Question about Plantronics 320 Bluetooth Headset Headset
Bluetooth connectivity i have Plantronics Vodafone VBH-300 Bluetooth Headset, how i can connect to mobile
  • Anonymous Feb 01, 2009
    how can i use my vodafone vhb-300 bluetooth headset with a vodafone mobile it is a lg kc500
    Guru:
  • 395 Answers
How do I listen to music through the bluetooth
Listen to music with the Plantronics Explorer 220:
Unfortunately the Explorer 220 was not designed for music, it does not have the technology built in to stream audio. Headsets must have the Bluetooth A2DP profile and technology to be able to stream music. Like the Plantronics Voyager Pro+ and BackBeat models. Here are the links for these below.
http://www.headsetsdirect.com/plantronics-bluetooth-headsets/bluetooth-for-mobile-phones/voyager-pro-bluetooth-headset.html
http://www.headsetsdirect.com/plantronics-bluetooth-headsets/ipod-mp3-mobile.html
Good luck from Headsets Direct - 800-914-7996.
Aug 09, 2011 | Plantronics Explorer 220 Bluetooth Headset...
1. Why a new plantronics m100 sometimes (be change to always) disconnects (lost connection) itself while the HTC P3450 phone is kept in my suit pocket? 2. Why the headset emits unclear sound like a buzz...
Starting from the beginning sometimes cures those problems. In the link below for the Plantronics M100 take a look at the "Tips" and "Connect" pages to prepare and pair the headset to your mobile. You want to make sure your phone is empty of any bluetooth devices.
Plantronics M100 User's Guide
Good luck from Headsets Direct!
Mar 18, 2011 | Plantronics M100 Bluetooth Headset
My blackberry bold phone does not locate my Plantronics VBH-300 bluetooth headset whilst trying to pair them. It was paired with a previous nokia phone,which I no longer have.
Hi,you will have to delete the previous paired phones first before you can be able to pair the blackberry phone with your blue tooth device.
You can use the below steps to know how to pair properly:
Instructions
Pair Your Blackberry with a Bluetooth Headset
Turn on Bluetooth headset and Blackberry hand-held.
Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.
Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.
Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically.
Use your Bluetooth Headset with your Blackberry
Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the handheld.
Tips & Warnings
Pair your Blackberry with any Bluetooth-enabled device using the same steps as those for connecting a Bluetooth headset.
Remove your Bluetooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Hope it helped.
Thanks for usingf ixya..
Jan 13, 2011 | Plantronics Explorer 320 Wireless Headset
My bluetooth Plantronics 220 won't turn on
my plantronics will not connect to my htc diamond without being on the charger.when i take the bluetooth off the charger it will not connect
Nov 19, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Code
the code is (0000)
hope this helps
Jun 08, 2008 | Plantronics Explorer 320 Wireless Headset
Plantronics bluetooth
you have to first put bluetooth headset in pairing mode by holding the phone hook button down until blue indicator on headset goes solid blue not flashing then set your phone to find bluetooth device by looking under your phones menu and look under bluetooth or connections make sure to turn on bluetooth function and choose find or add device phone will detect bluetooth device and will display the type of device on your phones display tell it to bond or connect once you select yes thats it the bluetooth headset will start to flash and its ready to go.
Jan 14, 2008 | Plantronics 510 Voyager Headset - PLN-510...
Plantronics sold under Vodafone: VBH-300
Try going through the plantronics website for a replacement. My 590's date code was within warranty and I ended up replacing it TWICE. The one I have now has a different date code and seems to work fine now. I surmise that the charging problem may have to do with bad voltage regulation and extreme sensitivity in their electronics.
Jun 14, 2007 | Plantronics Explorer 320 Wireless Headset
Radio Communications Logo
447 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
