Question about Weather King 10AJA2501AH Air Conditioner
Heat strip install
Hooking up package unit straight cool have a red brown yellow green and orange wire in the unit my thermostat wire has all but instead of orange its white can i hook up the orange unit wire to the white thermostat wire
  • Anonymous Mar 17, 2014
    Green white red and blue wires electric heat
  • 828 Answers
What color wire is connected to the "Y" terminal on the thermostat.
If the unit you are connecting is a heat pump A/C unit the orange wire is for the heating mode. Normally the "Y" terminal on the thermostat. "R" terminal on the thermostat is the power to the thermostat, "W" terminal is for heating, "Y" is for cooling, and "G" terminal is for fan operation. At the condensing unit for cooling the brown and yellow wires would normally be for the cooling.
Posted on May 22, 2008
I have a 3 ton Bryant split unit I'M trying to rewire.
what colors are landed where on the tstat? and does the tstat wire that goes BOTH inside and outside have the same colors. also why are you in this situation, has everything been unhooked?
Feb 09, 2018 | Heating & Cooling
Hi I have a hb2400vd2m20 air handler and need to know what wires are needed to hook up to my thermostat its a Honeywell, as of the moment there is no heat pump it just the air handler running. I know there...
Honeywell 5000, 8000, 8000 iaq, prestige, round dial analog, digital Honeywell redlink. 1 heat 1 cool thermostat 3 heat 2 cool thermostat. does the stat u have do conventional a/c and heat pump. red wire is hot wire 24 volts not heating its your 24 volt control power. this will be r on your board and t-stat and red wire. y is for cooling mode and is yellow and will be noted y on both board and t stat. green is fan on the indoor furnace and will be g on board and t-stat and the wire is green. blue is the common side of the transformer labeled b on both board and t-stat. I did not see brown on your schematic I looked up I seen orange which is your reversing valve wire for the heat pump whether its calling for cooling or heat this is what changes the flow of Freon to make it to the indoor coil as warm Freon or cold when called for in heat or cool. the thermostat if a vision pro 8000 needs to be programmed in the installer mode which if this is the t-stat u have u need to read through the heat pump section. the green hooked to the orange doesn't look right on the print but that's the breakdown. http://www.manualslib.com/manual/277678/Haier-Hb2400vd2m20.html?page=11#manual heres your schematic
Oct 20, 2013 | Haier 2.0 Ton Multi-position Air Handler...
I installed a new Honeywell Programable thermostat, When I turned on the AC it turned on the Heater... I followed the wiring but some of it is not making sense... G=Green, Y=Yellow, R=Red, C=Blue,...
Hi, the problem is you have bought the wrong thermostat for the unit if it is not a heat-pump. A heat pump will have W-1, W-2 for heat strips, and Y-2 is for 2nd stage cooling. G is Green for Fan, R is Red for Power, Y is Yellow for cooling, and W would be for Heat. This is all you need if you have gas heat, Orange is for a reversing valve for a heat-pump, and the blue is also for the reversing valve on a Rheem heat-pump. The stat you need will have these terminals, if you are sure its not a heat pump, which I am sure you would know. The stat you need has these terminals. RC and RH. It will have a Red jumper wire connecting the 2 terminals. This is where the Red wire connects, to either one, as they connect together. Connect G to Green, Y to Yellow, and W to white. Since you only have one control transformer, that's why the stat has RH for Red Heating, and RC for Red cooling tied together. Just hook the red coming in to either one. You need only, R, G, Y, and W, to run this unit. Look at your old stat and check the terminals. A heat-pump, uses many more conductors to operate it. O or orange for the reversing valve, blue also depending on the unit. C for common, W1 for stage one heating, W2 for stage 2 heating, Y1 for stage one cooling and Y2 for stage 2 cooling. This stat is used for a commercial unit with multible stages of heat and cooling. If you have a common wire and no batteries on the old stat, go to the indoor unit, remove the panel, and see if you have a common wire hooked up, such as the brown, black, or maybe blue. If so, you will need to hook it up at the stat if it has a C terminal. If it has batteries, just take all of the extra wires and shove them in the wall. You won't need them. Just the R, G, Y, and W, and you will be back on line. Very easy.
Please rate me. Take it back and have them sell you the right stat. Please keep me posted and I will be here if you need my help. Thank you for using Fixya.
Shastalaker7
A/C, and Heating Contractor
Nov 23, 2010 | Goodman Heating & Cooling
Wiring instructions for Thermostat Honeywell with Carrier Package
Jumper R to Rc and hook hot wire from transformer to R usually red wire
O = Reversing valve probably white or orange If you get heat when calling for cool or Vice Versa then switch wire from O to the B terminal.
Y = Contactor usually yellow
G = Blower usally green
Jumper Aux to E need to go to unit and use the wire that goes to your Auxiliary or 2nd stage heat
L = Light if you have this terminal on your unit then hook it up.
C = Common from transformer usually black, if you have this terminal on your unit hook this wire up.
Make sure you go to your unit and only hook these wires up if they go to these locations.
Jan 11, 2010 | Heating & Cooling
Honeywell RTH2310 heating while it's supposed to be cooling
ok to start with if you have a heat pump and not ac over electric heat depending on type but most will be wired as
red to r jumped to rc y to yellow this turns on compressor g to green this turns on fan w to white or brown for electric heat strip or em heat o to orange reversing valve energised in cooling switches from heat to cool or orange to b energised in heating c blue for common
you will have to look at your indoor unit and out door unit to verify what collors the contractor used when they wired it up hope this helps
May 31, 2009 | Honeywell Programmable Thermostat Heater
Thermostat wiring goodman model aruf032-ooa-1b
is this a heat pump or straight cool with heat strips?
Mar 16, 2009 | Heating & Cooling
Trane Weathertron XE1000 Thermostat Wiring
Check to see if you have the system switch accidently on em. heat. The way you have it wired is correct except for the having brown on e. disconnect brown wire and cut ofbare end just in case they have the wire hooked up for constant run on roof.
Feb 08, 2009 | Heating & Cooling
I am replacing a white rodgers thermostat with a honeywell rth3100c. i have matched my wire as e (brown) to e w2 (white) o aux y (yellow) to y g (green) to g o (orange) to o l blank r (red) t r b blank c...
Blue (C) or sometimes (B) should be your common wire. Look at your schematics and locate common. Your Brown wire is (E) and is emergency heat, white wire (W) is Auxilary Heat, green wire (G) is fan relay, red wire (R) is power, yellow wire (Y) is Cooling and orange wire (O) is reversing valve.
Dec 02, 2008 | Heating & Cooling
Weather King 10AJA2501AH Air Conditioner Logo
812 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
