number: 1-812-282-2787. Asus warrants their boards for three years. They will ask for the number's typed on a sticker located on the pink LPT port.
You can see this SN from inside you're case only. That SN will let the tech know if you're board is still in warranty. If it is, make sure you get a case number before you hang up with the tech.
You will need a case number before you can get a RMA number.
Good Luck!
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
Posted on May 22, 2008
How do I install a new CD drive in an old destop computer It is an old Compaq Presario 5WV254 The existing CD drive has a ribbon type connector that mates up to the pins on the drive plus a 4 pin module...
The Compaq Presario SWV254 Desktop PC uses IDE technology, not SATA.
In the specifications for the above Desktop PC, it states ATAPI is used for the interface technology, and connector, for the optical drive/s.
[IDE is also referred to as PATA. Parallel ATA
SATA is Serial ATA.
The PATA designation was implemented, so that computer users could easily distinct between IDE, and SATA technology]
1) The IDE interface cable, (Flat ribbon cable), has a connector on each end with 40 socket holes.
(39 are actually used. Most of the time, one socket hole is blocked off. (Pin 32)
2) The SATA interface cable has 7 contact pins. Also referred to as a Data cable.
3) The IDE devices, (Harddrive and optical drive), use a 4-pin Molex connector for the power cable.
4) The SATA devices use a 15-pin connector on the end of the power cable.
More info on SATA,
http://en.wikipedia.org/wiki/SATA
The Samsung SH223C optical drive is a SATA device.
You cannot just plug it in.
IF, you have an open, (Available), PCI slot on the motherboard, you can use a SATA adapter card.
The SATA adapter card plugs into the PCI slot, and has the necessary connections on the card, for a SATA interface cable.
(NOTE*
Just for the SATA interface cable. Does not have a connection for the SATA power cable, you need.
You have to buy a 4-pin Molex to SATA power cable adapter, and connect it to an available 4-pin Molex power cable, on your power supply.
You will also need a SATA data cable. The interface cable that goes from the SATA adapter card, to the SATA optical drive you're trying to install)
This is an example of a SATA adapter card. It is not an advertisement for said website, nor manufacturer,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1281807&CatId=1455
Jan 06, 2010 | Compaq Computers & Internet
As I stated earlier I have ASUS K8S-MX Motherboard, but when I connect IDE 80GB drive with 500GB SATA drive it does not detect my 4 SATA partitions, instead says it is only 500GB unformatted single...
Check your AHCI (or ACHI, can't remember) settings in your BIOS. Turn them off, use "standard pata mode" even though you're using a SATA drive, and try again.
Dec 18, 2009 | ASUS K8S-MX Motherboard
ASUS P5QC does not detect any devices... I have a HD and a DVD hooked up. The jumpers are set to normal but they are connected to the MB with one cable. Does it need to be a master slave setup?
Yes, since you are using two IDE drives on One flat ribbon cable, you need to set the harddrive as a Master drive, and the optical, (DVD), drive as a Slave drive.
When two IDE drives are installed on one cable, BIOS needs a way to find the drive that has the O/S, (Operating System), then the optical drive.
Would recommend you buy a SATA optical drive, as soon as you can afford it. SATA DVD burners aren't that expensive.
Your motherboard is set up for SATA, and SATA is WAY faster than IDE. (IDE is also referred to as EIDE, ATA, and PATA)
Then of course a SATA harddrive, and a fresh genuine copy of Windows in the future.
SATA doesn't care where you plug in a drive, and doesn't care which drive connects to what SATA header. It will find that drive. You can connect any SATA drive, to ANY SATA header on the motherboard.
Having two IDE drives such as an IDE harddrive, and an IDE optical drive on the same cable, S-L-O-W-S your computer down! BIOS has to look to see which drive has the O/S first, then it will look for the optical drive.
Thought I would include two links that tell you, and show you how to set jumpers on the jumper pins, on an IDE harddrive, and IDE optical drive,
1.Harddrive:
http://www.youtube.com/watch?v=WwbboeMO7b8&feature=related
2.Optical drive:
http://www.youtube.com/watch?v=lldXwgPabhE&feature=channel
Should my solution have helped you, feel free to rate it.
Jul 13, 2009 | ASUS P5QC Motherboard - Intel P45, Socket...
My computer shows to setup array and does not detect one hard disk
Please try to system reformat/reinstall OS to your HDD under SATA connection. then kindly check the jumper setting of HDD under IDE connection which I suggest to place it at Master while the SATA HDD will be automatically recognized as Slave by your computer. best regards
May 16, 2009 | ASUS Computers & Internet
M2N-MX SE PLUS SATA PROBLEM
Do your have windows installed on a ide drive?, cos if this is the case you have to install the sata hdd drivers.
Mar 27, 2009 | ASUS M2N-MX Motherboard
Samsung SH-s203 dvd writer is compatable with this motherboard
put the sata cable to sata terminal and also connet the sata power cable to drive.
Oct 28, 2008 | Intel D845GVSR Motherboard
Sata drive not seen by mobo?
On some older models of mother boards, you cannot use the SATA drive as a main start-up drive. You can only use a SATA drive as a data drive if this is your case.
To verify this, re-install the IDE start-up drive. When the computer starts, verify that you can have access to the SATA drive as a second drive.
I have this issue with a few computers at our facility.
Jerry G.
Sep 13, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
HOW TO CONNECT SAMSUNG DVD SH-203N TO A ASUS MOTHERBOARD
This is a SATA DVD Burner.
There should be a sata power and sata data cable
SATA POWER ADAPTER CABLE F is the power cable that attaches to the DVD the other end should be part of the power supply but if it isn't you would need this.
This is the SATA DATA cable would connect to the SATA point on the motherboard to the DVD burner, if the MOBO doesn't have this type connector on it you will need an ide to sata adapter
Apr 15, 2008 | Computers & Internet
My system is
I guess I'm missing something here?
Mar 29, 2008 | Western Digital Caviar SE WD1600AAJS 160...
Second harddrive
Make sure its jumper is set as slave, if you have a 40wire ribbon cable, and cable select if you are using a 80 wire ribbon cable, if it is on the same ribbon cable.
If it is on the second ide cable, by itself keep it as master.
Jan 15, 2008 | ASUS M2N-MX Motherboard
Computers & Internet Logo
586 people viewed this question
David Payne
David Payne
