Question about Dishwashers
Maytag Dishwasher model # MDB5130AWW
The "clean" light blinks along with the "heated dry" light, then goes out after a few minutes..When I push "normal wash" I can hear something come on inside, but after a couple of minutes, it shuts off...
  • 1 more comment
  • jwf523 Oct 01, 2008
    I have a Maytag MDB5100AWW and the same two lights continuously blink and can't make anything happen.
  • Anonymous Mar 23, 2014
    will not start
    MAYTAG QUIET SERIES 300 MODEL #MDBH968AWB3--CANT FIND MANUAL. The normal, tough scrub, high temp, heated dry, and sanitize lights are on and the start light is blinking. The locked light is off. I turned the breaker switch off for a few minutes and back on, same thing.
I had a similar issue with my MDB5130AWW. The Wash was interupted and wouldn't come back on. Not knowing where to start I read some other solutions on this site and started by opening the bottom cover. Thats where I found a 4 page diagnostic / Electrical Schematic. Start with the Sales Demo mode of pressing the Rinse button 5 times within 5 seconds. I had to do it twice before the washer came "alive". I was estatic after reading about the $100 mainboard cost and maybe more for other parts. The document has other test and what different keypads mean when flashing. Thankfully I didn't have to go that far.
Posted on Aug 27, 2008
All you can do is turn the power off at the power point, leave it for a few minutes and then switch the power back on.
Jan 11, 2016 | Dishwashers
Green light is blinking --says clean when you push
Hello & Welcome to FixYa
Flashing green light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Jun 10, 2011 | Kenmore 16764 Dishwasher
Blinking "Normal" light on a Maytag model
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
May 19, 2011 | Maytag Dishwasher
After starting dishwasher to do a normal wash with heated dry, the dishwasher stops and Clean light blinks 7 times, pauses and this continues until I reset the machine. After reset it goes to rinse only...
Please check if the clean light is blinking 7 times. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry.
If this doesn’t work then its an issue with the heater circuit, door switch, wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. If heater is fine then make sure water pressure is optimum and fill valve is working fine.
Please post back for further assistance.
Aug 20, 2010 | Whirlpool 24 in. DU1148XTP Built-in...
Kenmore dishwasher clean light blinks
The computer needs to be reset. you may need to check the tech sheet that should have come with the dishwasher ( usually behind the toe panel) for directions on reseting it. If you cannot find the reset directions, let me know, I will have to look it up. thank you.
Jul 07, 2010 | Kenmore Dishwashers
Blinking lights, unresponsive
I went to the Maytag site looking for a manual. None existed for my model, but I looked up won't start under the FAQs. The advice said to push the cancel button twice. My model doesn't have one, so I just started at the left side of the control panel and pushed each button twice. pushing the dry button twice made the lights stop blinking. i pushed the wash button and the unit started.
May 08, 2009 | Dishwashers
Kenmore elite model 16574
press (high temp-wash) button and then ( heated dry)
do that 3 times in that order within 5 seconds. So it looks like this:
(high temp-wash) ( heated dry) (high temp-wash) ( heated dry) (high temp-wash) ( heated dry)
That will start a short diagnostic cycle (last about 2 minutes) that will clear the blinking light and allow you to use the dishwasher. If the light comes back, your drying cycle has failed and you will need service.
Oct 28, 2008 | Kenmore 24 in. 16352 / 16354 / 16359...
Clean light keeps blinking and I can't start a new cycle
Puppa, clear the fault by pressing the keys in this order: high temp scrb--air dry--high temp scrub--air dry. Or, depending on your model..Sani rinse--air dry--sani rinse--air dry. The dishwasher will enter the service mode. Let it do it's thing or advance it through it by pressing the start key. The fault came from the board not sensing a rise in the water temp. Make sure to run the hot water before starting the dishwasher. The heating element runs through the nuetral side of the door switch so make sure the d/w is level and the door switches are all making. The element itself could be at fault. back
Apr 01, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
"Clean light" keeps blinking; dishwasher won't start new cycle
close the door and to cancel that just press hi temp and hetaer dry again hi temp and heater dry and all the lights is gonna light up, it getting into test mode.
After that press cancel
Now get somebody to replace the thermistor of your machine
Feb 19, 2007 | Kenmore 24 in. 17032 Built-in Dishwasher
Dishwashers Logo
471 people viewed this question
Top Dishwashers Experts
