Make sure the printer is on. Once you open the cover, the ink cartridge carrier automatically goes to a loading position where it moves to the middle. Then, you can replace the cartridges.
Sometimes the ink cartridge carrier won't position automatically to the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Load the new cartridges. Close the cover. Plug the printer back to power source.
Manually Removing Toner for magicolor 2400W
1. Hold down the Cancel button for 10 seconds or longer.
2. With the Cancel button still held down, also simultaneously hold down the Rotate Toner button for 10 seconds or longer.
3. When all LED indicators are blinking rapidly, release both the Cancel and Rotate Toner buttons.
4. Then hold down the Rotate Toner button again for another 10 seconds or longer.
5. The Cyan toner cartridge moves into the proper position, so it can be removed.
6. Remove and/or replace the Toner Cartridge if necessary.
7. Open and close the covers. Each time you do this, another toner cartridge moves into the proper position, so it can be removed and/or replaced (in this order: cyan, black, yellow, magenta).
The link is located here
