Question about Dell Dimension 2400 PC Desktop
Error 1317 and power surge on hub port
I am having problems downloading anything to my program files. i get this error message 1317 saying it can not create a directory for c:documents and settingsall usersstart menuprograms.
the other problem is the power surge on the hub port. i plugged my printer back in and now i get that.
on top of all of this i need my printer for work and i can not re-install the software and i can't connect the thing.
murphy's friend
  • silverwolff7 May 30, 2008
    i am open to all help. i was attempting to back up all my important stuff to reformat, when my kodak software updated and now i can't see my pics because i need quicktime for it. i can't update quicktime because of the directory problem. so now all my pics are in jasc panit pro which i don't have. System restore won't work either. i am about to pull my hair out.
    Sergeant:
  • 336 Answers
If you are willing to let me work on your computer from my end I can attempt to fix your problem. Can you tell me your response ASAP so I can help you get your computer back on track?
All The Best,
RCF
Posted on May 28, 2008
  • Ryan Frame
    Ryan Frame May 28, 2008
    I found a website that will help you solve your problem. The site is
    http://support.microsoft.com/kb/306986 If you need anything else in the future yo can just ask.
    Hope This Helps
    All The Best,
    RCF
  • Ryan Frame
    Ryan Frame May 30, 2008
    Okay I can work on your computer today (Friday) at about 5pm eastern standard time. If you want to do this e-mail me at 4077mashunit@gmail.com
    RCF
I Have Toshiba Satellite Laptop, i am continuously getting pop up message " Power Surge On Hub Port " A USB device has exceeded the power limits of its hub port. Please help how to stop this pop...
Remember the help below is only a fix for seeing the error message not for overdrawing the port.
To stop overdrawing the port you need to either use a power supply or a double USB cable.
To prevent seeing the USB Power Surge alert message, complete the following steps:
Click on START, Click on CONTROL PANEL, Double-click on the SYSTEM icon, Click on the HARDWARE tab, Click the DEVICE MANAGER button, Click the "+" next to Universal Serial Bus Controllers to expand the selection.,Right-click and select PROPERTIES on the Intel® USB UNIVERSAL HOST CONTROLLER (not the USB Root Hub),Click the ADVANCED Tab, Check the box that says: "Don't tell me about USB errors"
Nov 29, 2010 | Amstron Toshiba Satellite A80 Laptop AC...
Hp nx6110 laptop error power surge on hub port
OK if you have anything plugged into the USB Ports at bootup, unless Keyboard or Mouse, remove everything, and see if it boots normally, if it does, then the "Hub" you are using may be faulty, or a device you are using is drawing a lot of current at switch on and overloading the USB bus, that can only supply 500mA. If it still does it, and you do use a USB KB & Mouse, then remove them one at a time & reboot, between, and see if it was one of them causing the problem. If you have nothing attached then your internal USB bus is flaky.
Feb 16, 2010 | HP Compaq nc6120 Notebook
Power surge on hub port message
unplug your mp3 player immediately!! it will fry your mp3 player if you leave it plugged in!! try adjusting the player's settings and seeing if there is somewhere to switch it from '1000mah' to '500mah' or lower. try that. if it still gives the error try a different usb port.
May 26, 2009 | Microsoft Windows XP Home Edition
Use a powered hub, one that has it's own power supply.
May 09, 2009 | Microsoft Windows XP Home Edition
Power Surge on Hub Port
Some USB devices draw excessive power from the USB port, especially USB scanners. When this happens you need a powered USB hub, connect this to your computer's USB port and connect the USB device into the powered USB hub, you should not have any further error power surge problems.
Apr 27, 2009 | Compaq NX6110 TFT XGA Notebook
Usb port not recognized: power surge on hub port
Your going to need a new logic board, I know only one place that fixes creative zen players and sells the parts besides ebay.
Apr 17, 2009 | Creative Labs Zen Vision Digital Media...
Power surge message
Problem :Overvoltage on USB hub port
Solution: Look carefully at that same port and you will four gold pins make sure they are NOT touching each other..
Apr 16, 2009 | Computers & Internet
Error power surge on hub port
Some USB devices draw too much current from the computer's USB port and you get an exceed power error message.
To get around this problem, get a powered USB hub and connect it to the Computer's USB port and then connect the troublesome USB device into the powered USB hub.
Apr 09, 2009 | Lenovo 3000 N500 Notebook
Western Digital Passport 160 GB external HD won't load.
WinXP SP2 blocks the use of the drive because it thinks it draws too much power. But there is a simple procedure to override this (from WD site):
"Problem:
Under Windows XP, an error message of "Power Surge on Hub Port" or "USB device has exceeded the power limits of it's hub port" is displayed when connecting a USB device to a USB port on a computer or Hub.
Cause:
Under some computers, USB devices are only allowed to draw a maximum of 500 milliamps (mA) per connection from the USB port on the computer system or from a USB hub. Under the Windows XP Operating System, with the release of Service Pack 2, if a device attempts to draw more than this (500 milliamps), a USB port balloon message is displayed to indicate this over current condition. When connecting a USB device that draws power from the USB bus, a very brief over current condition is sometimes detected by the OS, and the warning message is displayed.
Resolution:
This message has no affect on the functionality of the USB port. The USB hard drive should still function correctly on the USB port regardless of the error message. To prevent the USB Power Surge Alert message from displaying, please complete the following steps:
Click on Start.
Click on Control Panel.
Double-click on the System Icon.
Click on the Hardware Tab.
Click on the Device Manager button.
Click on the + next to Universal Serial Bus Controllers to expand the selection.
Right-click and select Properties on any listing that displays USB UNIVERSAL HOST CONTROLLER.
Click on the Advanced Tab.
Check the box that says: Don't tell me about USB errors."
This works fine, and the drive works fine afterwards. I suspect it actually draws less power than they say. Maybe it has a brief power draw spike on startup, but it's running power seems less. In any case, it works fine without the Y cable. I do think it is tacky that WD doesn't give the cable for free, since my $7 Sabrent 2.5" Hard drive enclosure came with a y cable.
But most likely the drive will work fine for you. It is a lovely quiet drive, and takes up no space at all.
Feb 01, 2009 | Western Digital Passport 160GB External...
Power surge on hub port error msg
The printer is the problem, obviously but, also try using a different USB cable to see if that doesn't help! When plugging up th cable, look for anything out of the ordinary! If changing the USB cable doesn't resolve the situation then it could be something shorted out in your printer and you need to take it to a service shop for repair! regards, babb
May 15, 2007 | HP Deskjet 5440 InkJet Photo Printer
Dell Dimension 2400 PC Desktop Logo
91 people viewed this question
Alun Cox
